export to obj with groups and same mesh
Moderator: oliveroxtoby
bernd
Re: export to obj with groups and same mesh
Postby bernd » Fri Aug 05, 2016 5:02 am
:D
cyclone8.obj
(20.03 KiB) Downloaded 36 times
Site Admin
Postby wmayer » Wed Sep 07, 2016 5:22 pm
git commit 361951e now offers a GUI method to define the groups. As discussed before you have to define colors per faces and then use the Standard mesher and set the option to create the segments.
bernd
Postby bernd » Thu Sep 08, 2016 5:21 am
- open attached file cyclone--colors
- change to Mesh Design workbench
- select the object Fusion in Tree View
- Menue Meshes --> create mesh from shape
- change to standard mesher
- activate checkbox "Define segements by face colors"
- use a Surface deviatiation of 0.1 mm or any other which would you like to have
- click on "OK"
- I only get one mesh ?! Shouldn't there be three meshes according to the colors or are these segments inside the new mesh. If they are inside how to make them visible?!
- If I export the mesh to object and reimport I still have one mesh after reimport.
OS: Debian GNU/Linux 8.5 (jessie)
Version: 0.17.8383 (Git)
Build type: Unknown
Hash: eac69724aab11e0dc872c6bc2508ad12f5047234
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
cyclone--colors.fcstd
(10.65 KiB) Downloaded 25 times
Site Admin
Postby wmayer » Thu Sep 08, 2016 8:29 am
Not yet at this time. Here it internally just creates the segments and when exporting it as obj they are used to achieve the grouping.
When running this snippet after creating the mesh it reports "3":
App.ActiveDocument.ActiveObject.Mesh.countSegments()
At this point you can create the sub-meshes with:
mesh=App.ActiveDocument.ActiveObject.Mesh
for i in range(mesh.countSegments()):
    Mesh.show(mesh.meshFromSegment(mesh.getSegment(i)))
This is supposed to work. Since the segments are created I guess there must be a bug that they are not used for the obj export. I will have a look...
Site Admin
Postby wmayer » Thu Sep 08, 2016 10:01 am
For the moment you have to use the export function from the Mesh menu. The general export doesn't support this at the moment.
Site Admin
Postby wmayer » Thu Sep 08, 2016 11:34 am
bernd
Postby bernd » Thu Sep 08, 2016 3:44 pm
@werner: :D
For others:
- click on "OK"
- select the new Mesh in TreeView --> Menu File Export --> export to object format
- reimport into FreeCAD will create 3 meshes which fit together at the vertices
(10.65 KiB) Downloaded 30 times
cyclone9.obj
(9.68 KiB) Downloaded 30 times
cfdfoundation
Postby cfdfoundation » Tue Sep 13, 2016 1:47 pm
This does split the boundary regions into separate sets of grouped faces, but each group is named "Group". Is it possible to assign an index within the group name, ideally for our usual naming convention of "patch", it would be: patch0, patch1, ... patchN
Thanks, Chris
Site Admin
Postby wmayer » Wed Sep 14, 2016 7:09 pm
bernd
Postby bernd » Thu Sep 15, 2016 4:23 am
cyclone10.obj
(9.69 KiB) Downloaded 34 times
