Interesting project: DesignSPHysics fluid simulator
Moderator: oliveroxtoby
kwahoo
Re: Interesting project: DesignSPHysics fluid simulator
Post by kwahoo »
Reviving this old thread to share a small news for AMD users.
I converted the CUDA code to AMD HIP/ROCm, to perform calculations of AMD Radeon GPUs.
Code is here https://github.com/kwahoo2/DualSPHysics
Performance difference is quite noticeable, testing the 01_DamBreak:
CPU, Ryzen 7 1700:
real 50m35,257s
user 749m2,203s
sys 0m14,726s
GPU, Radeon 6600XT
real 4m55,682s
user 6m55,447s
sys 0m6,649s
https://github.com/DualSPHysics/DualSPHysics/issues/3
ROCm runs on Linux and AMD Radeon Vega, CDNA and RDNA2 GPUs.
https://rocmdocs.amd.com/en/latest/Curr ... Notes.html
Post by Kunda1 »
https://twitter.com/z_Joker/status/1567168370524540932
A spillway simulated using DualSPHysics workbench
Published on Twitter (link in caption)
M4mina
Post by M4mina »
I have played with it. It is very promising but the problem is the boundaries. It is not easy to define inlets and outlets with velocitoes and pressure values.
It best fit for spillway or waves on shore.
Actually this spillway is my work and i posted it on twitter ) interesting
Post by Kunda1 »
M4mina wrote: Fri Oct 14, 2022 6:18 pm I have played with it. It is very promising but the problem is the boundaries. It is not easy to define inlets and outlets with velocitoes and pressure values.
Is there a possibility to improve this limitation? Do the DesignSPHysics devs know ?
M4mina
Post by M4mina »
@Kunda1
I haven't contacted the team, but it has futuristic capabilities such as FSI. I believe it is developed for shore applications. Maybe i will try to contact the Manchester university prof when i move near there.
Still thinking of attending their next workshop but no support from my company :)
Post by Kunda1 »
@M4mina if you see functionality in that workbench that improves FreeCAD operations (not relevant necessarily to designsphysics subject matter, please feel free to comment on it. I notice that some of these specialized workbench find workarounds and improve functionality of FreeCAD like 3rd party software installations and UI/UX improvements. But the issue is that these refinements don't feedback in to the FreeCAD master. So it would be great to have liasons between these 3rd party workbench developers (the ones that aren't active in the FC community) and the FC community and developers. It's an invitation more than anything.
thschrader
Post by thschrader »
Collapse of the Aquadom-Aquarium in Berlin at 16.12.2022.
The little red cubes are people for scale. Aquadom contains 1 million Liters.
Sounds a lot, but the effect doesnt look very dramatic.
The Aquarium is built around an inner elevator.
Here is the first tutorial I found about using inlet-/outlet definition in DesignSphysics macro for FC:
https://www.youtube.com/watch?v=AqxzzF9REcw
thschrader
My first attempt to simulate a NACA2412 hydrofoil.
Waterdepth 1,3 m, foil is located 300 mm below surface.
Inlet speed 2,6 m/s, equals 5 knots.
312000 particles, distance 5 mm, physical simulation time 3 sec.
chord-length profile 500 mm. 2D-case.
Runtime 40 min on Nvidia Geforce RTX2060 GPU.
The hydrofoil "sucks down" the waterlevel in the wake.
After a while I get these weird artefacts at the bottom of the inlet.
Based on this tutorial:
case-files:
CaseNACA2412_2D.zip
(264.22 KiB) Downloaded 39 times
thschrader
It is more realistic to move the wing, not the fluid.
Wingspeed 2m/s.
Next steps:
-more particles for better wing resolution
-full 3D-case hydrofoil
