Test request: OpenFOAM solver for FemWorkbench
Moderator: oliveroxtoby
makkemal
Re: Test request: OpenFOAM solver for FemWorkbench
Postby makkemal » Tue Sep 06, 2016 9:20 am
@qingfeng.xia please try: bash -i -c "echo $WM_PROJECT_VERSION" in your terminal.
makke@ubuntu:~/freecad$ bash -i -c "echo $WM_PROJECT_VERSION"
4.0
Updated snippti does not change things.
OS: Ubuntu 16.04.1 LTS
Version: 0.17.8378 (Git)
Build type: Unknown
Branch: foam/foambuilder1,origin/rtd_hindlemp
Hash: 1024ed5f777c0cf18a3186e2aaac271c1023e5e7
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
bernd
Postby bernd » Wed Sep 07, 2016 2:04 pm
I have been browsing your code. Correct me if I'm wrong. You are not integrating in FEM module of FreeCAD at all. All your CFD is like an own module inside the FEM module, like a parallel world of FEM in FEM module. Why would you like it to see it inside the FEM module?
Have you ever been thinking of making an own CFD module. From an own module you could still access all Fem objects. You could still add the constraint objects to the FEM module code because they are based on FEM constraints. But the whole Workflow of writing CFD input file running the solver and reading the input files would be in CFD module. With this you are totally independent from FEM module. Since your code does not integrate and does not use any of FEM python modules it could makes sense.
I do not know if it make sense to have multiple module workflows in one module?!
May be some more opinions of FreeCAD cracks are needed?!
cheers bernd
qingfeng.xia
Postby qingfeng.xia » Wed Sep 07, 2016 5:26 pm
4.0
I mean try this snippet:
def _detectFoamVersion():
    return _DEFAULT_FOAM_VERSION
Also, I tried both python3 and python2 on the following, it seems subprocess output differently
from __future__ import print_function
import subprocess
_DEFAULT_FOAM_VERSION = (4,0,0)
#https://docs.python.org/2/library/subprocess.html
    #foam_ver = subprocess.check_output('bash -i -c "echo $WM_PROJECT_VERSION"')
    proc = subprocess.Popen('bash -i -c "echo $WM_PROJECT_VERSION"', stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
    (foam_ver, err) = proc.communicate()
    if foam_ver: print("stdout:", foam_ver)
    if err: print("stderror:", err)
    if foam_ver:
        print("echo output:", foam_ver)
        return tuple([int(s) for s in str(foam_ver).split('.')])
    else:
        print("""environment var 'WM_PROJECT_VERSION' is not defined,
              fallback to default {}""".format(_DEFAULT_FOAM_VERSION))
print(_detectFoamVersion())
python3 return
b'4.0\n'
python2 return:
4.0
Ubuntu LTS 64bit in virtualbox, always work with latest FreeCAD git version
Mainly work on OpenFOAM + Fenics for CFD, FSI
qingfeng.xia
Postby qingfeng.xia » Wed Sep 07, 2016 5:37 pm
bernd wrote:I have been browsing your code. Correct me if I'm wrong. You are not integrating in FEM module of FreeCAD at all. All your CFD is like an own module inside the FEM module, like a parallel world of FEM in FEM module. Why would you like it to see it inside the FEM module?
cheers bernd
Yes, CFD is parallel with FEM in python level, but cpp code are shared. I may have some special requirement on meshing. They are of different physical domain, in the future we could dome some FEM and CFD coupling analysis. I may also need to share post-processing by VTK.
To make an independent CFD module could be possible, actually puting CFD function in FEM workbench, sounds a bit misleading. However, I am not sure it is worth of splitting, only a few python files. I will wait and see more suggestion.
Thanks
makkemal
Postby makkemal » Wed Sep 07, 2016 6:45 pm
This does work.
I have to start the simpleFoam command manually in the command line.
simpleFoam -case /tmp//TestCase > /tmp//TestCase/log.simpleFoam
How do I view results in paraview ?
sgrogan
Postby sgrogan » Wed Sep 07, 2016 10:05 pm
qingfeng.xia wrote:I do not know if it make sense to have multiple module workflows in one module?!
I vote for more modular is more better.
