export to obj with groups and same mesh
Moderator: oliveroxtoby
bernd
Postby bernd » Wed Aug 03, 2016 1:02 pm
There has been group export added to obj recently ...
The OpenFoam guys are quit excited about this feature :) They wonder if it is possible to use the same mesh for the different exported groups. Attached a FreeCAD file. To get different groups I extracted the three different shapes from the fusion. They all where selected and exported to *.obj. The file than has three groups, but they gets meshed independent. See attached screen from reimport.
Is it possible to export parts (groups of faces ore single faces) of the fusion into differend groups but have the whole fusion meshed consistently.
cyclone--bhb.fcstd
(24.09 KiB) Downloaded 56 times
cyclone6.obj
(20.51 KiB) Downloaded 95 times
reimport screen: EDIT: made a red circle to mark the problem
export_objs = []
export_objs.append(App.ActiveDocument.getObject("Shape"))
export_objs.append(App.ActiveDocument.getObject("Compound"))
export_objs.append(App.ActiveDocument.getObject("Shape001"))
export_file = u"C:/Users/bhb/Desktop/0110--openfoam--meshgroups/cyclone6.obj"
Mesh.export(export_objs, export_file)
Site Admin
Re: export to obj with groups and same mesh
Postby wmayer » Wed Aug 03, 2016 1:59 pm
The export works this way:
1. Internally a tmp. global mesh object is created
2. For every selected object another mesh is created if possible (at the moment for mesh & part objects)
3. The points and faces of this mesh are added to the global mesh and a named segment is created for the new data (the segment is needed to handle the grouping stuff)
4. The global mesh goes to the obj export function and inside there first all points are written out and then for every segment a new group is created and the corresponding face indexes are written out
No, it's not possible this way and I'm not sure what they want to achieve with this.
Yes, and isn't this the sense of it?
Recently there was on the German forum an issue where somebody selected a few objects, exported them to obj and was not happy that on import in his other application it was one big mesh. He wanted to have independent mesh objects.
The export function cannot decide how to do the meshing because in one case someone needs it this way and in another case someone else needs it differently. If a shape must be meshed consistently then the input shape must be at least a compound or even a shell or solid -- not independent faces. However, then the compound (or shell or solid) appears as a single mesh in the obj file afterwards.
bernd
Postby bernd » Wed Aug 03, 2016 2:16 pm
My misstake. I should have been writing:
They wonder if it is possible to use the same edge, node and face data for the different exported groups (meshes).
After reimport there should be 3 meshes, but it should look like in the screen attached. I marked the differnce in the first post screen.
Site Admin
Postby wmayer » Wed Aug 03, 2016 3:17 pm
I see what you mean. As said before this is too complex for the mesh export function to handle it all. And it has actually not much to do with the obj export as such.
What we need is a special function e.g. in the tessellation panel from the MeshPart module where you can say "Mesh together but keep separate". There we could add an option where several shapes are selected and meshed together but for each shape its own mesh in the document is created.
Afterwards you select the created meshes and export them as obj.
Site Admin
Postby wmayer » Wed Aug 03, 2016 3:27 pm
Just tried your example and apparently creating a compound is not sufficient. This means we need a shell to have the faces sewed together because otherwise the individual shapes are meshed independently again.
bernd
Postby bernd » Wed Aug 03, 2016 3:32 pm
wmayer wrote:What we need is a special function e.g. in the tessellation panel from the MeshPart module where you can say "Mesh together but keep separate". There we could add an option where several shapes are selected and meshed together but for each shape its own mesh in the document is created.
For me it seams this is exactly what these guys need. Let's wait for chris to comment this.
EDIT: related: viewtopic.php?f=3&t=4284&p=75302&hilit=openfoam#p75302
cfdfoundation
Postby cfdfoundation » Wed Aug 03, 2016 4:07 pm
Firstly, the inclusion of group names in the obj (surface) mesh export is very useful when we use the obj mesh for volume meshing with snappyHexMesh in OpenFOAM for CFD. This is highly appreciated.
The slight weakness is that the different grouped regions of the surface are meshed separately so the overall mesh includes gaps and overlaps. It is better that a closed volume, e.g. a cylinder, is strictly closed in the tesselated form.
So, indeed, it would be very helpful to have a function as described by wmayer as "Mesh together but keep separate".
Ideally, vertices along the interface between regions should be shared, not duplicated. I imagine they may get duplicated during meshing, but I don't know if there is a function that can filter out duplicates. If not, OpenFOAM has the surfaceMergePoints utility that can remove the duplicate vertices from an OBJ file. - chris
Site Admin
Postby wmayer » Thu Aug 04, 2016 2:40 pm
With the latest changes this is now possible at least in Python. From Bernd's example there is an object "Fusion". For its faces 7 and 8 a separate mesh should be created and the other faces should go into one mesh. Here is the code to achieve this in Python:
import Mesh
shape=App.ActiveDocument.Fusion.Shape
shape.tessellate(0.1)
# for each face gets its tessellation and create a tmp. mesh
face_mesh=[Mesh.Mesh(shape.getFacesFromSubelement("Face",i+1)) for i in range(len(shape.Faces))]
mesh1=face_mesh[6]
mesh2=face_mesh[7]
face_mesh.remove(mesh1)
face_mesh.remove(mesh2)
# create one mesh from all other faces
mesh3=Mesh.Mesh()
[mesh3.addMesh(i) for i in face_mesh]
# in case it causes duplicate points, remove them
mesh3.removeDuplicatedPoints()
Mesh.show(mesh1)
Mesh.show(mesh2)
Mesh.show(mesh3)
bernd
Postby bernd » Thu Aug 04, 2016 4:09 pm
and here the file ...
cyclone7.obj
(626.76 KiB) Downloaded 91 times
:D
BTW:
I tried to get a more rough tessellation but changing the parameter in shape.tessellate(0.1) did not do the trick :?
Site Admin
Postby wmayer » Thu Aug 04, 2016 4:59 pm
When meshing a shape the data are attached to the Brep structure and subsequent calls of the meshing function have no effect. You have to clean the Brep structure from the mesh and then a call of the meshing function creates a new mesh.
In Python you can use the method "cleaned" which returns a copy of the shape without mesh data. Then use tessellate with a different tolerance.
