Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
- Crossleyuk
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Sorry, files did not load.
- oliveroxtoby
This happens when "Use value from boundary" is chosen in the "InitialiseFields" object, but a valid boundary has not (yet) been selected. Simply double-clicking the "InitialiseFields" object should automatically choose the first suitable boundary ("inlet" in this case); click OK and all should be well. The run then fails since this is an inviscid analysis with prescribed pressure drop - changing to viscous will fix that.Crossleyuk wrote: ↑Mon Sep 13, 2021 3:56 pm Started a very simple model to checkmy recollections but get the same Runtime Error : No boundary selected to copy initial pressure value for my complex historic model and this simple one:
- Crossleyuk
HaHa, fantastic to be back pestering you Oliver, thank you !
- Crossleyuk
Oh dear, here I am again. All great after youre help but I now get this after 35 seconds:
Processor 0: field transfer
12:12:56 Processor 1: field transfer
12:12:56 Processor 2: field transfer
12:12:56 Processor 3: field transfer
12:12:56
End
12:12:57 ./Allrun: line 9: mpiexec: command not found
Sorry and thanks again.
Michael
12:12:56
End
Michael
- oliveroxtoby
It looks like MPI is not installed. If you are on Windows, try reinstalling OpenFOAM and make sure you answer 'yes' to installing MSMPI if asked. Running the installer as Administrator might help. If you don't get any joy with the OpenFOAM Windows installer, you could try BlueCFD instead.Crossleyuk wrote: ↑Tue Sep 14, 2021 11:21 am Oh dear, here I am again. All great after youre help but I now get this after 35 seconds:
12:12:56
End
Michael
Please provide all the information requested in this post before reporting problems with CfdOF.
- Crossleyuk
I reinstalled with no solution and then uninstalled and reinstalled blueCFD and OpenFOAM. During reinststall I was told that MPI was not installed and now get a differnt failure respoinse from the model. I started with blueCFD-Core-2020-1-win64-setup and then tried blueCFD-Core-2017-2-win64-setup. No difference.
Regards
Michael
1. Uninstall bluecfd
2. Goto "Apps and Features", check for remaining mpi. If so, uninstall via "Apps and Features"
3. Reboot system
4. Install bluecfd, newest version https://bluecfd.github.io/Core/Downloads/
Works for me.
3. Reboot system
Works for me.
- Crossleyuk
Still problems Oliver,
I have unistalled and reinstalled three times with no reported problems.
Michael
Michael
Can you run this testcase?
- Crossleyuk
Hi thschrader,
No, I get the same "simulation exit with error" but with no "./Allrun: line 9: mpiexec: command not found"
Michael
Michael