Now it seems not to matter, but in the future if the dependencies diverge it would be beneficial to tweak the build. Since the SMESH upgrade, everyone here knows my problems with Netgen on Win, but there are also issues with VTK and libmedC-dev on some Linux distros that extend beyond FEM into the Mesh WB, that effects the 3D printing crowd.
I'm not a developer, only a package manager, but the more independent the better. If CFD is split now FEM would be a dependency of CFD, ideally they could share a computational engine and a post processing engine.
All that said, FreeCAD's computational ability is great. In most solvers the geometry portion is an after thought, which makes it hard for the user. FreeCAD is much simpler for the user.
Keep up the great work :D
qingfeng.xia
Postby qingfeng.xia » Thu Sep 08, 2016 8:24 am
makkemal wrote:
This does work.
Great to hear that, start in new terminal since CFD takes ages to converge, several days is common for us.
May be QProcess instead Popen, to get the solver exit signal , could be a better choice, I will look at QProcess, to see if that is portable to Qt5 and Python3.
 paraFoam -case /tmp/TestCase
If you are familar with paraview, you can build up the pipe line, paraview is not quite straight-forwards.
I am think about writing @CfdResultObject.py@ and CfdReaderVTK.py to show Temperature, Pressure and Velocity using current facility in FEM.
qingfeng.xia
Postby qingfeng.xia » Thu Sep 08, 2016 8:32 am
Yes, they will share meshing render and post-processing. I list the possible route for split, please correct me.
1. Do you means create a CFD workbench? , that sounds challenging to me, I am not sure how to create Gui/Resource part, maybe I leave the icon still in Fem module (not sure as we did not specify icon path, but icon name),
2. then CMakeLists.txt, Init.py and InitGui.py should be make a pure python module?
3 . If I need the post-processing and creat-meshing command, can I just import from "_CommandFemMesh.py" or I must copy into new module?
4. I think I need a SelectionObserver python class.
5. To add new command MenuItem/ToolbarItem to workbench, I need to add into Fem/Gui/Workbench.cpp. Is that possible to add into InitGui.py now? Or I should make Cfd/Gui/ cpp files.
6. python ViewProvider file needs renaming, Fem->Cfd
more...
Thanks very much
bernd
Postby bernd » Thu Sep 08, 2016 9:52 am
qingfeng.xia wrote: 1. Do you means create a CFD workbench? , that sounds challenging to me, I am not sure how to create Gui/Resource part, maybe I leave the icon still in Fem module (not sure as we did not specify icon path, but icon name),
You could start the new workbench not in FreeCAD src but in your ./FreeCAD Mod directory in your home directory.With this you need just a few files to start. See https://github.com/berndhahnebach/FreeC ... aster/MyWB for my simple template for a new workbench in Mod directory of your ./FreeCAD folder in your home directory. It has just two simple tools. With this there is no Cmake needed, because no installation is needed.
Later if you would like to go for a PullRequest to integrate it in FreeCAD source you could add the Cmake stuff.
qingfeng.xia wrote:3 . If I need the post-processing and creat-meshing command, can I just import from "_CommandFemMesh.py" or I must copy into new module?
You can use any module and any object from any module in any other module. It just need to be available and of couse you need to import the module.
qingfeng.xia wrote:4. I think I need a SelectionObserver python class.
I have one small just for FEM you could import it. Arch has an own python selection observer class. Assambly2 has one too.
qingfeng.xia wrote:5. To add new command MenuItem/ToolbarItem to workbench, I need to add into Fem/Gui/Workbench.cpp. Is that possible to add into InitGui.py now? Or I should make Cfd/Gui/ cpp files.
Yes you could just add it to InitGui.py See my small template.
There are dozens of modules around which are installed in your user Mod. You could have a look at the code if you need something. One of the best is lattice2. I truelly can recomend installing it.
bernd
bernd
Postby bernd » Thu Sep 08, 2016 10:47 am
I vote for more modular is more better. ... I'm not a developer, only a package manager, but the more independent the better. If CFD is split now FEM would be a dependency of CFD, ideally they could share a computational engine and a post processing engine.
Good point, if CFD is integrated in FEM, FEM relies on CFD, means more depencies.
