Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
oliveroxtoby
Re: Fork of CFD workbench
Postby oliveroxtoby » Wed May 10, 2017 12:02 pm
makkemal wrote:When can we have this available via "addon manager" ?
The name has now and directory has now changed
Soon. We wanted to wait until we have a decent pre-requisite checker, so that a user who installs it via the addon manager and tries to run it without first having installed necessary dependencies, will at least get a helpful error message. This is in the works right now, together with cut-cell Cartesian meshing / boundary layers!
Please provide all the information requested in this post before reporting problems with CfdOF.
Postby Kunda1 » Wed May 10, 2017 12:28 pm
oliveroxtoby wrote: We wanted to wait until we have a decent pre-requisite checker, so that a user who installs it via the addon manager and tries to run it without first having installed necessary dependencies, will at least get a helpful error message. This is in the works right now
A pre-requisite checker would be a helpful tool for FreeCAD in general, I believe. Maybe it's worth making a FC wide function that can do this for plugins in general?
It would help working towards realizing issue #857
yorik wrote:ping
Edit: clarity + added ticket reference
Postby Kunda1 » Sat May 13, 2017 11:53 am
oliveroxtoby wrote:ping
I've also opened a ticket on FreeCAD-addons
https://github.com/FreeCAD/FreeCAD-addons/issues/29
That we might as well think of the logic needed to implement this for all of FC.
wafi
Postby wafi » Wed May 17, 2017 9:21 am
impressing work :D
I have two different problems:
Windows installation:
FreeCAD 0.17 Rev No 11091
the icons in the CfdFoam bench will not be shown
Solved, simple ... the extracted zip file called the workbench CfdFoam-master, renaming into CfdFoam and the problem is solved.
Linux installation
OS: Ubuntu 16.04.2 LTS
Version: 0.17.11090 (Git)
Build type: None
Hash: 4d7554197ee622ac5a4b709aa4205989e54484f3
Python version: 2.7.12
OCC version: 7.1.0
I am not able to call openfoam solver. Error message: OpenFOAM installation directory not found
In the bashrc the source is added with: source /opt/openfoam4/etc/bashrc
No problem to start i.e. simplefoam from terminal.
oliveroxtoby
Postby oliveroxtoby » Thu May 18, 2017 8:15 am
wafi wrote:impressing work :D
Linux installation
Build type: None
OCC version: 7.1.0
Thank you for testing!
Regarding the windows installation, for now I would suggest you install the prepackaged install at https://opensimsa.github.io/download.html, as some of the dependencies in the FreeCAD directory (as listed in the README file) need to be updated to work correctly.
I was unable to reproduce the problem in the Linux install, however as possible workaround, could you try adding the OpenFOAM install directory to preferences:
Choose Tools | Edit Parameters ... and navigate to:
Preferences | Mod | Cfd | OpenFOAM
and edit the Installation Path parameter. Set this to
/opt/openfoam4
in your case.
wafi
Postby wafi » Thu May 18, 2017 8:50 am
Hi Oliver
perfect! :D
This solved the problem:
/opt/openfoam4
Thank you for your assistance
Peter
Postby Kunda1 » Thu May 18, 2017 10:42 am
An aside: for better visibility of this thread do you mind putting OpenFOAM in the title and even perhaps spelling out what CFD means so it could show up better in searches etc... ?
wafi
Postby wafi » Thu May 18, 2017 9:20 pm
Hi Oliver
I have played a little bit today and I had several problems.
... meshing ... mesh region, for bigger meshes this will not work, or ... with my model it did not work, but in general it us unclear what you mean with the relative size, should it be read as percentage?
... material constants ... I do not know why, but i.e. placing "sea water" in, next edit it`s stated "None" with totally different figures.
I had several crashs of the system when using a big model, underwater area of a 12m sailing boat incl. keel and rudder in a box of 20m length, 10m width and 5m draft. I do not know if these crashs were based on evt wrong material inputs, but in general the crashes were when gnuplot showed app. 50 iterations, than gnuplot stopped and shortly after gnuplot stopps solver also stopped. Due to the size of the unv file I did not looked into the materials, so maybe it is something with gnuplot constants or material, I do not know.
Grummmel .. forgot to state
Version: 0.17.11104 (Git)
Build type: None
Hash: 1b2b964c35bd0f989f1f833a372c48e08cec0194
OCC version: 7.1.0
Worufu
Postby Worufu » Fri May 19, 2017 8:29 am
Amazing work! It works very well, it was time I'm searching of something like this, simple to set, easy to process and full open also for Windows. Congratulations again.
I try some test with wing simulation, it works good, but the parallel core feature doesn't work. Case writes data, Solver starts the calculation, but after a little time, about a 1/10 of single core simulation, it stops and tell me the simulation is solved.
However the iteration plot doesn't show any data and work only a thread of the various cpus I tested. Obviously the results are not calculated.
Am I missing something or is this feature not supported yet?
Tested both on Windows 7 and 10 with the same problem.
Version: 0.17.10432 (Git)
Hash: 84ac526f62b394dba749e3086b6787308d5c7702
Python version: 2.7.8
OCC version: 7.0.0
wafi
Postby wafi » Fri May 19, 2017 8:44 am
hm, I installed the updated files from your GitHub because I wanted to have the files update.
Now the writing process stop with the failure :
27.6: Command '['bash', '-c', 'source "/opt/openfoam4/etc/bashrc" && cd "/tmp/case" && ideasUnvToFoam "/tmp/case/case.unv" > log.ideasUnvToFoam 2>&1']' returned non-zero exit status 134
seems to be same problem as some posts ago.
In the output window, following is stated:
File "/home/peter/.FreeCAD/Mod/CfdFoam/FoamCaseBuilder/utility.py", line 633, in runFoamApplication
out = subprocess.check_output(cmd, env=env, stderr=subprocess.STDOUT, startupinfo=si)
File "/usr/lib/python2.7/subprocess.py", line 574, in check_output
raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command '['bash', '-c', 'source "/opt/openfoam4/etc/bashrc" && cd "/tmp/case" && ideasUnvToFoam "/tmp/case/case.unv" > log.ideasUnvToFoam 2>&1']' returned non-zero exit status 134
