cfmesh installation issues during CfdOF install
Moderator: oliveroxtoby
u2berggeist
Postby u2berggeist » Wed Jul 04, 2018 12:34 pm
I'm getting some issues with installing cfmesh onto my computer and wondered if anyone might be able to help. I've attached the log file. Note that I tried to install twice, and I believe the log file that was done during the first install was over written.
All I can really tell is that it's failing to make certain files. Other than that, I'm not really sure what's happening. Any help would be greatly appreciated.
For general info, I'm running:
OS: Ubuntu 18.04 LTS
Version: 0.17.13522 (Git)
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.15rc1
OCC version: 7.2.0
OpenFOAMv1712
Here are the contents of the log.Allmake:
wmake libso meshLibrary
wmake executables
wmake cartesian2DMesh
make[1]: Entering directory '/home/u2berggeist/OpenFOAM/u2berggeist-v1712/cfmesh-cfdof/executables/cartesian2DMesh'
g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/triSurface/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/surfMesh/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/meshTools/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/finiteVolume/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/cartesian2DMesh.o -L/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/platforms/linux64GccDPInt32Opt/lib \
    -lmeshTools -lsurfMesh -lfiniteVolume -L/home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/lib -lmeshLibrary -lOpenFOAM -ldl  \
     -lm -o /home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh
Make/linux64GccDPInt32Opt/cartesian2DMesh.o: In function `main':
cartesian2DMesh.C:(.text.startup+0x37a): undefined reference to `Foam::cartesian2DMeshGenerator::cartesian2DMeshGenerator(Foam::Time const&)'
cartesian2DMesh.C:(.text.startup+0x3ff): undefined reference to `Foam::cartesian2DMeshGenerator::writeMesh() const'
cartesian2DMesh.C:(.text.startup+0x426): undefined reference to `Foam::cartesian2DMeshGenerator::~cartesian2DMeshGenerator()'
cartesian2DMesh.C:(.text.startup+0x64c): undefined reference to `Foam::cartesian2DMeshGenerator::~cartesian2DMeshGenerator()'
/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/wmake/makefiles/general:140: recipe for target '/home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh' failed
make[1]: Leaving directory '/home/u2berggeist/OpenFOAM/u2berggeist-v1712/cfmesh-cfdof/executables/cartesian2DMesh'
make[1]: *** [/home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/bin/cartesian2DMesh] Error 1
/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/wmake/makefiles/apps:39: recipe for target 'cartesian2DMesh' failed
make: *** [cartesian2DMesh] Error 2
wmake utilities
wmake checkSurfaceMesh
make[1]: Entering directory '/home/u2berggeist/OpenFOAM/u2berggeist-v1712/cfmesh-cfdof/utilities/checkSurfaceMesh'
g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1712 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -DNoSizeType -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/triSurface/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/surfMesh/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/meshTools/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/finiteVolume/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/OpenFOAM/lnInclude -I/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/checkSurfaceMesh.o -L/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/platforms/linux64GccDPInt32Opt/lib \
     -lm -o /home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh
Make/linux64GccDPInt32Opt/checkSurfaceMesh.o: In function `main':
checkSurfaceMesh.C:(.text.startup+0x28a): undefined reference to `Foam::triSurf::triSurf(Foam::fileName const&)'
checkSurfaceMesh.C:(.text.startup+0x2f7): undefined reference to `Foam::triSurfaceChecks::calculateBoundingBox(Foam::triSurf const&, Foam::boundBox&)'
checkSurfaceMesh.C:(.text.startup+0x485): undefined reference to `Foam::triSurfaceChecks::checkSurfaceManifolds(Foam::triSurf&, Foam::word)'
checkSurfaceMesh.C:(.text.startup+0x578): undefined reference to `Foam::triSurfaceChecks::checkForHoles(Foam::triSurf&, Foam::word)'
checkSurfaceMesh.C:(.text.startup+0x637): undefined reference to `Foam::triSurfaceChecks::checkForNonManifoldEdges(Foam::triSurf&, Foam::word)'
checkSurfaceMesh.C:(.text.startup+0x6d8): undefined reference to `Foam::triSurfaceChecks::checkDisconnectedParts(Foam::triSurf&, Foam::word)'
checkSurfaceMesh.C:(.text.startup+0x782): undefined reference to `Foam::triSurfaceChecks::checkAngles(Foam::triSurf&, Foam::word, double)'
checkSurfaceMesh.C:(.text.startup+0x829): undefined reference to `Foam::triSurfaceChecks::checkSelfIntersections(Foam::triSurf&, Foam::word, double)'
checkSurfaceMesh.C:(.text.startup+0x8e7): undefined reference to `Foam::triSurfaceChecks::checkOverlaps(Foam::triSurf&, Foam::word, double, double)'
checkSurfaceMesh.C:(.text.startup+0x981): undefined reference to `Foam::triSurfaceChecks::checkCollocatedPoints(Foam::triSurf&, Foam::word, double)'
checkSurfaceMesh.C:(.text.startup+0xa8b): undefined reference to `Foam::triSurf::writeSurface(Foam::fileName const&) const'
checkSurfaceMesh.C:(.text.startup+0xab2): undefined reference to `Foam::triSurf::~triSurf()'
checkSurfaceMesh.C:(.text.startup+0x1013): undefined reference to `Foam::triSurf::~triSurf()'
/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/wmake/makefiles/general:140: recipe for target '/home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh' failed
make[1]: Leaving directory '/home/u2berggeist/OpenFOAM/u2berggeist-v1712/cfmesh-cfdof/utilities/checkSurfaceMesh'
make[1]: *** [/home/u2berggeist/OpenFOAM/u2berggeist-v1712/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Error 1
/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/wmake/makefiles/apps:39: recipe for target 'checkSurfaceMesh' failed
make: *** [checkSurfaceMesh] Error 2
log.Allwmake.txt
(6.26 KiB) Downloaded 28 times
u2berggeist
Re: cfmesh installation issues during CfdOF install
Postby u2berggeist » Wed Jul 04, 2018 2:01 pm
Also, I did the dependency check just for fun and got the following message:
Checking CFD workbench dependencies...
