cfdOF install
Moderator: oliveroxtoby
ljb
Re: cfdOF install
Postby ljb » Fri Sep 07, 2018 2:03 pm
200 hours?
OK.
Maybe I can do a little better by standing on your shoulders?
Of course the way things are changing these days I imagine that no one ever gets very far beyond the beginner stage.
Hmm. The next step is to 'write the case to a directory'.
(Guess what ... :-) )
Input Case Name in the data tab of the model tree defaulted to 'case'. I changed that to 'case_elbow_1' and pushed the Write button.
That didn't work, so I changed it back to 'case' and pushed Write. Still did not work.
0.0: Please edit the case input files externally at: c:\users\lb17\appdata\local\temp\case
EDIT Input Case Name from 'case' to 'case_elbow_1'
0.0: Checking dependencies...
0.0: OpenFOAM case writer is called
1.2: Error writing case:
1.2: [Error 3] The system cannot find the path specified: 'c:\\users\\lb17\\appdata\\local\\temp\\meshCase\\constant\\triSurface/*.*'
1.2: Write case setup file failed
EDIT Input Case Name from 'case_elbow_1' back to 'case'
0.3: Error writing case:
0.3: [Error 3] The system cannot find the path specified: 'c:\\users\\lb17\\appdata\\local\\temp\\meshCase\\constant\\triSurface/*.*'
0.3: Write case setup file failed
NOTE: the folders 'case' and 'case_elbow_1' (on my computer) are found in the ... appdata\local\temp\ folder, not in the deeper folder shown above in the [Error 3] msgs.
The path
does not exist on my computer.
ljb
Re: cfdOF install
Postby ljb » Fri Sep 07, 2018 2:20 pm
I pulled up the Preferences dialog, and for CFD the output directory is
I bet I ought to change this to
c:\users\lb17\appdata\local\temp\meshCase\constant\triSurface/*.*'
However - shouldn't the current setting in Prefs cause FC to look in my preferred folder setting instead of (the factory default?) where it is actually looking?
oliveroxtoby
Re: cfdOF install
Postby oliveroxtoby » Fri Sep 07, 2018 3:47 pm
Did you create the mesh first? This should have created the folder c:\\users\\lb17\\appdata\\local\\temp\\meshCase - does it exist?
thschrader
Re: cfdOF install
Postby thschrader » Fri Sep 07, 2018 4:14 pm
Better not....
Here are some shoulders you can stand on:
https://www.youtube.com/channel/UCjdgpu ... Vvw/videos
Do you remember the geometry below? :)
All tutorials can be done with the bluecfd-core console. When you feel fit,
try to rebuild the tutorials with Freecad-cfd. You will learn a lot.
Some more learning stuff:
https://www.youtube.com/user/kehoste/videos
ljb
Re: cfdOF install
Postby ljb » Fri Sep 07, 2018 4:27 pm
Yes it does
temp\meshCase
contains constant and gmsh and system (plus some files)
* meshCase\constant contains polyMesh <but not triSurface> (and no files}
* * constant\polyMesh contains sets (and some files)
* * * polyMesh\sets contains (one file)
gmsh contains (some files)
system contains (some files)
back up the folder tree
...temp\case contains constant which contains triSurface which is empty
and
...temp\case_elbow_1 contains constant which contains triSurface which is empty
ljb
Re: cfdOF install
Postby ljb » Fri Sep 07, 2018 4:32 pm
thschrader:
Thanks.
Sounds like work.
and fun.
I'll do it.
ljb
Re: cfdOF install
Postby ljb » Fri Sep 07, 2018 8:18 pm
Oliver,
I'm trying to understand why my Default output directory in the Preferences dialog is different from the one that the 'Analysis control' dialog is calling.
The 'CFD Mesh by gmsh' dialog seems to have used the directory from Preferences for its output.
I did not explicitly set either one. Could I have done it indirectly, somewhere earlier in the process?
Could this be related to those error messages?
ljb
Re: cfdOF install
Postby ljb » Fri Sep 07, 2018 8:34 pm
Here's an idea.
This project is one that thschrader sent to me. It uses my original project as a starting point, but I think he finished some of the final steps prior to the 'write case' step.
I wonder what his Preference dialog says about the output directory.
ljb
Re: cfdOF install
Postby ljb » Sat Sep 08, 2018 12:32 am
In a recent post thschrader suggested that I attempt to redo the elbow tutorial from scratch.
I think that is a good idea. It will give me a chance to see how much I have learned from you guys.
Since my first attempt was named test_elbow_1, I will name this one test_elbow_2
oliveroxtoby
Re: cfdOF install
Postby oliveroxtoby » Sat Sep 08, 2018 8:35 pm
Oliver,
The preferences page defaults to your temporary directory, but you can change it. This is used as the path in which the mesh and the case are written, if the path in the analysis object is blank. If it is not blank, then that path (which will be saved with the file) overrides the one set in your preferences.
Can you share the file that is giving you this error, and I will see if I can reproduce?
