Installation problems
Moderator: oliveroxtoby
tony271
Re: Installation problems
Postby tony271 » Sat Jun 23, 2018 7:31 pm
Problem update.
I tried same installation on a stand alone PC and got same problem.
I was able to install cfMesh only restarting windows in safe mode.
oliveroxtoby
Postby oliveroxtoby » Sun Jun 24, 2018 1:07 pm
Problem update.
Thanks a lot for the information.
I tried an installation on my wife's Windows 10 machine but was unable to reproduce the problem there :(
I'm not able to come up with any ideas as to what could be at fault.
Are you able to reproduce this problem easily, or does it no longer occur now that you have got it installed in safe mode? If you can reproduce, I could try adding some debugging information and ask you to run it on your system to give us some hints.
Please provide all the information requested in this post before reporting problems with CfdOF.
tony271
Postby tony271 » Tue Jun 26, 2018 6:18 am
I ' ll try it and post here any update.
tony271
Postby tony271 » Fri Jun 29, 2018 4:16 pm
I tried a new installation.
- hard disk reformatted
- installed last Windows release (Windows 10 Pro 64 bit, version 1803).
- installed FeeeCAD 0.17 revision 13522
- installed CFD
no problems detected.
oliveroxtoby
Postby oliveroxtoby » Sun Jul 01, 2018 8:33 am
- installed CFD
Thank you very much for going to all that effort! I guess we'll have to see if anyone else reports the problem, and see if we can gather any more info from them...
thschrader
Postby thschrader » Sat Jul 21, 2018 10:40 am
just updated the cfd-of-wb with addon-manager.
When activating the wb, I get an error.
system:
Version: 0.18.14098 (Git)
Hash: 0c33d00bfdf8270e7e5b33d792bf0ad9bbbfc819
Python version: 2.7.14
OCC version: 7.2.0
thschrader
Postby thschrader » Sun Jul 22, 2018 10:14 am
deleted line 65 in initGui.py:
cfd-of-wb starts.
meshing with cfmesh/shm works.
gmsh does not (which wonder...)
solver runs.
oliveroxtoby
Postby oliveroxtoby » Sun Jul 22, 2018 4:42 pm
cfd-of-wb starts.
solver runs.
Ah, sorry. That was an old import that should not be there. Not sure how that slipped through.
We've done quite a big refactoring of the meshing, allowing 2D meshes to be created now, but there are probably a few glitches. Unfortunately we have had to break backward file compatibility, so the mesh objects in saved files will have to be recreated. Don't think that's the problem here though.
Can you paste more text from the report view showing how the gmsh error begins? One can't conclude much from what is shown.
Thanks for the report.
Oliver
thschrader
Postby thschrader » Sun Jul 22, 2018 5:08 pm
Voila.
gmsh_report.txt
(3.86 KiB) Downloaded 17 times
cfdtest.FCStd
(20.83 KiB) Downloaded 16 times
oliveroxtoby
Postby oliveroxtoby » Sun Jul 22, 2018 8:40 pm
Voila.
gmsh_report.txt
cfdtest.FCStd
Thanks. Should be sorted now.
