Problem installing cfmesh
Moderator: oliveroxtoby
Hi everyone,
I've been trying to install cfmesh but I keep getting errors.
First, error 127 showed but I think I fixed it by doing a : sudo apt-get install make.
But now, error 2 keeps appearing:
make[1]: /home/nil/OpenFOAM/OpenFOAM-v1906/wmake/platforms/linux64Gcc/wmkdepend: Command not found
make[1]: *** Aucune règle pour fabriquer la cible « Make/linux64GccDPInt32Opt/generateBoundaryLayers.C.dep », nécessaire pour « Make/linux64GccDPInt32Opt/generateBoundaryLayers.o ». Arrêt.
make: *** [generateBoundaryLayers] Error 2
make[1]: *** Aucune règle pour fabriquer la cible « Make/linux64GccDPInt32Opt/copySurfaceParts.C.dep », nécessaire pour « Make/linux64GccDPInt32Opt/copySurfaceParts.o ». Arrêt.
make: *** [copySurfaceParts] Error 2
I had a look to my openfoam installation and I couldn't find the problem. Can anyone help me?
Thanks for your help!
OS: Ubuntu 18.04.2 LTS
Version: 0.18.16117 (Git) AppImage
Branch: (HEAD detached at 0.18.2)
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.7
Qt version: 5.6.2
Locale: French/France (fr_FR)
Qt version: 5.6.2
- oliveroxtoby
Re: Problem installing cfmesh
I'm not sure. If you can post the entire output of the build process, I might be able to guess.nil.parent wrote: ↑Thu Aug 08, 2019 1:29 pm Hi everyone,
Please provide all the information requested in this post before reporting problems with CfdOF.
So I tried to changed some stuff in the installation and now I get this:
Running echo $WM_PROJECT_USER_DIR
Raw command: ['bash', '-c', 'source "/home/nil/OpenFOAM/OpenFOAM-v1906/etc/bashrc" && echo $WM_PROJECT_USER_DIR']
/home/nil/OpenFOAM/nil-v1906
Running { mkdir -p "$WM_PROJECT_USER_DIR" && cd "$WM_PROJECT_USER_DIR" && ( rm -r cfmesh-cfdof; unzip -o "/tmp/tmpt9jow2pb"; ); }
Raw command: ['bash', '-c', 'source "/home/nil/OpenFOAM/OpenFOAM-v1906/etc/bashrc" && { mkdir -p "$WM_PROJECT_USER_DIR" && cd "$WM_PROJECT_USER_DIR" && ( rm -r cfmesh-cfdof; unzip -o "/tmp/tmpt9jow2pb"; ); }']
Archive: /tmp/tmpt9jow2pb
creating: cfmesh-cfdof/
inflating: cfmesh-cfdof/.gitignore
creating: cfmesh-cfdof/meshLibrary/
creating: cfmesh-cfdof/meshLibrary/cartesian2DMesh/
creating: cfmesh-cfdof/tutorials/tetMesh/cutCubeOctree/constant/
inflating: cfmesh-cfdof/tutorials/tetMesh/cutCubeOctree/constant/.gitignore
inflating: cfmesh-cfdof/versionInfo.H
inflating: cfmesh-cfdof/buildDefs.include
Running export WM_NCOMPPROCS=`nproc`; ./Allwmake -> log.Allwmake
Raw command: ['bash', '-c', 'source "/home/nil/OpenFOAM/OpenFOAM-v1906/etc/bashrc" && cd "$WM_PROJECT_USER_DIR/cfmesh-cfdof" && { rm log.Allwmake; export WM_NCOMPPROCS=`nproc`; ./Allwmake 1> >(tee -a log.Allwmake) 2> >(tee -a log.Allwmake >&2); }']
rm: impossible de supprimer 'log.Allwmake': Aucun fichier ou dossier de ce type
./Allwmake: 3: ./Allwmake: wmake: Permission denied
./Allwmake: 6: ./Allwmake: wmake: Permission denied
./Allwmake: 9: ./Allwmake: wmake: Permission denied
- oliveroxtoby
Strange. To help debug, please could you execute the following commands in a terminal:nil.parent wrote: ↑Mon Aug 19, 2019 1:32 pm So I tried to changed some stuff in the installation and now I get this:
wmake -help
Here is a first thing that show up in the terminal:
And here is the bashrc file:
Fianlly, here is the output from wmake -help:
Thanks!
