UAV-tutorial / compressible-solver
Moderator: oliveroxtoby
oliveroxtoby
Re: UAV-tutorial / compressible-solver
Postby oliveroxtoby » Mon Oct 01, 2018 12:05 pm
shIxx wrote:
Mon Oct 01, 2018 11:06 am
Hi guys,
I do not know if this fits in here, but I did not want to start a new thread.
I have all tutorials through and am quite familiar with the cfdOF -wb now. Only at the 4th (the UAV tutorial) I can not get on. I did everything as described but I always get an error message and the solver does not expect anything useful (see screenshot).
What I have done:
PhysicsModel: Stady, turbulent case.
FluidProperties: Air
InitialiseFields: Potential flow
openFOAM: parallel true (4), conv.criteria 1e-3, 2000 iterations
Inlet: y = 5m/s and z = -20m/s
Instead of the slice operator I have used XOR (you can see it on the tutorial screenshot as well even if there is written "slice") and it only works with XOR otherwise the model disappears! -> The mesh was well generated (looks like the tutorial)
I don't know why it does not work.
The file is too large to attach.
Maybe double-check your inlet condition. It looks like the solver is probably not seeing any inlet velocity. Otherwise if you can find a way to share the fcstd file, that would probably be the quickest way to get an answer.
shIxx
Postby shIxx » Mon Oct 01, 2018 12:18 pm
I have uploaded it to google drive:
https://drive.google.com/drive/folders/ ... 5_mvcKfOn7
oliveroxtoby
Postby oliveroxtoby » Mon Oct 01, 2018 3:51 pm
Strangely when I open the file, write the mesh and run the solver, it runs with no problem. Can you paste your system info (Help | About) and attach the complete output of your report view please?
shIxx
Postby shIxx » Mon Oct 01, 2018 8:36 pm
Of course, thank you for your helpI.
Version: 0.18.14825 (Git)
Hash: a0ff629747d5d73567075821852a8cdaadcf51c5
Python version: 2.7.14
OCC version: 7.2.0
I hope you mean the output window "reportview" in the German translation. At the very beginning when I start FC already comes an error and the cfd-wb is not displayed to me although it is installed. that's been around for about a year, since the download on the addon manger works and blueCFD-core is for download in the settings. I think that has nothing to do with this problem but still it is strange.
report-view.txt
(105.42 KiB) Downloaded 12 times
oliveroxtoby
Postby oliveroxtoby » Mon Oct 01, 2018 8:50 pm
OCC version: 7.2.0
I hope you mean the output window "reportview" in the German translation. At the very beginning when I start FC already comes an error and the cfd-wb is not displayed to me although it is installed. that's been around for about a year, since the download on the addon manger works and blueCFD-core is for download in the settings. I think that has nothing to do with this problem but still I find it strange.
Thanks for the output. It looks as if you installed cfMesh a while ago before we made some modifications. As a result, although the mesh looks good, the process is terminating before it is fully complete. If you re-do the cfMesh installation from the Preferences window, I think this should solve your problem.
oliveroxtoby
Postby oliveroxtoby » Mon Oct 01, 2018 8:54 pm
The error is generated by the CFD workbench. This is a separate development from the CfdOF workbench so I can't really comment.
shIxx
Postby shIxx » Tue Oct 02, 2018 11:39 am
Thank you it works.
Straight forward. You look at the stystem info and the output file and you know whats the problem .
You are really a professional. Thumbs up!
I'm surprised that so far all other simulations worked well with this broken installation. Anyway, I reinstalled everything (blueCFD, cfMesh and HiSA)
As I installed cfmesh just showed:
downloading cfmesh.
extract ...
building .... please wait
and then Log: C:/ ...........................
I thought it was done and it just shows me where to find the logfile, so I hit "Apply". Then the mesher did not worked anymore and broke off with an error. So I installed cfMesher again and found out that something is happening in the output window. I waited until finally "insatllation complete" was showen.
That took almost 15 minutes ... is this normal for a 15mb file?
Same for HiSA and this had only 0.25mb downloaded.
oliveroxtoby
Postby oliveroxtoby » Tue Oct 02, 2018 8:38 pm
The code has to be compiled in the OpenFOAM environment - this is what takes the time.
thschrader
Postby thschrader » Sun Oct 07, 2018 3:48 pm
Wind on building, comparison of Hisa/simpleFoam solvers.
House 8x8x6,5 m (simulation at half body for saving computing time)
Inlet: v=42 m/s (150 km/h)
Fluid air, temperature 290 K.
Mesher: snappyhexmesh with refinement zones.
Hisa: resulting force on building 72 kN, drag-coefficient 1,27
simplefoam: 65 kN force, drag coefficient 1,14.
According to my DIN-manual, the correct drag-coefficient is between
1,2-1,3 (depending on roof-tilt)
Hisa runs longer, but gives a more accurate p-residual, which is needed for
the force calculation.
In my opinion Hisa can be used for such calculations too, not "only" for
aircraft-design.
oliveroxtoby
Postby oliveroxtoby » Sun Oct 07, 2018 8:59 pm
aircraft-design.
Interesting observation, thanks. The flux-splitting scheme used does have a low Mach correction and seems to perform quite well under those conditions, but we haven't studied it comprehensively so I am wary about making any promises.
