Exercises for fast stable models from combinations with partdesign part and arch-draft (german audio)
A place to share learning material: written tutorials, videos, etc.
thomas-neemann
Post by thomas-neemann »
partdesign_draft
https://www.youtube.com/watch?v=cuy6UWUOl0Q
phpBB [video]
changes
https://www.youtube.com/watch?v=VjdJ5z7p1ZI
phpBB [video]
simple model with dimensioned, digital plan (pdf)
https://www.youtube.com/watch?v=KbT7yPXSBQ8
phpBB [video]
Last edited by thomas-neemann on Sun Jul 10, 2022 7:25 pm, edited 1 time in total.
thomas-neemann
Re: Exercises for fast stable models from combinations with partdesign part and arch-draft
exercise quick construction of a lock, riegel in german, (homage to jürgen riegel one of the co-founders of freecad). I don't think there is a faster or easier way.
https://www.youtube.com/watch?v=KosJ1dlpGXw
phpBB [video]
1101-fin.FCStd
(14 KiB) Downloaded 48 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
thomas-neemann wrote: Thu Jun 30, 2022 5:10 am I don't think there is a faster or easier way.
I do:
- PartDesign: Sketch two circles
- Pad
- Sketch rounded rectangle with two circles inside
- Pad.
This is not only fast and easy but also parametric.
thomas-neemann
chrisb wrote: Thu Jun 30, 2022 6:35 am ..
I will try and report here
thomas-neemann
chrisb wrote: Thu Jun 30, 2022 6:35 am ...
I found a nice toot. so I will compare both versions. I will shoot videos of it and compare the times
http://www.mousometer.de/download/
I couldn’t find something similar for macOS.
Ich habe leider noch nichts Entsprechendes für macOS gefunden.
thomas-neemann
here is the result with my working speeds. this confirms the possibility of being able to work twice as fast in freecad as with conventional 3d cad systems/workflows. that's what my customers want, they say: "since we started working in 3d, our construction times have doubled and we're losing contractors to faster competitors". I am of the opinion that with freecad you can probably be as fast as in 2d.
time factor 2
mouse km factor 3.5
clicks factor 3.8
key factor 2.2
https://www.youtube.com/watch?v=4z68yUuA_NA
phpBB [video]
thomas-neemann
chrisb wrote: Fri Jul 01, 2022 12:36 am Ich habe leider noch nichts Entsprechendes für macOS gefunden.
I hardly find anything for mac either, something very old which doesn't count the clicks. you could use this on your linux computer
sudo add-apt-repository ppa:atareao/atareao
sudo apt install habits
thomas-neemann wrote: Fri Jul 01, 2022 7:26 am time factor 2
mouse km factor 3.5
clicks factor 3.8
key factor 2.2
I would rate that as pretty good for someone who is untrained with sketching. I'm sure it would take much longer if I did it in Draft.
Your Draft model is still missing a couple of clicks: Select PartWorkbench (2 clicks), select both objects (2 clicks), create union (1 click). Without that it wouldn't be an hommage to Jürgen, but to Mrs. Tube and Mr. Plate.
This would be my take in PartDesign; AutoConstraints enabled.
Create the plate:
3 clicks New Sketch on XY plane. (Precisely: 1 click + 1 double click)
2 clicks select rounded rectangle
4 clicks create two rounded rectangles
5 clicks select circle and make two circles on the y axis
Constrain the plate:
5 clicks select horizontal distance and constrain all such dimensions
7 clicks dto. with vertical distance
5 clicks equality of radiuses
10 clicks symmetry tool selection and application
3 clicks radius constraining
When using keyboard shortcuts one click per line can be saved
1 click close sketch
3 clicks Pad, it would be two if it shouldn't be symmetric
Create the tube:
3 clicks New Sketch on XZ plane
5 clicks select circle and make two concentric circles on the y axis
Constrain the tube:
3 clicks point on object for fixing the vertical position of the circles
3 clicks radius constraining for the two circles
3 clicks Pad symmetric
That makes a total of 66 clicks. I use the enter key for confirming inputs. If I wanted something only on the Draft level, it could be even faster, because I could simply use sketcher's grid snapping without any constraints.
riegel_cb.FCStd
(27.21 KiB) Downloaded 53 times
thomas-neemann
chrisb wrote: Sun Jul 03, 2022 6:07 pm ...
I like that, how long did it take?
