(solved) DamBreak tutorial not running in FC
Moderator: oliveroxtoby
thschrader
Postby thschrader » Mon Jun 11, 2018 2:17 pm
Last weekend I wanted to demonstrate the cfd-wb to a friend,
with the openfoam dambreak tutorial. OF gave back an error
after a few seconds and I cant figure out what I am doing wrong. Month ago
it worked (with bluecfd-core 2016), but I have deleted the old files.
Interfoam-log says, that an entry is missing in fvsolutions dict.
Can someone have a look at my file? Thanks.
bluecfd: version 2017-2
mesher: cfmesh
freecad:
Version: 0.18.13824 (Git)
Hash: 73d597710fe15f1ee3453bf75c0f4f95c309764a
Python version: 2.7.14
OCC version: 7.2.0
loginterFoam.txt
(3.44 KiB) Downloaded 13 times
damBreakFC.FCStd
(280.98 KiB) Downloaded 24 times
thschrader
Re: DamBreak tutorial not running in FC
Postby thschrader » Mon Jun 11, 2018 2:52 pm
OK, I found a tip in the cfd-online forum.
I wrote the case again, then edit fvsolutions, simply putting
in the "pcorrFinal" string in the solver. At the moment simulation runs without error.
Was this string missing because I did something wrong when defining the case in GUI?
EDIT: simulation finished
Adding "pcorrFinal" string to solver obviously helped.
And I have no idea why... ;)
oliveroxtoby
Postby oliveroxtoby » Tue Jun 12, 2018 10:44 am
Hi Thomas
Thank you for the report. It was a fairly minor change in OF v5 which broke things (unfortunately I neglected to test the multiphase cases last time). I have updated the workbench accordingly - let me know if you have any further trouble.
thschrader
Postby thschrader » Tue Jun 12, 2018 1:33 pm
Hi Oliver,
updated cfd-of-wb, dambreak runs fine, no errors.
Thanks for the fast work.
