gmsh Mesh refinement region
Moderator: oliveroxtoby
solosails
Postby solosails » Fri Mar 02, 2018 12:16 pm
I have been trying to mesh using gmsh, using a very simple cube inside a cube - the outer cube being the domain, and the inner cube being the part to check flow around.
I can make gmsh make an even 3D mesh of both of these objects by joining them as a compound - however, I need to refine the mesh around the object cube - no matter what I do, I always get an error , any advice how to refine a gmsh region using gmsh?
Started GMSH meshing ...
Part to mesh: Name --> Box, Label --> domain, ShapeType --> Solid
CharacteristicLengthMax: 86.6025403784
CharacteristicLengthMin: 0.0
ElementOrder: 1
ElementDimension: 3
c:\users\woody\appdata\local\temp\Box_Geometry.brep
c:\users\woody\appdata\local\temp\Box_Mesh_TmpGmsh.unv
c:\users\woody\appdata\local\temp\shape2mesh.geo
C:/Program Files/FreeCAD_0.17/bin/gmsh.exe
No mesh group objects.
No analysis members for group meshing.
Mesh regions, we need to get the elements.
File "C:\Users\Woody\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdMeshGmsh.py", line 174, in runMeshProcess
gmsh_mesh.get_group_data()
File "C:\Users\Woody\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdGmshTools.py", line 279, in get_group_data
ele_shape = FemMeshTools.get_element(shape, elems) # the method getElement(element) does not return Solid elements
File "C:\Program Files\FreeCAD_0.17\Mod\Fem\femmesh\meshtools.py", line 1454, in get_element
return part.Shape.getElement(element) # Face, Edge, Vertex
AttributeError: 'Part.Solid' object has no attribute 'Shape'
bernd
Re: gmsh Mesh refinement region
Postby bernd » Fri Mar 02, 2018 4:41 pm
have you read the first part of FEM_Shear_of_a_Composite_Block
Would you post your FreeCAD file?
oliveroxtoby
Postby oliveroxtoby » Sun Mar 04, 2018 9:16 pm
I can make gmsh make an even 3D mesh of bot of these objects by joining them as a compound - however, I need to refine the mesh around the object cube - no matter what I do, I always get an error , any advice how to refine a gmsh region using gmsh?
ElementOrder: 1
ElementDimension: 3
Could you try again? Fixed some bugs.
thschrader
Postby thschrader » Mon Mar 05, 2018 8:35 am
Updated cfd-of-wb via addon-manager, mesh refinement works, both cfd/fem.
@solosails: if you want to do a flow-simulation around the inner cube, you must
subtract the inner cube from the outer cube (part-wb: boolean-cut), not joining them,
as you wrote above.
system:
Version: 0.17.13346 (Git)
Hash: 22ee06de8441bfcc9fded2c6de4232d763fb11bc
Python version: 2.7.14
OCC version: 7.1.0
solosails
Postby solosails » Sun Mar 11, 2018 10:22 am
Hi all,
Thanks for the responses, and sorry for delay in reply. , I forgot to check the notification box on the post for replies.
I will try the suggested methods which (Boolean cut) sounds like wherebim going wrong!
Thanks again!
solosails
Postby solosails » Sun Mar 11, 2018 12:19 pm
Hi all, that solved it for me thank you!
Ps is there a way to add boundary layers using gmsh?
Thanks.
bernd
Postby bernd » Sun Mar 11, 2018 12:32 pm
the boundary layer of FEM can, but I do not know if CFD can use it?
oliveroxtoby
Postby oliveroxtoby » Sun Mar 11, 2018 2:35 pm
No, we haven't added this feature. We tend to favour CfMesh for CFD meshes so it's unlikely this will be added unless someone else does so.
bernd
Postby bernd » Sun Mar 11, 2018 3:17 pm
@oliver:
did you really copy the gmsh module from FEM? Why not just use the object from FEM ?
oliveroxtoby
Postby oliveroxtoby » Sun Mar 11, 2018 4:35 pm
@oliver:
Hi Bernd
In respect of gmsh, our code hasn't changed much from what was in the CFD workbench when we forked CfdOF from it. We haven't focused much at all on gmsh as we find the cut-cell Cartesian meshers better suited to our needs for CFD. Using the FEM object directly sounds like a much better plan, but will have to go to the to-do list, as it'll be difficult to prioritise for one of us. If someone else has time, then great! Thanks for the suggestion :)
Oliver