Checking FreeCAD version
Checking for OpenFOAM:
Running  echo $WM_PROJECT_VERSION
Raw command:  ['bash', '-c', 'source "/home/u2berggeist/OpenFOAM/OpenFOAM-v1712/etc/bashrc" && echo $WM_PROJECT_VERSION']
v1712
  File "/home/u2berggeist/.FreeCAD/Mod/CfdOF/CfdPreferencePage.py", line 126, in runDependencyChecker
    msg = CfdTools.checkCfdDependencies()
  File "/home/u2berggeist/.FreeCAD/Mod/CfdOF/CfdTools.py", line 803, in checkCfdDependencies
    if foam_ver != 'dev' and foam_ver != 'plus' and int(foam_ver.split('.')[0]) < 4:
ValueError: invalid literal for int() with base 10: 'v1712'
I'm guessing I'm only supposed to use OpenFOAM from the foundation rather than ESI? Regardless, I'm installing 5.0 now just in case.
u2berggeist
Postby u2berggeist » Wed Jul 04, 2018 2:23 pm
Installing OpenFOAM 5.0, then using the builtin cfmesh installer worked for me. No more issues!!
oliveroxtoby
Postby oliveroxtoby » Wed Jul 04, 2018 8:56 pm
I have updated our cfMesh fork to support v1712, but you are correct that we only 'officially' support v5 as we don't do testing on the other versions.
u2berggeist
Postby u2berggeist » Thu Jul 05, 2018 8:12 pm
Thanks for the update.
I checked to see if the v1712 would work (just to check more than anything else). Running the dependency checker still comes up with the error for the version. ie. the can't convert 'v1712' to a integer.
oliveroxtoby
Postby oliveroxtoby » Fri Jul 06, 2018 6:28 am
Did you update the workbench? This should be fixed.
u2berggeist
Postby u2berggeist » Fri Jul 06, 2018 7:49 pm
Ah, I didn't update it. Once I updated it, the v1712 directory works fine now.
wafi
Postby wafi » Sat Aug 18, 2018 3:25 pm
hm, I running into same problems after updating to Ubuntu 18.4
It seems that I am not able to install cfmesh without errors, here the erroro message during installation process, of cause I installed openfoam 5 first:
L/home/peter/OpenFOAM/peter-5.x/platforms/linux64GccDPInt32Opt/lib -lmeshLibrary -lOpenFOAM -ldl \
-lm -o /home/peter/OpenFOAM/peter-5.x/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh
/usr/bin/x86_64-linux-gnu-ld: -lmeshTools kann nicht gefunden werden
/usr/bin/x86_64-linux-gnu-ld: -ltriSurface kann nicht gefunden werden
/usr/bin/x86_64-linux-gnu-ld: -lfiniteVolume kann nicht gefunden werden
/usr/bin/x86_64-linux-gnu-ld: -lmeshLibrary kann nicht gefunden werden
/usr/bin/x86_64-linux-gnu-ld: -lOpenFOAM kann nicht gefunden werden
make[1]: *** [/home/peter/OpenFOAM/peter-5.x/platforms/linux64GccDPInt32Opt/bin/checkSurfaceMesh] Error 1
OS: Ubuntu 18.04.1 LTS
Version: 0.17.13528 (Git)
Build type: None
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
oliveroxtoby
Postby oliveroxtoby » Sat Aug 18, 2018 7:46 pm
Not sure what could be going on here. Could you include the previous few lines of output that are produced?
Also, could you include the output that is produced on the report view when you run the dependency check?
wafi
Postby wafi » Sat Aug 18, 2018 7:55 pm
just played arround and re- installed, but without big sucsess only the error message is changing.
Dependencie checker states:
Checking dependencies...
No missing dependencies detected
Now, when I try to mesh something:
Starting meshing ...
Part to mesh: Name --> BooleanFragments, Label --> BooleanFragments, ShapeType --> Compound
CharacteristicLengthMax: 115.2
ElementDimension: 3D
No mesh regions.
Populating mesh dictionaries in folder /tmp/meshCase
Successfully wrote meshCase to folder /tmp/meshCase
cfMesh and snappyHexMesh do not accept boolean fragments.Executing: bash -c cd "/tmp/meshCase" && ./Allmesh
Finish Editing BooleanFragments_Mesh
.... unfortunately without mesh. If I try to mesh with gmsh
it`s stated that opencascade is necessary to run gmsh