No completion added for /home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/bin
#----------------------------------*-sh-*--------------------------------------
# \\ / F ield | OpenFOAM: The Open Source CFD Toolbox
# \\ / O peration |
# \\ / A nd | Copyright (C) 2004-2011, 2016-2019 OpenCFD Ltd.
# \\/ M anipulation |
# | Copyright (C) 2011-2016 OpenFOAM Foundation
# License
# This file is part of OpenFOAM, licensed under GNU General Public License
# <http://www.gnu.org/licenses/>.
# File
# etc/bashrc
# Description
# The OpenFOAM environment for POSIX shell (eg, bash,dash,zsh,...).
# Source manually or from the ~/.bashrc or ~/.profile files.
# Many settings can be overridden using a <prefs.sh> file:
# - Base values (eg, from system admin):
# - $WM_PROJECT_DIR/etc/prefs.sh
# - User or group values (first file found):
# - ~/.OpenFOAM/$FOAM_API/prefs.sh
# - ~/.OpenFOAM/prefs.sh
# - $WM_PROJECT_SITE/$FOAM_API/etc/prefs.sh
# - $WM_PROJECT_SITE/etc/prefs.sh
# Environment
# FOAM_VERBOSE (set/unset)
# - add extra verbosity when sourcing files
# FOAM_CONFIG_NOUSER (set/unset)
# - suppress use of user/group configuration files
# WM_PROJECT_SITE (optional directory)
# - local site-specific directory, uses WM_PROJECT_DIR/site if unset
# Note
# Changes made to this bashrc file may be lost with the next upgrade.
export WM_PROJECT=OpenFOAM
export WM_PROJECT_VERSION=v1906
# [projectDir] - directory containing this OpenFOAM version.
# \- When this file is located as $WM_PROJECT_DIR/etc/bashrc, the next lines
# should work when sourced by BASH or ZSH shells. If this however fails,
# set one of the fallback values to an appropriate path.
# This can be removed if an absolute path is provided for WM_PROJECT_DIR
# later on in this file
projectDir="${BASH_SOURCE:-${ZSH_NAME:+$0}}";
[ -n "$projectDir" ] && projectDir="$(\cd $(dirname $projectDir)/.. && \pwd -L)" ||\
projectDir="$HOME/OpenFOAM/OpenFOAM-$WM_PROJECT_VERSION"
# projectDir="/opt/OpenFOAM/OpenFOAM-$WM_PROJECT_VERSION"
# projectDir="/usr/local/OpenFOAM/OpenFOAM-$WM_PROJECT_VERSION"
# END OF (NORMAL) USER EDITABLE PART
: # Safety statement (if the user removed all fallback values)
