Please could you upload your file for easier debugging?aruizreina wrote: ↑Sat Mar 20, 2021 1:09 am Hi,
Just landed to freecad and this workbench. After installing v0.19 and CfdOF I got results for the first case. But now, I have made a new geometry to solve a free surface case with water and air. However, when I write the case I get this error:
0.0: Error writing case:
0.0: AttributeError: 'FeaturePython' object has no attribute 'Phase'
0.0: Write case setup file failed
And after that, I cannot access previous data to revise it. I already installed freecad and workbench twice.
02:05:38 Traceback (most recent call last):
File "C:\Users\Antonio Ruiz Reina\AppData\Roaming\FreeCAD\Mod\CfdOF-9b2565821cfc4751f821026ef09eea4f2000fd33\CfdFluidMaterial.py", line 150, in setEdit
taskd = _TaskPanelCfdFluidProperties.TaskPanelCfdFluidProperties(self.Object, physics_model)
File "C:\Users\Antonio Ruiz Reina\AppData\Roaming\FreeCAD\Mod\CfdOF-9b2565821cfc4751f821026ef09eea4f2000fd33\_TaskPanelCfdFluidProperties.py", line 56, in __init__
self.createTextBoxesBasedOnPhysics()
File "C:\Users\Antonio Ruiz Reina\AppData\Roaming\FreeCAD\Mod\CfdOF-9b2565821cfc4751f821026ef09eea4f2000fd33\_TaskPanelCfdFluidProperties.py", line 67, in createTextBoxesBasedOnPhysics
if self.physics_obj.Flow == 'Incompressible':
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Flow'
I would appreciate any suggestion to fix it. Thanks in advance and congratulations on this script, it is a helpful tool to begin with OF.
Antonio
Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
- oliveroxtoby
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Of course, please find .FCStd and meshcase here:
https://www.dropbox.com/sh/zkeaacfry20s ... oh6Va?dl=0
Thanks in advance!
Thanks in advance!
You posted the backup-file...aruizreina wrote: ↑Sat Mar 20, 2021 11:13 am Of course, please find .FCStd and meshcase here:
Thanks in advance!
Ups... let's try again...
sorry
sorry
- ALI-ESPA.FCStd
- (103.71 KiB) Downloaded 115 times
- oliveroxtoby
The 'PhysicsModel' object has been moved outside the 'CfdAnalysis' group. Move it back in by dragging it onto 'CfdAnalysis'.
Note that you will also need to change the pressure initialisation to a constant value as potential initialisation is not supported for this solver.
After these changes the solver runs for me.
Oh, it runs!! so easy and so quick, no words. Thank you very much for your interest and help!
Hi everyone,
When I launch the analysis it works but I can't do the meshing part.
I receive the following message. I precise that I tried several paths too : /usr, /lib ...
OS: Ubuntu Core 20 (XFCE/xubuntu) . . . . . . . . .Word size of OS: 64-bit
Word size of FreeCAD: 64-bit . . . . . . . . . . . . . . . Version: 0.19.24276 (Git)
Build type: Unknown . . . . . . . . . . . . . . . . . . . . . Branch: releases/FreeCAD-0-19
Python version: 3.8.5 . . . . . . . . . . . . . . . . . . . . . Qt version: 5.12.8
Coin version: 4.0.0 . . . . . . . . . . . . . . . . . . . . . . . OCC version: 7.5.0
- bug.png (95.71 KiB) Viewed 5046 times
- oliveroxtoby
CfdOF is not finding your OpenFOAM installation. It needs to be installed separately. Take note of the install location for the version you install, and set the OpenFOAM install directory to this.Logry wrote: ↑Fri Apr 30, 2021 2:39 pm Hi everyone,
Did some calculations on the ingenuity-heli, using this model:
https://mars.nasa.gov/resources/25043/m ... -3d-model/
I tried to reconstruct the wing-profile from the obj-file.
Rotor-lift:
At 2400 rpm the wing segment in the middle moves with approx 75 m/s. At this speed
and this Angle of Attack the segment produces practically no lift.
heli-mass=1,8 kg, required lift on Mars approx 6,8 N (equals 680 gramm).
Sounds like nothing, but atmospheric density is only 0,015 kg/m^3 (earth 1,25 kg/m^3).
Rotor-imbalance:
How do they handle this?
At 2400 rpm a imbalance of 1/10 gramm at rotor-tip produces more than 3 N horizontal force.
Half of the heli-weight.
Energy:
Solar input at mars ground level approx 500 W/m^2.
Solar-panel area approx 640 cm^2. Efficiency 25%, gives power output of 10 Watt to reload accus.
Thats not much...
Rover:
Only one fixing at the gear, how is it balanced? Active control?
Rotor-lift:
Rotor-imbalance:
Energy:
Thats not much...
Rover:
- Crossleyuk
Hello again all,
OS: Windows 10 Version 2009
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
I'm returning after a very rough period and rebuilding of my notebook. Result was that I had to reinstall FreeCAD and CfdOF again and was expecting to be able to go back to my previous model and continue. I cannot get it to work in FreeCADD 0.19. All ssems to be installed and set up:
Started a very simple model to checkmy recollections but get the same Runtime Error : No boundary selected to copy initial pressure value for my complex historic model and this simple one:
Sorry trouble again and thank you
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
