Test request: OpenFOAM solver for FemWorkbench
Moderator: oliveroxtoby
qingfeng.xia
Postby qingfeng.xia » Sun Sep 04, 2016 10:49 pm
update: 25/12/2016, I back to forum and dev for a very very busy winter, I see some dev work on FluidMaterial and Gmsh from several devers
I hope contribution can be merge to my https://github.com/qingfengxia/Cfd.git repo, so open source strength is united.
I will upload my work on compressible and thermal solver , although it is not tested fully, to avoid duplicate work from other devers.
as branch of https://github.com/qingfengxia/Cfd.git
update: 01/10/2016: openfoam related code has been moved to a CFD module:
please `git clone https://github.com/qingfengxia/Cfd.git`
update: 16/09/2016 It is decided a new python module "Cfd" will be developed, depending on Fem. cpp code will be commit to Fem
===========collaboration strategy==========
Cfd is still under testing and dev, it will not be ready to be included into official in the next 6 m.
Currently route I can imagine:
CFD workbench new developers fork official FreeCAD and my Cfd githttps://github.com/qingfengxia/Cfd.git.
Cfd workbench depends on Fem for meshing and boundary(FemConstraint) and post-processing, most of them are coded in C++ so it is hard to split from Fem. If you need add feature on above, you branch FreeCAD official, not mime (but do let me know, pull request will only accepted if it is fully discussed on forum and reviewed by other dev like Bernd, me). see my ebook on how to pull request. Any other cfd python code, do pull request me (my Cfd.git) e.g. I developed vtk mesh and result import and export feature, git directly to official Fem workbench.
User can install freecad-daily, and git update/install Cfd.git so all got updated code without pain for installation.
============outdated, use https://github.com/qingfengxia/Cfd.git please ========
update on 05/09/2016: on a free install compilation both GUI and text tests passed on ubuntu 16.04 + openfoam4
one commit: bugfix for missing files and spelling errors in CMakelists.txt
To https://github.com/qingfengxia/FreeCAD.git
0af2a2a..eee073f foambuilder1 -> foambuilder1
============end of outdated ==================
## Highlight for this initial pull:
1. Python code to run a basic laminar flow simulation is added
2. An independent python module, FoamCaseBuilder (LGPL), can work with and without FreeCAD to build up case for OpenFOAM
3. A general FemSolverControlTaskPanel is proposed for any FemSolver.
Code under Fem folder pass flake8 test, but FoamCaseBuilder is checked due to time limitation.
Code should be merged into master asap, to move to next stage dev.
## Limitation:
1. only laminar flow with dedicate solver and boundary setup can converge, and I suspect the the current meshing tool, netgen is not ideal for CFD, which needs very thin layer near wall. Please download my 2 test file to evaluate for this stage.
2. result can only be viewed in paraview. but possible to export result to VTK format then load back to FreeCAD. (it is implemented in Oct 2016)
## updated test procedure for Cfd module Dec 25, 2016
To test: you need to install several GPL software to run the test, There are 2 files can be downloaded ro quickly test the function
see details
https://github.com/qingfengxia/Cfd/tree ... aseBuilder
You may need to run the TestBuilder.py twice to get case built, reason maybe file download is not finished though runFoamCommand is a block operation.
https://www.iesensor.com/download/TestCase.unv and must be put into folder of FoamCaseBuilder/
Test FoamCaseBuilder module without FreeCAD: "python pathto/FoamCaseBuilder/TestBulderer.py"
Test with FreeCAD by download: https://www.iesensor.com/download/TestFoam.fcstd, this file may outdated!!!
more procedure could be found at https://github.com/qingfengxia/Cfd/tree/master/
to test this fork, you need to start FreeCAD in gmome-terminal, not from window manager! in order to source all env var in ~/bashrc
you need to run the case in console terminal, because it takes too long to converge, it is not a good idea to wait in FreeCAD GUI.
## Roadmap for OpenFOAM
https://github.com/qingfengxia/Cfd/blob ... Roadmap.md
FreeCAD FoamCaseBuilder.png (240.33 KiB) Viewed 2505 times
Last edited by qingfeng.xia on Tue Dec 27, 2016 1:39 pm, edited 13 times in total.
Ubuntu LTS 64bit in virtualbox, always work with latest FreeCAD git version
Mainly work on OpenFOAM + Fenics for CFD, FSI
makkemal
Re: Test request: OpenFOAM solver for FemWorkbench
Postby makkemal » Mon Sep 05, 2016 4:40 am
Hi qingfeng
I have been looking forward to testing this :D
Do you know this function in foam before you start coding the result import in Freecad.
http://openfoamwiki.net/index.php/Polyh ... generation
By using polyhedral s as default will increase open-foam accuracy
bernd
Postby bernd » Mon Sep 05, 2016 4:49 am
bitacovir
Postby bitacovir » Mon Sep 05, 2016 6:34 am
makkemal wrote:Hi qingfeng
Yes. OpenFOAM has its own system of meshing. Maybe it would be a better strategy to use it, like other programs that works as graphical interface of OpenFOAM:
https://www.ods-engineering.com/tools/o ... /download/
http://engys.com/products/helyx-os
::bitacovir::
My Blog
Mini Airflow Tunnel Project
makkemal
Postby makkemal » Mon Sep 05, 2016 9:06 am
https://github.com/qingfengxia/FreeCAD/ ... ambuilder1
On this branch I get it compiled but get this error when starting the FEM workbench.
