Unknown patchField type characteristicWallPressure
Moderator: oliveroxtoby
nic
Postby nic » Sat Jul 06, 2019 7:26 pm
Hello cfdOFoamers!
After successfully solved the elbow tutorial, I simply tried to switch from Incompressible to Compressible + high Mac number, but this lead to an early error (message below).
Any idea?
elbow_DP.FCStd
(28.76 KiB) Downloaded 4 times
Here is the Foam error message
--> FOAM FATAL IO ERROR:
Unknown patchField type characteristicWallPressure for patch type wall
% apt-cache policy openfoam6
openfoam6:
  Installé : 20190620
  Candidat : 20190620
 Table de version :
 *** 20190620 500
OS: Ubuntu 18.10 (i3/i3)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.11.1
Locale: French/Switzerland (fr_CH)
oliveroxtoby
Re: Unknown patchField type characteristicWallPressure
Postby oliveroxtoby » Sat Jul 06, 2019 9:45 pm
Hello cfdOFoamers!
Any idea?
elbow_DP.FCStd
For the moment unfortunately the potential flow initialisation does not work with the compressible solver. Please use specified values instead. Note that pressure must be an absolute pressure value (nonzero) unlike for incompressible flow (likewise for the pressure outlet).
nic
Postby nic » Sun Jul 07, 2019 11:42 am
Hi Oliver; thanks for the answer.
Just to be sure, it is also not supported at the moment to select "Compressible" and un-select "High Mach Number" ; is that correct ?
