Update on the development of the OpenFOAM CFD workbench (CFDOF)
Moderator: oliveroxtoby
thschrader
Re: Update on the development of the OpenFOAM CFD workbench (CFDOF)
Postby thschrader » Mon Oct 02, 2017 9:03 pm
Hello Oliver,
I tried to do the same simulation like the "flooding-tank" tutorial from Jozsef Nagy on YT.
(The tank is flooded with water against gravity, like a fountain. The result should look like
the picture below). The calculation allways stops after 30s with openFOAM fatal error.
Probably I do something wrong with the field initialization or my workflow is garbage.
Please have a look at the FC-file. After writing the case you will see in the alpha.water-dict,
that the inlet/outlet values are not assigned (like in the alpha.water from tutorial), there
is a "TODO" entry. The blue cube is the initialization-zone for water.
regards Thomas
(the error "out of scope" on the mesh in tree has no effect...)
testCFD.FCStd
(183.19 KiB) Downloaded 35 times
oliveroxtoby
Postby oliveroxtoby » Tue Oct 03, 2017 2:48 pm
I thought that the alpha initialisation zone would cause the inlet alpha value to be set to 1, but I see that it doesn't work out like that.
The alpha inflow value can now be set in the boundary condition, and a couple of bugs are fixed. Should work now.
testCFD.FCStd
(182.02 KiB) Downloaded 35 times
thschrader
Postby thschrader » Wed Oct 04, 2017 1:36 pm
@Oliver, short info
after updating CFDOF via addon-manager, close/restart FC:
try to mesh a cube. snappyhexMesh breaks,
gmsh/cfmesh works. system:
Version: 0.17.12284 (Git)
Hash: 2244292552c004e6b506af9e1e98d3423e524ee7
Python version: 2.7.8
OCC version: 7.1.0
oliveroxtoby
Postby oliveroxtoby » Wed Oct 04, 2017 2:47 pm
@Oliver, short info
Thanks - fixed.
Worufu
Postby Worufu » Fri Oct 06, 2017 10:07 am
Is it possibile to have the "volumetric flow rate" and "mass flow rate" also in outlet as in inlet?
oliveroxtoby
Postby oliveroxtoby » Mon Oct 09, 2017 7:48 am
At present the OpenFOAM boundary condition is only designed as an inlet (all three components of velocity are constrained); of course you can achieve much the same effect with the 'uniform velocity' outlet. If you would be interested, you could code up a new BC which allows users to specify mass flow rate and divides this by density and area to get the normal component of velocity.
Worufu
Postby Worufu » Tue Oct 10, 2017 3:38 pm
Thank for the information. It can be a good start to put me on coding in freecad. In your opinion is it possible to code all through python?
makkemal
Postby makkemal » Wed Oct 11, 2017 4:43 pm
believe this post is actually part of this thread
https://forum.freecadweb.org/viewtopic.php?f=18&t=24857
oliveroxtoby
Postby oliveroxtoby » Wed Oct 11, 2017 5:21 pm
Great! Yes, definitely possible in python.
oliveroxtoby
Thanks for the notification.
