cfdOF install
Moderator: oliveroxtoby
ljb
Re: cfdOF install
Postby ljb » Sun Sep 09, 2018 3:38 pm
Hi Oliver,
Thanks for your help.
I’m not sure. The Report view just below might be the one you need. I sent a copy of my project, 'test_elbow_1.FCStd', to thschrader and he sent it back to me as 'test_elbow_1_new_cfmesh.FCStd' and 'test_elbow_1_new_gmesh.FCStd'.
As part of my subsequent fiddling, I loaded my original and at least one of thschrader’s modified project files and did some experimenting.
I now realize I should have paid more attention to which was which. Bookkeeping was not on my mind then, but it is now.
Not all is lost from that time, however. I did copy the Report view from then that produced the relevant (I hope) error.
Report view
Starting meshing ...
  Part to mesh: Name --> Pad,  Label --> Pad, ShapeType --> Solid
  CharacteristicLengthMax: 800.0
  ElementDimension: 3D
  File "C:\Users\LB17\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdMesh.py", line 234, in runMeshProcess
    cart_mesh.setup_mesh_case_dir()
  File "C:\Users\LB17\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdMeshTools.py", line 200, in setup_mesh_case_dir
    shutil.rmtree(self.meshCaseDir)
  File "C:\Program Files\FreeCAD 0.17\bin\lib\shutil.py", line 261, in rmtree
    rmtree(fullname, ignore_errors, onerror)
  File "C:\Program Files\FreeCAD 0.17\bin\lib\shutil.py", line 270, in rmtree
    onerror(os.rmdir, path, sys.exc_info())
  File "C:\Program Files\FreeCAD 0.17\bin\lib\shutil.py", line 268, in rmtree
    os.rmdir(path)
WindowsError: [Error 145] The directory is not empty: 'c:\\users\\lb17\\appdata\\local\\temp\\meshCase\\constant\\polyMesh'
    os.rmdir(path)
WindowsError: [Error 145] The directory is not empty: 'c:\\users\\lb17\\appdata\\local\\temp\\meshCase\\constant'
    os.rmdir(path)
WindowsError: [Error 145] The directory is not empty: 'c:\\users\\lb17\\appdata\\local\\temp\\meshCase'
Save AutoRecovery file: Needed time: 36ms
My question about the different directories was focused on the default working directory in the Preferences dialog. I now recognize that as the temp directory from Windows, rather than something from freeCAD as I though then.
I used the Input Case Name property with the default value of ‘case’ once, and later with an edited value of ‘case_elbow_1’. At the time I thought I was doing a mesh of my model, but now I see that I was doing a case. At least, I think I see this.
The error msgs in the report above mention a folder named 'meshCase'. This is the mystery folder I was/am wondering about. Where does it come from?
I do not see where the meshing results are saved. Would that be saved as part of the .FCStd file?
And – can a model be meshed more than once? Somewhere in my explorations I got an error message that said only one meshing was allowed. This seems unlikely, so I just chalked it up to something I did wrong.
I am in the process of starting over with the elbow tutorial. I will pay a lot more attention to bookkeeping this time.
I will rephrase my other questions as I understand this stuff a little better. Fewer problems this time around, hopefully. One things is already better - My model this time is fully constrained.
Meshing is next.
Thanks again.
ljb
Re: cfdOF install
Postby ljb » Sun Sep 09, 2018 5:48 pm
Meshing went OK
Adding boundaries went OK
Writing the case went OK
Running the case went OK
Post processing looks like it ought to.
For now I'm passing on the 2D option, since I need to stay 3D.
The End
Dang.
Am I done?
Well, of course not. I'm just getting started. :-)
I'm sure I'll have more questions, but they will mostly be more appropriate in a different topic.
For now I'd like to say thank you. All of you.
polymer
Re: cfdOF install
Postby polymer » Wed Sep 12, 2018 7:57 am
The following problem appears by the Installation:
Checking dependencies...
cfMesh not found
HiSA not found
gmsh is not installed
Downloading cfMesh, please wait...
Error downloading cfMesh: module 'urllib' has no attribute 'FancyURLopener'
Download unsuccessful
Downloading HiSA, please wait...
Error downloading HiSA: module 'urllib' has no attribute 'FancyURLopener'
blueCFD Core 2017-2 is installed.
Version: 0.18.14709 (Git)
Hash: faad5ea27301cb7af393a25d317c406d3098bafe
Python version: 3.6.6
Qt version: 5.6.2
What am I doing wrong?
Can I provide some additional Information?
greetings
thschrader
Re: cfdOF install
Postby thschrader » Wed Sep 12, 2018 8:41 pm
I think nothing.
When you copy the download URL from preferences/cfd into the browser,
a pop-up opens. The install routine cannot reach the zip-file. Download
cfmesh/Hisa manually and use the "choose existing file" option for installing.
For me it works.
polymer
Re: cfdOF install
Postby polymer » Wed Sep 12, 2018 9:10 pm
Hmm, no, it does not work, too.
For Download:
  File "C:\Users\USERNAME\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 327, in downloadCfMesh
    urllib._urlopener = urllib.FancyURLopener(context=ssl._create_unverified_context())
AttributeError: module 'urllib' has no attribute 'FancyURLopener'
During handling of the above exception, another exception occurred:
  File "C:\Users\USERNAME\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 293, in run
    self.downloadCfMesh()
  File "C:\Users\USERNAME\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 334, in downloadCfMesh
    raise Exception("Error downloading cfMesh: {}".format(str(ex)))
Exception: Error downloading cfMesh: module 'urllib' has no attribute 'FancyURLopener'
When i choose the downloaded *.zip file:
  File "C:\Users\USERNAME\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 187, in pickCfMeshFile
    self.form.le_cfmesh_url.setText(urlparse.urljoin('file:', urllib.pathname2url(f)))
AttributeError: module 'urllib' has no attribute 'pathname2url'
oliveroxtoby
Re: cfdOF install
Postby oliveroxtoby » Wed Sep 12, 2018 9:44 pm
cfMesh not found
HiSA not found
Qt version: 5.6.2
greetings
We have just done the update to support Python 3, and this was an issue that slipped through. Should be fixed now.
oliveroxtoby
Re: cfdOF install
Postby oliveroxtoby » Wed Sep 12, 2018 9:47 pm
I think nothing.
For me it works.
The previous certificate issues that sometimes occurred when downloading were (hopefully) fixed a while ago.
polymer
Re: cfdOF install
Postby polymer » Thu Sep 13, 2018 6:46 am
It work's! Thank you! :)
Another Thing...
I have installed gmsh according to the following instructions:
http://bluecfd.github.io/Core/FAQ/how-t ... h-as-gmsh/
gmsh starts in the blueCFD-core Terminal, but the dependeny check says "gmsh is not installed".
greetings
thschrader
Re: cfdOF install
Postby thschrader » Mon Sep 17, 2018 4:46 pm
Another Thing...
greetings
Why do you have an additional install of gmsh? Thats not necessary, you get gmsh "for free"
in ...freecad/bin folder. I never did an extra installation, gmsh runs fine in cfd-wb.
Forget this extra installation stuff, just follow the preferences dialog. Should work...
oliveroxtoby
Re: cfdOF install
Postby oliveroxtoby » Mon Sep 17, 2018 7:24 pm
Another Thing...
greetings
It seems that the Python3/Qt5 package doesn't include gmsh at this stage. Ideally we should make the gmsh path configurable so that you can point it to a separate installation, but for now a workaround would be to copy the gmsh executable into the FreeCAD/bin folder.
