Error to write mesh
Moderator: oliveroxtoby
poulmack
Error to write mesh
Post by poulmack »
Hello,
I am using FreeCAD_0.20.27422 and installed OpenFOAM V2012, ParaView, cfMesh, HiSA for Windows.
I am able to select the physics model, FluidProperties, and boundary conditions, but when I try to run the mesh the following errors appear
23:41:47 Traceback (most recent call last):
23:41:47 File "C:\Users\paulc\AppData\Roaming\FreeCAD\Mod\CfdOF\.\_TaskPanelCfdMesh.py", line 228, in writeMesh
23:41:47 FreeCADGui.doCommand("cart_mesh.writeMesh()")
23:41:47 File "<string>", line 1, in <module>
23:41:47 File "C:\Users\paulc\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdMeshTools.py", line 81, in writeMesh
23:41:47 self.processRefinements()
23:41:47 File "C:\Users\paulc\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdMeshTools.py", line 252, in processRefinements
23:41:47 bc_group[nb].Label, bref[0], bref[1], bc_group[nb2].Label, bref2[0], bref2[1]))
23:41:47 TypeError: 'int' object is not subscriptable
I am following this tutorial (https://www.youtube.com/watch?v=7i_K7fo8BSk). What could be the error?
Please find attached the file.
CFD model.FCStd
(129.72 KiB) Downloaded 59 times
oliveroxtoby
Re: Error to write mesh
Post by oliveroxtoby »
poulmack wrote: Tue Mar 29, 2022 5:49 am Hello,
This was a bug - should be fixed now, so please update your workbench. Please note that it will now warn you that you have assigned the inlet and outlet to the same patch.
ddettrick
Post by ddettrick »
I am a newby to FreeCAD also having meshing problems. Any ideas?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
13:05:31 Exporting mesh refinement data ...
13:05:31 Matching boundary patches
13:05:31 Traceback (most recent call last):
13:05:31 File "C:\Users\David\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdMesh.py", line 207, in writeMesh
13:05:31 FreeCADGui.doCommand("cart_mesh.writeMesh()")
13:05:31 File "<string>", line 1, in <module>
13:05:31 File "C:\Users\David\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdMeshTools.py", line 81, in writeMesh
13:05:31 self.processRefinements()
13:05:31 File "C:\Users\David\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdMeshTools.py", line 259, in processRefinements
13:05:31 bc_group[nb].Label, bref[0], bref[1], bc_group[nb2].Label, bref2[0], bref2[1]))
13:05:31 TypeError: 'int' object is not subscriptable
Planetoid.FCStd
Planetoid.FCStd
(62.27 KiB) Downloaded 45 times
oliveroxtoby
ddettrick wrote: Sat Jun 11, 2022 3:22 am I am a newby to FreeCAD also having meshing problems. Any ideas?
Please make sure you update your workbench to the latest version via the Addon manager. When I mesh your case, I don't get that error, just the warning
Boundary 'MeteorArive' reference Pad:Face4 also assigned as boundary 'wall' reference Pad:Face4 - ignoring duplicate
which indicates you have assigned two different boundary conditions to the face in question.
nordman
Post by nordman »
Hallo,
i have PC with
Windows 10, last updates, 64 bit
FreeCAD 0.19.4
cfdOF 1.17.7
MS MPI v10.1.2 is installed
Messages after start "Write mesh case" and "Run mesher":
20:40:32 Part to mesh:
Name: Body, Label: Body, ShapeType: Solid
20:40:32 CharacteristicLengthMax: 0.66
20:40:32 Exporting mesh refinement data ...
20:40:32 Matching boundary patches
20:40:32 Matching mesh refinement regions
20:40:32 Exporting the part surfaces ...
20:40:32 Triangulating part Body, patch patch_1_0
20:40:32 Triangulating part Body, patch patch_2_0
20:40:32 Triangulating part Body, patch patch_3_0
20:40:32 Populating mesh dictionaries in folder C:\Users\TOM\AppData\Local\Temp\meshCase
20:40:32 Successfully wrote meshCase to folder C:\Users\TOM\AppData\Local\Temp\meshCase
20:40:32 Wrote mesh case to C:\Users\TOM\AppData\Local\Temp\meshCase
20:40:38 Executing: ./Allmesh in C:\Users\TOM\AppData\Local\Temp\meshCase
20:40:38 Sourcing OpenFOAM environment...
20:40:38 openfoam: windows support (mingw64) is runtime only
20:40:43 C:/Users/TOM/AppData/Roaming/ESI-OpenCFD/OpenFOAM/v2206/msys64/home/ofuser/OpenFOAM/OpenFOAM-v2206/platforms/win64MingwDPInt32Opt/bin/blockMesh.exe: error while loading shared libraries: libmeshTools.dll: cannot open shared object file: No such file or directory
20:40:53
With freeCAD 0.20 and 0.20.1 - the same error messages.
How to fix loading shared libraries?
