Edit case issue
Moderator: oliveroxtoby
Re: Edit case issue
If you mean as in the image, It opens at the correct file location
Could it be the fact that I am saving my cases on a different drive than the OS and the installation drive of Freecad and Openfoam?Re: Edit case issue
I do also get this message every time I open FreeCAD ...
Module: Part
Loading Part module... done
Loading Fem module... done
Loading GUI of Fem module... done
Init: Initializing C:\Users\Woody\AppData\Roaming\FreeCAD\Mod\Cfd... failed
File "<string>", line 120, in InitApplications
File "<string>", line 87, in <module>
File "<string>", line 34, in __init__
AttributeError: 'module' object has no attribute 'getModulePath'
During initialization the error 'module' object has no attribute 'getModulePath' occurred in C:\Users\Woody\AppData\Roaming\FreeCAD\Mod\Cfd\InitGui.py
Please look into the log file for further information
Re: Edit case issue
Ahhh, I just removed the CFD add on (original add on) leaving only CFDOF and now it seems to work fine!
Re: Edit case issue
Spoke too soon - it's opening in C/my documents again!
- oliveroxtoby
Re: Edit case issue
Yup, that's what I meant. This is the command that CfdOF executes to open the folder, so I am stumped.
Do you mean that it actually fixes the edit folder issue? I did not expect that...
Re: Edit case issue
Sorry, I thought it did, but tried a new case and have the same problem again - nevermind, it's not a big problem, thanks for looking into it!
Re: Edit case issue
This is the command I see when I click edit
Which is correct, but the window that opens is C:\Users\Woody\documents
Successfully wrote OpenFOAM case to folder B:/CFD/freecad/Newfolder
Please edit the case input files externally at: B:/CFD/freecad/Newfolder\case333
Re: Edit case issue
Ahhh, now, if I type in RUN
explorer B:/CFD/freecad/Newfolder\case333 (which is the address CFDOF is issuing) it opens up at my Documents ...
if I reverse the slashes as in we get the correct folder...
B:\CFD\freecad\Newfolder\case333
- oliveroxtoby
Re: Edit case issue
Great, thanks. Pushed an update that should fix that.solosails wrote: ↑Wed Mar 28, 2018 1:47 pm Ahhh, now, if I type in RUN
if I reverse the slashes as inwe get the correct folder...Code: Select all
Re: Edit case issue
Perfect, thank you! That appears to have solved it for me!oliveroxtoby wrote: ↑Wed Mar 28, 2018 1:55 pmGreat, thanks. Pushed an update that should fix that.solosails wrote: ↑Wed Mar 28, 2018 1:47 pm Ahhh, now, if I type in RUN
