feature request: Viewing and editing OpenFOAM blockMeshDict in FreeCAD?
Moderator: oliveroxtoby
bernd
Re: feature request: Viewing and editing OpenFOAM blockMeshDict in FreeCAD?
Postby bernd » Wed Aug 22, 2018 4:02 pm
I would like to give it a try too. Would you post an example blockmeshfile?
foadsf
Postby foadsf » Wed Aug 22, 2018 5:38 pm
There are lot of blockMeshFiles available here in OpenFOAM tutorials. A very good example has been mentioned here in this StackOverflow post.
bernd
Postby bernd » Wed Aug 22, 2018 7:17 pm
ok than the attached file will be my test case ...
remove txt ...
blockMeshDict.txt
(3.01 KiB) Downloaded 18 times
bernd
Postby bernd » Wed Aug 22, 2018 8:34 pm
played a bit ... https://github.com/berndhahnebach/FreeC ... f8426bd887
we really should include it as FEM mesh. I'm not good at re module at all. Do you plan to read the hexaeder too? If yes I would adapt the reader I started to read a real FEM mesh in FreeCAD. I would just need a dictionary, with the node numbers for each hexaeder.
bernd
foadsf
Postby foadsf » Wed Aug 22, 2018 8:56 pm
cool. I see you have already started integrating into the FreeCAD and sent a pull request? next logical steps would be:
  • connect the points which are in the same face and put the face title/number in center
  • put the hex name/number in the middle of the block
  • file a better way of showing text, the
    Draft.makeText([str(vertexNum)],point=FreeCAD.Vector(vertex[0],vertex[1],vertex[2]))
    is utterly awful! i would prefer a solution like the one I have suggested in this question where the text is proportional to the window size and always parallel to the view plane
bernd
Postby bernd » Wed Aug 22, 2018 8:58 pm
as I said, I'm not good at re module at all. For the hex elements I would need a dictionary, with the node numbers for each hexaeder. Would you add this to your code?
foadsf
Postby foadsf » Wed Aug 22, 2018 9:00 pm
i will try implementing it. would you be so kind to help me with the annotation?
foadsf
Postby foadsf » Wed Aug 22, 2018 9:49 pm
The blockMesh has this nice feature of
blockMesh  -blockTopology
which
write block edges and centres as .obj files
. and then two .obg files can be imported into MeshLab. What we are developing can replace that.
bernd
Postby bernd » Wed Aug 22, 2018 11:19 pm
once we have the hexaeder I will show you something better than Draft to visualize the mesh :)
In the regard of the annotation. This should be dissussed once the mesh can be imported as FemMesh.
bernd
foadsf
Postby foadsf » Thu Aug 23, 2018 8:25 am
I'm talking to one of the SO guys over here for the rest of the re stuff over here. feel free to join.
