FreeCAD Basic Tutorial For Bad User (Beginner & Pro Not Recommend)
Learn freecad basic 3d modeling tutorial for Bad User
Re: FreeCAD Basic Tutorial For Beginner Exercise 09
I cannot really recommend this video. It is considered bad practice to reference generated geometry.
- Shalmeneser
Overly complicated !
The bigger error : not to use symetrical axis.
- Mufasucad09_SHALM.FCStd
- (64.15 KiB) Downloaded 108 times
Thanks for your advice on my tutorials, great advice for me to make more better tutorials
- Shalmeneser
With a master sketch (do not touch it !).
- Mufasucad09_SHALM2.FCStd
- (61.67 KiB) Downloaded 122 times
- Capture du 2021-09-14 08-57-43.png (78.88 KiB) Viewed 8780 times
- Shalmeneser
- Mufasucad11_SHALM.FCStd
- (77.59 KiB) Downloaded 100 times
- Shalmeneser
- Mufasucad13_SHALM.FCStd
- (75.44 KiB) Downloaded 97 times
update for exercise 20
- Shalmeneser
Please don't call this "Tutorial For Beginner" because there is too much bad practices :
* Use Sketcher_ConstrainSymmetric and axis (so 107 and DatumPlane are useless)
* Do not repeat the same dimension. Use Sketcher_ConstrainEqual.
* Prefer Horizontal/vertical distance to Sketcher_ConstrainDistance
* For fillet selection, try Wireframe display
* Do not use Zero dimension
* Do not support sketch upon face, but prefer axis or sketch line.
(Problems with fillet in my file)
- Mufasucad20_SHALM.FCStd
- (455.88 KiB) Downloaded 81 times
To add to this:
* You don't need these construction lines in the first sketch.
* You could use some for the equal distances.
