interFoam Error with multiphase flow
Moderator: oliveroxtoby
kix
Post by kix »
I tried some example in cfdof workbench but it has error with multiphase (air-water) flow model.
I made the model "filling of tank" simililar to https://forum.freecadweb.org/viewtopic. ... 47#p194045
The model is attached.
  • blueCFD-core: installed via freeCAD
  • The calc. conditions are set in cfdof workbench only. I don't edit the openFoam files directly.
  • Mesh/walls seems no problem since the solver runs in single phase flow.
  • Boundary conditions: Inlet= velocity, Outlet= pressure
Can anyone tell me how to fix?
Happy holidays!
log.interFoam:
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops
Reading field p_rgh
Reading field U
Reading/calculating face flux field phi
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
GAMG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.0011904762
Time = 0.00119048
PIMPLE: iteration 1
--> FOAM FATAL ERROR:
Only Euler and CrankNicolson ddt schemes are supported
    From function int main(int, char**)
    in file ../VoF/alphaEqn.H at line 49.
FOAM exiting
Version: 0.18.15449 (Git)
Hash: 47a38eceb395887d5cce220ff882f525ca06c4b7
Python version: 2.7.14
OCC version: 7.2.0
testCFD2.FCStd
(26.12 KiB) Downloaded 111 times
thschrader
Re: interFoam Error with multiphase flow
Post by thschrader »
same issue here
Version: 0.18.15399 (Git)
Hash: 9683abfc36c3e9e94b9175428ec9491b869a6b97
OCC version: 7.2.0
thschrader
There is an issue when writing the case.
fvSchemes-dict, line 20 ddtSchemes: default should be Euler.
@kix: after writing the case, edit fvSchemes dict. Solver runs.
kix
Post by kix »
Hi thschrader,
Thank you for the quick response!
I also confirmed the solver runs with the modification :D
I should learn more about openfoam...
oliveroxtoby
Post by oliveroxtoby »
kix wrote: Sat Dec 22, 2018 3:11 pm Hi,
Sorry about that - fixed the bug. Please update your workbench.
Please provide all the information requested in this post before reporting problems with CfdOF.
ReneSci
Post by ReneSci »
Thanks for the valuable info. However, cfdOF still seems to write "backward" instead of "Euler"
Is this by purpose ?
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default backward;
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Locale: Danish/Denmark (da_DK)
Installed mods:
  * A2plus 0.4.60k
  * ArchTextures
  * Assembly3 0.11.4
  * Assembly4 0.12.7
  * CfdOF 1.21.8
  * Defeaturing 1.2.0
  * Dracula 0.0.4
  * ExtremeProDark 2.7.8
  * IconThemes
  * InventorLoader 1.3.0
  * lattice2 1.0.0
  * Manipulator 1.5.0
  * MeshRemodel 1.8919.0
  * parts_library
  * Plot 2022.4.17
  * QuickMeasure 2022.10.28
  * sheetmetal 0.2.63
  * workfeature
oliveroxtoby
ReneSci wrote: Tue Apr 18, 2023 11:29 am Thanks for the valuable info. However, cfdOF still seems to write "backward" instead of "Euler"
No. A mistake when adding DES/LES schemes. Should be fixed now.
