Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
bernd
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Postby bernd » Wed Jan 24, 2018 7:10 pm
Which constraint do you like to apply. We may could do a hack, just to get it useble to make this example?
thschrader
Postby thschrader » Wed Jan 24, 2018 8:38 pm
bernd wrote:
Wed Jan 24, 2018 5:00 pm
I would just be speed up things a lot if we would only display one arrow per face, but this can not be adjusted ATM.
Lets colour the faces, no 3D-arrows. Mhh...lets say when thre are more than 100 faces to display...
polymer
Postby polymer » Thu Jan 25, 2018 5:08 am
I think a combination whould be good, color to Show which Face belong to the contrain and a Limited number of arrows.
TT-RS
Postby TT-RS » Tue Feb 06, 2018 6:14 pm
For me, it is the most interesting workbench in FC, very interesting and promising.
oliveroxtoby
Postby oliveroxtoby » Fri Feb 09, 2018 8:58 am
Thank you for the support! :-)
Please provide all the information requested in this post before reporting problems with CfdOF.
sket
Postby sket » Sun May 13, 2018 10:23 am
hello, I'm trying to add the workbench, when I check the dependencies I have this result:
Checking dependencies...
Paraview executable paraview not found in path.
when I installed OpenFoam, this install also Paraview. I found the folder of Paraview in /opt.
what should I do? how should I proceed?
edit: please some help.
oliveroxtoby
Postby oliveroxtoby » Fri Jun 08, 2018 12:19 pm
Sorry - missed this post. The easiest way would be to add a symlink to the paraview executable to one of the bin directories in your path - say /usr/local/bin - with a command like
ln -s /opt/paraview/bin/paraview /usr/local/bin/paraview
sket
Postby sket » Sat Jun 09, 2018 5:09 pm
thank you Oliver!
Crossleyuk
Postby Crossleyuk » Tue Jan 15, 2019 6:06 am
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
I am relatively new to FreeCAD (six months) but can now use it reasonably well after great support from the Forum. I am now looking to move forward into a piece of research (MPhil) and need to use CFD, so CfdOF has been a fantastic start.
I have it all up and running and started with the initial "Elbow" tutorial after going through the Read Me.
CFD Tutorial 1 - Elbow Rev 2.FCStd
(340.26 KiB) Downloaded 19 times
I am also seeing different dialogues to those illustrated in the turorial with failures as indicated by this dialogue:
Elbow Tutorial Mesh Response - Rev P1.PNG (23.21 KiB) Viewed 756 times
And others saying:
Response after start of Meshing
0.0: Starting meshing ...
0.1: Exporting mesh region data ...
0.4: Exporting the part surfaces ...
0.5: Running gmsh ...
7.5: ./Allmesh: line 6: [: too many arguments
7.7: tee: log./c/Program: No such file or directory
7.7: tee: Files/FreeCAD: No such file or directory
7.7: tee: 0.17/bin/gmsh.exe: No such file or directory
7.8: tee: log./c/Program: No such file or directory
7.8: tee: Files/FreeCAD: No such file or directory
7.8: tee: 0.17/bin/gmsh.exe: No such file or directory
26.6: Meshing completed[/color]
and
Response from Solver Run (3D Mesh)
0.0: Checking dependencies...
0.0: OpenFOAM case writer is called
0.9: Error writing case:
0.9: [Error 3] The system cannot find the path specified:'c:\\uappdata\\local\\temp\\meshCase\\constant\\triSurface/*.*'
0.9: Write case setup file failed
sers\\user\\
Sorry, very inexperienced in the Forum and don't understand what is going on here. Could you please direct me to some further assistance.
oliveroxtoby
Postby oliveroxtoby » Tue Jan 15, 2019 6:40 am
And others saying:
Could you update the workbench and check it again? I ran into the same issue recently and could have sworn I had fixed it. Let me know if that doesn't help.
