Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
Crossleyuk
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Postby Crossleyuk » Thu Jan 17, 2019 5:54 pm
Thanks again Thomas,
Yes, CFD_Tutorial_1_new.FCStd worked fine and I have the result:
Thomas CFD_Tutorial_1_new.FCStd Solver.PNG (125.47 KiB) Viewed 300 times
I must now try the Elbow again for myself and start to learn a lot more about what CfdOF can do for me and how to do it :roll: :lol:
Cheers man!!
Michael
Crossleyuk
Postby Crossleyuk » Thu Jan 17, 2019 5:56 pm
Great job guys, cant tell you how much I'm enjoying this.
Thank you so much!!!
Michael :P
Crossleyuk
Postby Crossleyuk » Mon Jan 21, 2019 10:13 am
Sorry Guys,
First of all, thanks for the help again and now it is clear that I had drawn the entire sketch in the wrong orientation an the as you suggested Oliver the axies were incorrect. Yet another dumb moment on my part.
Okay, now the strange bit again. As you will have seen when I used your new corrected case Thomas it worked great and I started the Paraview tutorial excited.
However, I came back to it today and I'm getting the same failure again:
Thomas CFD_Tutorial_1_new.FCStd 2nd Try Fail.PNG (17.75 KiB) Viewed 265 times
You've been great an undertstand if I'm being slow but I'm confused big time.
Cheers guys,
Michael
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
oliveroxtoby
Postby oliveroxtoby » Mon Jan 21, 2019 12:14 pm
Did you restart your computer in between writing the mesh and trying to run the solver? If you, the temporary directory might have been erased. Returning to the mesh panel and re-creating the mesh should solve that. Also, you can change the directory where the case files are written in the CFD preferences, if you want to avoid the temp directory.
Crossleyuk
Postby Crossleyuk » Mon Jan 21, 2019 4:43 pm
Thanks Oliver, I'll take a cloer look at your suggestions.
Michael
thschrader
Postby thschrader » Tue Jan 22, 2019 7:43 pm
Have you set an explicit (existing) path for the case writer in Edit/Preferences/cfd?
After doing this, the meshcase and case folder should allways located there.
For me it works.
Crossleyuk
Postby Crossleyuk » Wed Jan 30, 2019 10:05 am
Okay Thomas, thanks again and all agreed with your suggestions. I now realise that I must re-mesh before running the iterations, so yet another learning step. Thank you again.
Now please tell to "give up" (to put it politely) if I'm being a pain but I had a thought of ensuring I had things understood. So I went back to my original case and went through it again ensuring that I had repeated all the items in the case you sent to me that was working fine. Of cours my change in axis and plain selection for the original sketch ment I had to correct my Inlet velocity axies. So after checking everything was in agreement with your case again I ran my modified case immediately after running yours and got exactly the same result.
So all seamed fine but when I saved my case and re-loaded it failed, after making all the checks again and re-meshing etc:
CFD Tutorial 1 - Elbow Rev P3 After Changes Fail.PNG (24.74 KiB) Viewed 135 times
Again sorry but I really thought I'd solved my problem with your help.
Cheers
Michael
OCC version: 7.2.0
oliveroxtoby
Postby oliveroxtoby » Wed Jan 30, 2019 10:24 am
Did you by any chance give one of your boundary conditions a numeric name? (They should all be alphanumeric, start with a letter, and contain no spaces.) This would cause confusion to OpenFOAM, and unfortunately we haven't had time for such niceties as checks on the legality of naming :-/
Crossleyuk
Postby Crossleyuk » Wed Jan 30, 2019 11:08 am
Hi Oliver,
Yet again I'm very impressed and grateful for your efforts and support. After checking the boundary naming I realised that I had used a space in four boundary names, eg, "Input 1". I removed all the spaces and it has worked fine now.
Bloody marvellous, as we say here in England :lol:
Cheers man!! 8-)
Michael
thschrader
Postby thschrader » Wed Jan 30, 2019 8:56 pm
Dont hesitate to put questions in the FC-forum.
Sometimes the answers are rough, but in the end we solve the problem.
regards Thomas :)