# Configuration environment variables.
# Should override via <prefs.sh> file instead of editing this file.
# [WM_COMPILER_TYPE] - Compiler location:
# = system | ThirdParty
export WM_COMPILER_TYPE=system
# [WM_COMPILER] - Compiler:
# = Gcc | Gcc4[8-9] | Gcc5[1-5] | Gcc6[1-5] | Gcc7[1-4] | Gcc8[12] |
# Clang | Clang3[7-9] | Clang[4-6]0 | Icc | Cray | Arm | Pgi
export WM_COMPILER=Gcc
# [WM_PRECISION_OPTION] - Floating-point precision:
# = DP | SP | SPDP
export WM_PRECISION_OPTION=DP
# [WM_LABEL_SIZE] - Label size in bits:
# = 32 | 64
export WM_LABEL_SIZE=32
# [WM_COMPILE_OPTION] - Optimised, debug, profiling, other:
# = Opt | Debug | Prof
# Other is processor or packaging specific, for example
# = OptKNL
export WM_COMPILE_OPTION=Opt
# [WM_MPLIB] - MPI implementation:
# = SYSTEMOPENMPI | OPENMPI | SYSTEMMPI | MPI | MPICH | MPICH-GM |
# HPMPI | CRAY-MPICH | FJMPI | QSMPI | SGIMPI | INTELMPI | USERMPI
# Also possible to use INTELMPI-xyz etc and define your own wmake rule
export WM_MPLIB=SYSTEMOPENMPI
# (advanced / legacy)
# [FOAM_SIGFPE] - Trap floating-point exceptions.
# - overrides the 'trapFpe' controlDict entry
# = true | false
#export FOAM_SIGFPE=true
# [FOAM_SETNAN] - Initialize memory with NaN
# - overrides the 'setNaN' controlDict entry
# = true | false
#export FOAM_SETNAN=false
# [FOAM_CODE_TEMPLATES] - dynamicCode templates
# - unset: uses 'foamEtcFile -list codeTemplates/dynamicCode'
##export FOAM_CODE_TEMPLATES="$WM_PROJECT_DIR/etc/codeTemplates/dynamicCode"
# [FOAM_JOB_DIR] - location of jobControl
# - unset: equivalent to ~/.OpenFOAM/jobControl
# export FOAM_JOB_DIR="$HOME/.OpenFOAM/jobControl"
# [WM_OSTYPE] - Operating System Type
# = POSIX
#export WM_OSTYPE=POSIX
# [WM_ARCH_OPTION] - compiling with -m32 option on 64-bit system
# = 32 | 64
# * on a 64-bit OS this can be 32 or 64
# * on a 32-bit OS this option is ignored (always 32-bit)
#export WM_ARCH_OPTION=64
# Capture values of old directories to be cleaned from PATH, LD_LIBRARY_PATH
foamOldDirs="$WM_PROJECT_DIR $WM_THIRD_PARTY_DIR \
$HOME/$WM_PROJECT/$USER $FOAM_USER_APPBIN $FOAM_USER_LIBBIN \
$WM_PROJECT_SITE $FOAM_SITE_APPBIN $FOAM_SITE_LIBBIN"
# [WM_PROJECT_DIR] - Location of this OpenFOAM version
export WM_PROJECT_DIR="$projectDir"
# [WM_PROJECT_USER_DIR] - Location of user files
export WM_PROJECT_USER_DIR="$HOME/$WM_PROJECT/$USER-$WM_PROJECT_VERSION"
# [WM_PROJECT_SITE] - Location of site-specific (group) files
# Default (unset) implies WM_PROJECT_DIR/site
# Normally defined in calling environment
# Finalize setup of OpenFOAM environment for POSIX shell
if [ -d "$WM_PROJECT_DIR" ]
then
if [ -n "$FOAM_VERBOSE" ] && [ -n "$PS1" ]
then
echo "source $WM_PROJECT_DIR/etc/config.sh/setup" 1>&2
fi
. "$WM_PROJECT_DIR/etc/config.sh/setup" "$@"
else
echo "Error: did not locate installation path for $WM_PROJECT-$WM_PROJECT_VERSION" 1>&2
echo "No directory: $WM_PROJECT_DIR" 1>&2
fi
# Cleanup variables (done as final statement for a clean exit code)
unset foamOldDirs projectDir
(base) nil@nil-laptop-Asus:~/OpenFOAM/OpenFOAM-v1906/etc$ wmake -help
Usage: wmake [OPTION] [dir]
wmake [OPTION] target [dir [MakeDir]]
options:
-s | -silent Quiet mode (does not echo commands)
-a | -all wmake all sub-directories, running Allwmake if present
-q | -queue wmakeCollect all sub-directories, running Allwmake if present
-k | -keep-going Keep going even when errors occur (-non-stop)
-debug Define c++DBUG='-DFULLDEBUG -g -O0' as override
-j Compile using all local cores/hyperthreads
-jN | -j N Compile using N cores/hyperthreads
-no-scheduler Disable scheduled parallel compilation
-pwd Print root directory containing a Make/ directory
-update Update lnInclude dirs, dep files, remove deprecated files/dirs
-show-api Print api value
-show-ext-so Print shared library extension (with '.' separator)
-show-compile-c Same as '-show-c -show-cflags'
-show-compile-cxx Same as '-show-cxx -show-cxxflags'
-show-c Print C compiler value
-show-cflags Print C compiler flags
-show-cxx Print C++ compiler value
-show-cxxflags Print C++ compiler flags
-show-cflags-arch The C compiler arch flag (eg, -m64 etc)
-show-cxxflags-arch The C++ compiler arch flag (eg, -m64 etc)
-h | -help Print the usage
A general, easy-to-use make system for multi-platform development
with support for local and network parallel compilation.
The 'target' is a Makefile target:
e.g., platforms/linux64GccDPOpt/.../fvMesh.o
or a special target:
exe Compile statically linked executable
lib Compile statically linked archive lib (.a)
libo Compile statically linked lib (.o)
libso Compile dynamically linked lib (.so)
dep Compile lnInclude and dependencies only
updatedep Compile dependencies only (in case of broken dependencies)
objects Compile but not link
- oliveroxtoby
It looks like this problem could indicate a too-old version of bash, or possibly even that OpenFOAM is not compiled: https://www.cfd-online.com/Forums/openf ... v1712.htmlnil.parent wrote: ↑Sun Sep 08, 2019 9:54 am Here is a first thing that show up in the terminal:Code: Select all
I don't know if this is the cause of the original issue, but it is the only theory I have...
So I have reinstalled and recompiled openFOAM,
However I keep getting errors with wmakedepend : could not open.
