UAV-tutorial / compressible-solver
Moderator: oliveroxtoby
thschrader
Postby thschrader » Sun Aug 26, 2018 2:38 pm
the opensimsa UAV-tutorial was updated.
First impressions:
Hard to mesh. When using the parameters from tutorial (base cell size 100 mm),
cfmesh gives back a bad mesh (with more then 1 Mio cells). The problems remains when
using cell-size 50 mm, the mesh is still looking weird.
When starting meshing, FC needs 3 min to generate the stl for OF.
Maybe thats a translation problem from XOR to stl.
I will try gmsh/SHM. Or the macros...
After updating the cfd-wb, there is a new solver option:
Compressible/High mach number:
Which solvers are used? rhoSimpleFoam and sonicFoam?
Fluid-properties, sutherland-constant:
The units kg/(m*s) imply that this is a dynamic viscosity. Is it the
reference-viscosity mu-0 in the sutherland-formula?
Initialise flow-field, temperature:
Is it the reference-temperature T-0 in formula?
Bondary conditions:
How must I use the new Far-field BC?
@oliver/bernd: great job guys, the cfd/fem-wb is a real stunning
engineering-tool :)
thschrader
Re: UAV-tutorial / compressible-solver
Postby thschrader » Sun Aug 26, 2018 3:51 pm
I will see, if I can transform the imported iges-shells (from grabcad)
into a watertight solid to be sure, that the booleans work properly.
In the curves-wb is a tool "Make a parametric solid from selected faces"
(the green cube). For the front wheel it works...
thschrader
Postby thschrader » Sun Aug 26, 2018 4:40 pm
BTW:
The Millenium-Falcon tutorial on
https://opensimsa.github.io/training.html
has gone... :o
oliveroxtoby
Postby oliveroxtoby » Mon Aug 27, 2018 12:20 pm
First impressions:
Did you update the workbench before you did this? Because we have not experienced either of these issues.
EDIT: Sorry. I do have the mesh problem when I run it in 0.17. It is happy in 0.18. Investigating...
No, hisa.gitlab.io, a solver just released by my institution.
No, unfortunately the units are wrong at present because FreeCAD currently doesn't accept fractional units (on my todo list). This is the C_1 constant referenced at https://www.cfd-online.com/Wiki/Sutherland%27s_law
This is the initial temperature and it is used to calculate viscosity at initial time via the formula, but it doesn't relate to the reference temperature. The formula used uses C_1 and S, and T_0 is not used.
Bondary conditions:
It is for specifying uniform free-stream flow conditions far away from a body, typically an aircraft, and prevents reflections of shocks back into the domain.
engineering-tool :)
Thank you for the testing!
oliveroxtoby
Postby oliveroxtoby » Mon Aug 27, 2018 12:21 pm
That sounds like a really useful tool. But I have not had any issues with the tutorial as presented.
EDIT: My bad. It was working fine with latest 0.18, but not with 0.17. Investigating...
oliveroxtoby
Postby oliveroxtoby » Mon Aug 27, 2018 12:23 pm
BTW:
has gone... :o
It was not much of a 'tutorial' to begin with - the new UAV tutorial makes it obsolete. Is is still there on the repository - see https://github.com/opensimsa/opensim/tr ... tCases/CFD
thschrader
Postby thschrader » Mon Aug 27, 2018 2:09 pm
Updated cfd-of, problem remains. I have reimported the written XOR_Geometry.stl from
trisurface. In the mesh-design wb you can analyze the stl. Try this on your machine.
When the stl writing process is identical, you should get the same result.
However, I will try to redesign the UAV in FC. This is a nice
model to play with curves/surface-wb. My system:
Version: 0.18.14315 (Git)
Hash: 5f8f26824486b55b2bf72c579e95f0f6d4a19284
Python version: 2.7.14
OCC version: 7.2.0
oliveroxtoby
Postby oliveroxtoby » Mon Aug 27, 2018 8:44 pm
OCC version: 7.2.0
This should be fixed now. I don't think it was appropriate to use XOR here. Slice seems to do the job. For some reason (probably sheer luck), XOR worked for me originally on a version that was linked to OCC 6.9 (which happened to be my 0.18 version, but it was nothing to do with that)...
thschrader
Postby thschrader » Tue Aug 28, 2018 2:19 am
Slice (and the updated wb) is the way. Thanks for the fast fixing.
Lets have fun with the tutorial.
thschrader
Postby thschrader » Wed Sep 05, 2018 12:41 pm
Updated cfd-of wb.
Updated cfmesh.
Installed HiSA-solver via preferences/cfd. Installation ok, dependencies ok.
I want to simulate the openfoam "prism" tutorial with FC (Mach 2 flow along prism)
When writing the case I still get error "compressible model currently not supported"
Maybe my workflow is wrong?
prism.FCStd
(18.97 KiB) Downloaded 22 times
