preprocessing and mesh for openfoam
Moderator: oliveroxtoby
julieng
Postby julieng » Sun Dec 23, 2018 11:00 pm
Is there a simple solution to preprocess cases for Openfoam (mesh with Freecad and patches inlet outlet walls)?
I watched some tutorial of Salome allowing to do this but not really with FreeCAD.
I try to preprocess a case with cfdOF and use the polyMesh folder created in Openfoam but it seems to be not easy because of the name of patches.
Any ideas?
Best regards
thschrader
Re: preprocessing and mesh for openfoam
Postby thschrader » Tue Dec 25, 2018 10:55 am
Yes, use the cfdof-wb... :lol:
Can you explain what you want to do with the polymesh-folder?
I do not understand what you mean.
julieng
Postby julieng » Tue Dec 25, 2018 3:57 pm
I want to use some other solvers of openfoam for example for the heat transfer. cfdOF maybe can help me to preprocess cases (geometry and mesh)
In any case, Salome do the job
Best regards
thschrader
Postby thschrader » Tue Dec 25, 2018 5:03 pm
You can define the case with FC-cfdof (geometry, mesh, patches), write the case files
and edit the files (dont close the cfdof GUI). Then run solver.
I mean like this (see picture with the moving inlets):
https://forum.freecadweb.org/viewtopic. ... 6&start=20
oliveroxtoby
Postby oliveroxtoby » Tue Dec 25, 2018 6:14 pm
Best to write the mesh and then also write the case for the solver. Part of the solver setup script that is produced is to rename the raw patches according the names of the boundary conditions.
Please provide all the information requested in this post before reporting problems with CfdOF.
