Problem solving incomp. flow
Moderator: oliveroxtoby
Sidemountyucatan
Postby Sidemountyucatan » Wed Jun 19, 2019 9:27 am
Dear all,
I tried to solve a problem but I got the following error message:
0.0: Checking dependencies...
0.0: OpenFOAM case writer is called
0.2: Write OpenFOAM case is completed
0.1: Starting solver command:
0.1: C:\BLUECF~1\OPENFO~1.X\..\msys64\usr\bin\bash --login -O expand_aliases -c cd "/c/users/t42/appdata/local/temp/case" && ./Allrun
0.1: Solver started
5.0: OpenFOAM fatal error: Cannot find file "points" in directory "polyMesh" in times 0 down to constant
5.0: Simulation exited with error
Due to the fact I am new on CFD and CFDOf especially could someone give me a hint whats gone wrong. I have attached the file.
Thanks a lot !!
Best Regards
Marcus
Mischkammer_CFD.FCStd
(148.17 KiB) Downloaded 16 times
oliveroxtoby
Re: Problem solving incomp. flow
Postby oliveroxtoby » Wed Jun 19, 2019 7:55 pm
Dear all,
0.1: Solver started
Thanks a lot !!
Best Regards
Marcus
I don't get that error. Make sure that you generate the mesh before running the solver.
I get a different (floating point) exception when trying to run the case. I am fairly sure this is because the mesh is too coarse and no mesh faces on the second inlet. Some refinement should fix it.
Please provide all the information requested in this post before reporting problems with CfdOF.
Sidemountyucatan
Postby Sidemountyucatan » Thu Jun 20, 2019 11:25 am
Hi olivertoxoby,
I did another trial with a simpler problem just to investigate the "tricks" and challenges. It is simply a diffusor in between
2 pipes. (I did attach the file aswell). Interestingwise I got a error message too but I cannot evaluate why.
204.7: Simulation exited with error
I did mesh refinement. I used snappyhexmesh as net-tool.
Could you take a look to it and tell me why it wont work ? Would really give me help on my way to better understand the matter.
Thx a lot !
Diffusor.FCStd
(16.07 KiB) Downloaded 14 times
Sidemountyucatan
Postby Sidemountyucatan » Thu Jun 20, 2019 11:50 am
… interestingwise I did make a transient run and than it worked ….. can you give me an indication why ? …….
oliveroxtoby
Postby oliveroxtoby » Fri Jun 21, 2019 5:45 am
Hi olivertoxoby,
Thx a lot !
This was an issue with the CfdOF - we were not writing pressure from the potential flow initialisation, resulting in a large imbalance with the 400 kPa boundary. Should be fixed now.
