export to obj with groups and same mesh
Moderator: oliveroxtoby
cfdfoundation
Re: export to obj with groups and same mesh
Postby cfdfoundation » Thu Sep 15, 2016 12:07 pm
I tested the latest and it worked for me, adding unique names patch0, patch1, etc. The surface is closed, all is fine. Overall this provides a simpler, more robust way of labelling regions of the surface in the obj file than the earlier approaches. It is really great, thanks, it gives us something we can promote in conjunction with meshing in OpenFOAM.
The only possible improvement is if the user can specify their own group names, rather than using defaults patch0, patch1, etc. I guess that would mean somehow "attaching" them to the colour selection. It would be interesting to know if that is unrealistic based on the underlying code.
Again, thanks (wmayer, bernd) for putting this into FreeCAD, it is appreciated.
Site Admin
Postby wmayer » Thu Sep 15, 2016 12:34 pm
I would just leave the default names patch0, ... when creating the mesh and then offer a function in the mesh workbench where these names can be changed.
bernd
Postby bernd » Thu Sep 15, 2016 1:43 pm
Does it mean the segments off the mesh have names in FreeCAD mesh data structure already? I thought the names where given to the segments (groups) during export.
Site Admin
Postby wmayer » Thu Sep 15, 2016 2:02 pm
Yes.
On export a new mesh is created. If the selected mesh feature already has segments then they are copied over to the new mesh. If not then the whole mesh is added as segment and its label is used as group name.
bernd
Postby bernd » Thu Sep 15, 2016 2:46 pm
Yes.
But there is no python API to neither read or write the name off a segment. Or at least I could not found a method which returns the name?!
Site Admin
Postby wmayer » Thu Sep 15, 2016 3:35 pm
The naming of segments and the flag to mark them for export is something that has been added recently. The Python API hasn't been adjusted.
Postby Kunda1 » Thu Dec 14, 2017 10:49 am
Shall we open a feature Request in the tracker?
bernd
Postby bernd » Thu Dec 14, 2017 12:19 pm
IMHO: As long as noone explizit ask for it no.
pupoSDC
Postby pupoSDC » Thu Apr 05, 2018 9:42 am
Hello all,
I'm currently struggling with this issue, and I'm still unable to achieve the single mesh with multiple groups .obj file.
For my particular case, I have a wing.obj file with a single group, that I need to split into 3 different groups. So far I've been able to split the original .obj into 3 different .objs, but if I try to export them all together only one group is created. I've also tried to convert the .obj into a solid object, and using the colour hack, convert it back into a mesh. But this does not work either since the checkbox to "Define segments by face colors" does not show up, and the end result only has 1 group.
I'm running free cad v0.16 on ubunto 17.10.
Any help would be very welcome.
Jee-Bee
Postby Jee-Bee » Thu Apr 05, 2018 12:32 pm
First start with 0.17 and second https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
