Collaboration between sketcher, part, draft, curves, partdesign and mesh
- JoeKundlak
Re: Collaboration between sketcher/part and draft. sketcher for tangents, draft for array and 3d bspline. 3d wireframe d
It's not necessarily ťhe speed, it's a combination of the german interface and advanced techniques (ie. not known to me yet). Give me a year
Joe
translating into SK: https://wiki.freecadweb.org
- thomas-neemann
I also needed 1 year.JoeKundlak wrote: ↑Fri Nov 19, 2021 4:45 pm It's not necessarily ťhe speed, it's a combination of the german interface and advanced techniques (ie. not known to me yet). Give me a year
- thomas-neemann
cooperation part draft
https://www.youtube.com/watch?v=1Mn-fmeIV9E
edit
here extrusion is better than loft
https://forum.freecadweb.org/viewtopic. ... 99#p549945
edit
Last edited by thomas-neemann on Sat Nov 27, 2021 7:45 am, edited 2 times in total.
It is recommended to use the simplest tool possible. So you should rather use a pocket instead of the loft. It may work here, but in other cases things may fail, e.g. because loft can create plain B-spline faces instead of real planes.
- thomas-neemann
I find that very interesting. is there an example file for such a case?
There are lots of these in the forum, but I have none at hand currently.thomas-neemann wrote: ↑Sat Nov 27, 2021 6:32 am I find that very interesting. is there an example file for such a case?
- thomas-neemann
ok, i will look for something like that, if anyone else has a file, please upload it
- thomas-neemann
according to my understanding, extrude should also avoid the problem
Extrude is most probably what is used internally if you create a pocket. The quality of the result will thus be as good as with the PartDesign feature, only the way requires more steps.
- thomas-neemann
cooperation sketcher part
https://www.youtube.com/watch?v=rCfmtdCaUzI
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.26479 (Git) AppImage
Branch: (HEAD detached at 00e0fc7)
Hash: 00e0fc73d950a26d9cc41bbc861a53bda7754d58
Python version: 3.9.7
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.3
