I haven't seen that before. I can only advise to try to uninstall and re-install blueCFD, and reinstall cfMesh.Rodp1 wrote: ↑Mon Jan 20, 2020 3:47 amI've now installed it on two computers - on one machine it works fine, on the other I'm getting issues.I'll need more information as detailed in the link below.
/* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 5.x-963176928289 Exec : C:/PROGRA~1/BLUECF~1/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin/cartesianMesh.exe Date : Jan 20 2020 Time : 11:44:12 Host : "ASAW109800" PID : 24372 I/O : uncollated Case : C:/Temp/meshCase nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Created 11 surface patches Setting root cube size and refinement parameters Root box (-7.8 -7.8 -7.8) (17.8 17.8 17.8) Requested cell size corresponds to octree level 8 Requested boundary cell size corresponds to octree level 8 Refining boundary Refining boundary boxes to the given size Finished refining boundary boxes Refining boxes intersecting surface meshes Finished refinement of boxes intersecting surface meshes Performing automatic refinement Performing automatic refinement Marking inside/outside. libgomp: Thread creation failed: Resource temporarily unavailable
cfdOF install
Moderator: oliveroxtoby
- oliveroxtoby
Re: cfdOF install
Re: cfdOF install
[/quote]
[/quote]
Thanks - I've tried that, and in doing so I notice that I get a warning about there already being a version of MPI installed. My guess is that this is somehow related. A quick google on the message brings up some discussion around it being an issue with the number of threads being created.
Is there any way to execute cfmesh on a single thread? I've tried modifying the Allmesh file that's generated as below, but it didn't help in this case
[/quote]
#!/bin/bash
OMP_NUM_THREADS=1
runCommand()
if [ "$1" == "mpirun" ]; then sol="$4"; else sol="$1"; fi
sol=$(basename -- "$sol")
sol="${sol%.*}"
if [ -f log."$sol" ]; then rm log."$sol"; fi
"$@" 1> >(tee -a log."$sol") 2> >(tee -a log."$sol" >&2)
err=$?
if [ ! $err -eq 0 ]; then exit $err; fi
# Extract feature edges
runCommand surfaceFeatureEdges -angle 60 "constant/triSurface/XOR_Geometry.stl" "XOR_Geometry.fms"
runCommand cartesianMesh
if [ ! -z $FOAM_API ] && [ $FOAM_API -ge 1906 ]
then
runCommand surfaceMeshExtract mesh_outside.stl
else
runCommand surfaceMeshTriangulate mesh_outside.stl
fi
runCommand surfaceTransformPoints -scale "(1000 1000 1000)" mesh_outside.stl mesh_outside.stl
- oliveroxtoby
Re: cfdOF install
Re: cfdOF install
Thanks again. For some reason I need to set export OMP_STACKSIZE=100M. This was defaulting to 1G, which was what was killing it.oliveroxtoby wrote: ↑Mon Jan 20, 2020 10:08 amChangingtoCode: Select all
OMP_NUM_THREADS=1
may do it.Code: Select all
export OMP_NUM_THREADS=1
No idea why this is happening, I can only guess there is a conflict with something else installed on my machine.
- oliveroxtoby
Re: cfdOF install
Glad you found a workaround - thanks for reporting back.