No module named _CommandSolverFoam
bernd
Postby bernd » Mon Sep 05, 2016 9:10 am
makkemal wrote:https://github.com/qingfengxia/FreeCAD/ ... ambuilder1
Same here.
I assme this is because the modules where only added to src/Mod/Fem/CMakeLists.txt ( https://github.com/qingfengxia/FreeCAD/ ... ts.txt#L84 ) and not to src/Mod/Fem/App/CMakeLists.txt ( https://github.com/qingfengxia/FreeCAD/ ... ts.txt#L73 ) They need to be added to both CMakes.
bernd
qingfeng.xia
Postby qingfeng.xia » Mon Sep 05, 2016 12:02 pm
Sorry, Guys, there are bugs in my Fem/App/CMakeList.txt, and spelling error in Fem/Cmakelist.txt, as you have pointed out. I forget to install file list here. I tested it without installation, it always makes some inconvenience for tester.
It will be soon fixed today. I got error in fresh pc rebuild. cmake , MedFile,
to fix it: Fem/Cmakelists.txt FoamCasebuilder -> FoamCaseBuilder
copy the file list to App/Cmakelists.txt. it should fixed.
Same here.
bernd
bernd
Postby bernd » Mon Sep 05, 2016 12:15 pm
qingfeng.xia wrote:Sorry, Guys, there are bugs in my Fem/App/CMakeList.txt, and spelling error in Fem/Cmakelist.txt, as you have pointed out. I forget to install file list here. I tested it without installation, it always makes some inconvenience for tester.
You may rebase on master (you are a 160 commits behind). Your branch rebases on FreeCAD master without any problems.
makkemal
Postby makkemal » Tue Sep 06, 2016 5:30 am
I can compile and start the workbench now, however I cannot add a Openfoam solver to Freecad.
If I load the test file you provided the openfoam solver cannot be opened ?
  File "/home/makke/freecad/Mod/Fem/CfdSolverFoam.py", line 34, in <module>
    import CfdSolver
  File "/home/makke/freecad/Mod/Fem/CfdSolver.py", line 31, in <module>
    from FoamCaseBuilder import supported_turbulence_models
  File "/home/makke/freecad/Mod/Fem/FoamCaseBuilder/__init__.py", line 27, in <module>
    from .utility import *
  File "/home/makke/freecad/Mod/Fem/FoamCaseBuilder/utility.py", line 80, in <module>
    _FOAM_SETTINGS = {"FOAM_DIR": _detectFoamDir(), "FOAM_VERSION": _detectFoamVersion()}
  File "/home/makke/freecad/Mod/Fem/FoamCaseBuilder/utility.py", line 74, in _detectFoamVersion
    return tuple([int(s) for s in foam_ver.split('.')])
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
Ubuntu 16.04
Openfoam 4
PyFoam installed
makke@ubuntu:~$ simpleFoam -help
Usage: simpleFoam [OPTIONS]
options:
  -case <dir>       specify alternate case directory, default is the cwd
  -noFunctionObjects
                    do not execute functionObjects
  -parallel         run in parallel
  -postProcess      Execute functionObjects only
  -roots <(dir1 .. dirN)>
                    slave root directories for distributed running
  -srcDoc           display source code in browser
  -doc              display application documentation in browser
  -help             print the usage
Using: OpenFOAM-4.0 (see www.OpenFOAM.org)
Build: 4.0-665f1db4c1f1
qingfeng.xia
Postby qingfeng.xia » Tue Sep 06, 2016 9:13 am
makkemal wrote:I can compile and start the workbench now, however I cannot add a Openfoam solver to Freecad.
    import CfdSolver
Ubuntu 16.04
Openfoam 4
PyFoam installed
Thanks very much for your testing.
It seems you got OF installed correctly, please try: bash -i -c "echo $WM_PROJECT_VERSION" in your terminal.
also you can open utilty file and define _detectFoamVerson(): to single line just `return _DEFAULT_FOAM_VERSION`, to carrry on the testing.
def _detectFoamVersion():
    #foam_ver = subprocess.check_output('bash -i -c "echo $WM_PROJECT_VERSION"')
This is the original code:
    proc = subprocess.Popen('bash -i -c "echo $WM_PROJECT_VERSION"', stdout=subprocess.PIPE, shell=True)
    (foam_ver, err) = proc.communicate()
    if foam_ver:
    else:
        print("""environment var 'WM_PROJECT_VERSION' is not defined\n,
              fallback to default {}""".format(_DEFAULT_FOAM_VERSION))
I may need more validation on subprocess version, `if foam_ver:`
an try and expect could be used, maybe
