Solver-Error
Moderator: oliveroxtoby
Praktikant8
Solver-Error
Postby Praktikant8 » Mon Jul 23, 2018 2:14 pm
Hi there,
i shortly started working with FreeCAD due to its CDF-Module, i need it for my work. Since i don't know nothing about FreeCAD and CFD i started working through some tutorials, learning by doing....I tried to reproduce a tutorial i found online but in the end i had to deal with an error of the solver. The output of the solver is:
0.0: Checking dependencies...
0.0: OpenFOAM case writer is called
0.0: Error writing case:
0.0: 'FeaturePython' object has no attribute 'ShapeFaceNames'
0.0: Write case setup file failed
I don't know what this means and how to solve it.
It would be great if you were able to help me.
I attached a Screenshot of the output and linked the website where i found the tutorial.
https://github.com/opensimsa/opensim/bl ... lbow.pdf
Word size of FreeCAD: 32-bit
Version: 0.18.14111 (Git)
Hash: 548f63fd0eb554bb0fe5b23c1970de5fe05e3001
Python version: 2.7.14
OCC version: 7.2.0
oliveroxtoby
Re: Solver-Error
Postby oliveroxtoby » Mon Jul 23, 2018 2:49 pm
Hi there,
OCC version: 7.2.0
Could you please save and share the FreeCAD file that is giving you this issue?
Praktikant8
Re: Solver-Error
Postby Praktikant8 » Mon Jul 23, 2018 3:04 pm
Sure, here you go
CFD.FCStd
(38.65 KiB) Downloaded 22 times
oliveroxtoby
Re: Solver-Error
Postby oliveroxtoby » Mon Jul 23, 2018 3:24 pm
Sure, here you go
Thanks. We have just refactored the meshing code extensively. Please update the workbench using Addon manager, and then try again. You will need to delete and re-create the mesh object due to the changes. Let me know if this sorts out the problem - it works for me, but I am using v0.17 of FreeCAD - maybe there is an issue that only comes up in 0.18.
thschrader
Re: Solver-Error
Postby thschrader » Mon Jul 23, 2018 3:25 pm
Posted in help-forum too.
Praktikant, your model is to small, factor 1000.
thschrader
Re: Solver-Error
Postby thschrader » Mon Jul 23, 2018 4:45 pm
Hi Praktikant,
I ran your "scaled-down" tutorial.
Use this parameters:
gmsh-meshing: max element size 1 mm
Inlet 1 vx=500 mm/s (you gave in 1 mm)
Inlet 2 vy=300 mm/s
Outlet ok
wall (the yellow one) = noSlip
wall001=slip
In the data-tab of openfoam you can set the solver-options.
Learn freecad:
https://www.youtube.com/user/BPLRFE
Learn openfoam:
https://www.youtube.com/watch?v=KznljrgWSvo
Have fun! :)
Praktikant8
Re: Solver-Error
Postby Praktikant8 » Tue Jul 24, 2018 7:21 am
Hi guys,
thanks to all of you, especially to thschrader. I corrected the parameters you told me, ran the solver and now it is working. I'm so glad that i can now move on and try to solve other tasks (maybe you will hear from me in a while having another problem). Also thanks for the useful YT-links. :D
