UAV-tutorial / compressible-solver
Moderator: oliveroxtoby
shIxx
Re: UAV-tutorial / compressible-solver
Postby shIxx » Thu Oct 18, 2018 12:56 pm
thschrader wrote:
Sun Oct 07, 2018 3:48 pm
Wind on building, comparison of Hisa/simpleFoam solvers.
House 8x8x6,5 m (simulation at half body for saving computing time)
Inlet: v=42 m/s (150 km/h)
Fluid air, temperature 290 K.
Mesher: snappyhexmesh with refinement zones.
Hisa: resulting force on building 72 kN, drag-coefficient 1,27
simplefoam: 65 kN force, drag coefficient 1,14.
According to my DIN-manual, the correct drag-coefficient is between
1,2-1,3 (depending on roof-tilt)
Can you please share both files. I am new to HiSA and I would like to study the boundary conditions and also the different results comparing HiSA and simplFOAM.
thschrader
Postby thschrader » Fri Oct 19, 2018 9:30 am
Sorry, deleted. ;)
But I can reconstruct the sim. OK?
atchuy
Postby atchuy » Fri Oct 19, 2018 9:54 am
wow thanks for your sharing ! it's very useful !
thschrader
Postby thschrader » Fri Oct 19, 2018 11:13 am
found the house geometry...
house.FCStd
(19.99 KiB) Downloaded 7 times
shIxx
Postby shIxx » Fri Oct 19, 2018 12:31 pm
house.FCStd
Thank you very much for sharing.
I have another issue now. I wanted to make a similar simulation as your bullet case. I noticed that my HiSA solver was not installed properly so I reinstalled it. But there is always an error that doesn't let me install HiSA. Although "install completed" is shown, the installation is faulty. I don't understand why.
Version: 0.18.14928 (Git)
Hash: 3d833e52df450cb98c1dacd0a3d17b439217a4c0
Python version: 2.7.14
OCC version: 7.2.0
thschrader
Postby thschrader » Fri Oct 19, 2018 5:28 pm
rebuilt Hisa-case.
house_hisa.FCStd
(38.54 KiB) Downloaded 7 times
EDIT: rebuilt simpleFoam-case too
house_simpleFoam.FCStd
(36.73 KiB) Downloaded 6 times
done with
Version: 0.18.14825 (Git)
Hash: a0ff629747d5d73567075821852a8cdaadcf51c5
OCC version: 7.2.0
oliveroxtoby
Postby oliveroxtoby » Sat Oct 20, 2018 4:58 am
This is very strange. Would you mind uploading the entire output of the report view so that I can see what the initial error is.
shIxx
Postby shIxx » Sat Oct 20, 2018 9:02 am
I attached the report files. Once from the installation and once from the dependencie check
dependencie-check.txt
(3.13 KiB) Downloaded 7 times
HiSA-install.txt
(25.69 KiB) Downloaded 9 times
oliveroxtoby
Postby oliveroxtoby » Sat Oct 20, 2018 4:51 pm
Thank you. All I can think of is that it has somehow got into a half-built state. Could you try deleting the entire C:\Program Files\blueCFD-Core-2017\ofuser-of5\hisa-master directory and try again? Please let me know if this works so that I can make it do this automatically.
If not, could you check if the file C:\Program Files\blueCFD-Core-2017\ofuser-of5\hisa-master\src\preconditioners\lnInclude\preconditioner.H exists? And the file C:\Program Files\blueCFD-Core-2017\ofuser-of5\hisa-master\src\preconditioners\preconditioner\preconditioner.H?
Finally can you try running the app "blueCFD core terminal" from the start menu, then type
cd blueCFD/ofuser-of5/hisa-master
./Allwmake
And see if you get any build errors.
shIxx
Postby shIxx » Sat Oct 20, 2018 9:50 pm
./Allwmake
Deleting the hisa-master folder has led to less errors (I think). Nevertheless, it showed a few red lines:
Exception in thread Thread-3:
File "C:\Users\thoma\Desktop\FreeCAD_0.18.14928_x64_dev_win\bin\lib\threading.py", line 801, in __bootstrap_inner
self.run()
File "C:\Users\thoma\Desktop\FreeCAD_0.18.14928_x64_dev_win\bin\lib\threading.py", line 754, in run
self.__target(*self.__args, **self.__kwargs)
File "C:\Users\thoma\AppData\Roaming\FreeCAD\Mod\CfdOF\WindowsRunWrapper.py", line 50, in processStderr
sys.stderr.write(output.decode())
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 46: ordinal not in range(128)
The folder \lnInclude is empty.
\preconditioner\preconditioner.H exists and has 6kb
The whole output of the blueCFD core terminal is attached . Some fatal errors are shown!
preconditioner.H and the report view of the HiSa installation are also attached.
Hisa-install-report.txt
(93.06 KiB) Downloaded 8 times
preconditioner.H
(5.16 KiB) Downloaded 5 times
blueCFD-terminal.txt
(6.77 KiB) Downloaded 6 times
