Edit case issue
Moderator: oliveroxtoby
solosails
Edit case issue
Postby solosails » Tue Mar 13, 2018 9:49 am
Very very minor bug/request.
Windows 10 Latest build of freecad and CFDOF as of today.
When Clicking edit in the analysis control, the windows browser does not open the correct directory.
This is a very minor bug, but hopefully easy to change?
Thanks again for this awesome work!
oliveroxtoby
Re: CfdOF bug reporting
Postby oliveroxtoby » Wed Mar 14, 2018 6:29 am
Unfortunately I can't reproduce this. Seems to work fine for me on Win 7 & 10.
Thanks!
Please provide all the information requested in this post before reporting problems with CfdOF.
solosails
Postby solosails » Wed Mar 14, 2018 10:41 am
Hmm, for me, it always opens in My Documents.
solosails
Postby solosails » Wed Mar 14, 2018 1:59 pm
Thanks!
I think I may have found the problem, I was saving the case a couple of folders in, so B:\CFD\freecad\case - If I save it B:\CFD\case - it opens at the expected case folder.
oliveroxtoby
Postby oliveroxtoby » Wed Mar 14, 2018 3:26 pm
Made a change that might possibly have fixed this...
solosails
Postby solosails » Thu Mar 15, 2018 3:26 pm
Thanks for that - I'm afraid it is the same problem - however, I only updated the CFDof plugin inside freecad - would that update the file required?
thschrader
Postby thschrader » Thu Mar 15, 2018 4:42 pm
After updating workbenches via addon-manager, you must close/restart FC to get the changes done.
solosails
Re: Edit case issue
Postby solosails » Tue Mar 27, 2018 12:34 pm
No, it's still not opening the correct folder when a few folders deep - sorry!
oliveroxtoby
Re: Edit case issue
Postby oliveroxtoby » Tue Mar 27, 2018 2:06 pm
Could you check what happens if you go to Start | Run... and enter
explorer <case path>
solosails
Re: Edit case issue
Postby solosails » Wed Mar 28, 2018 12:51 pm
Sorry, not quite sure what you mean