And also this one:
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FMSToVTK] Error 1
make: *** [FMSToVTK] Error 2
Here is the raw output of the cfMesh installation:
Thank you again for your help and your time, I am a beginner regarding all this
Nil
And also this one:
wmake libso meshLibrary
ln: ./lnInclude
/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c utilities/meshes/polyMeshGenModifier/polyMeshGenModifierRenumberMesh.C -o Make/linux64GccDPInt64Opt/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierRenumberMesh.o
In file included from lnInclude/DynList.H:254:0,
from lnInclude/VRWGraph.H:42,
from lnInclude/meshSubset.H:44,
from lnInclude/polyMeshGenPoints.H:49,
from lnInclude/polyMeshGenFaces.H:40,
from lnInclude/polyMeshGenCells.H:40,
from lnInclude/polyMeshGen.H:39,
from utilities/meshes/polyMeshGenModifier/polyMeshGenModifier.H:40,
from utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.C:28:
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = long int; long int staticSize = 16]’:
lnInclude/helperFunctionsTopologyManipulationI.H:491:34: required from here
lnInclude/DynListI.H:195:15: error: request for member ‘size’ in ‘l’, which is of non-class type ‘const int’
setSize(l.size());
lnInclude/DynListI.H:197:32: error: subscripted value is neither array nor pointer
this->operator[](i) = l[i];
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6]’:
lnInclude/helperFunctionsGeometryQueriesI.H:1259:37: required from here
setSize(l.size());
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DUSE_OMP -fopenmp -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c utilities/meshes/polyMeshGenModifier
-lmeshTools -lsurfMesh -L/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/lib -lmeshLibrary -lOpenFOAM -ldl \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/pMesh
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/tetMesh.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/tetMesh
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/cartesianMesh.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/cartesianMesh
Make/linux64GccDPInt64Opt/tetMesh.o : Dans la fonction « main » :
tetMesh.C:(.text.startup+0x150) : référence indéfinie vers « Foam::tetMeshGenerator::tetMeshGenerator(Foam::Time const&) »
tetMesh.C:(.text.startup+0x1c5) : référence indéfinie vers « Foam::tetMeshGenerator::writeMesh() const »
tetMesh.C:(.text.startup+0x1ec) : référence indéfinie vers « Foam::tetMeshGenerator::~tetMeshGenerator() »
tetMesh.C:(.text.startup+0x234) : référence indéfinie vers « Foam::tetMeshGenerator::~tetMeshGenerator() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/tetMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'tetMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/pMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'pMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/cartesian2DMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'cartesian2DMesh' failed
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/tetMesh] Error 1
Make/linux64GccDPInt64Opt/pMesh.o : Dans la fonction « main » :
pMesh.C:(.text.startup+0x150) : référence indéfinie vers « Foam::voronoiMeshGenerator::voronoiMeshGenerator(Foam::Time const&) »
pMesh.C:(.text.startup+0x1c5) : référence indéfinie vers « Foam::voronoiMeshGenerator::writeMesh() const »
pMesh.C:(.text.startup+0x1ec) : référence indéfinie vers « Foam::voronoiMeshGenerator::~voronoiMeshGenerator() »
pMesh.C:(.text.startup+0x234) : référence indéfinie vers « Foam::voronoiMeshGenerator::~voronoiMeshGenerator() »
make: *** [tetMesh] Error 2
make: *** Attente des tâches non terminées....
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/pMesh] Error 1
make: *** [pMesh] Error 2
Make/linux64GccDPInt64Opt/cartesian2DMesh.o : Dans la fonction « main » :
cartesian2DMesh.C:(.text.startup+0x150) : référence indéfinie vers « Foam::cartesian2DMeshGenerator::cartesian2DMeshGenerator(Foam::Time const&) »
cartesian2DMesh.C:(.text.startup+0x1d4) : référence indéfinie vers « Foam::cartesian2DMeshGenerator::writeMesh() const »
cartesian2DMesh.C:(.text.startup+0x1fb) : référence indéfinie vers « Foam::cartesian2DMeshGenerator::~cartesian2DMeshGenerator() »
cartesian2DMesh.C:(.text.startup+0x243) : référence indéfinie vers « Foam::cartesian2DMeshGenerator::~cartesian2DMeshGenerator() »
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/cartesian2DMesh] Error 1
make: *** [cartesian2DMesh] Error 2
Make/linux64GccDPInt64Opt/cartesianMesh.o : Dans la fonction « main » :
cartesianMesh.C:(.text.startup+0x240) : référence indéfinie vers « Foam::cartesianMeshGenerator::cartesianMeshGenerator(Foam::Time const&) »
cartesianMesh.C:(.text.startup+0x2c2) : référence indéfinie vers « Foam::cartesianMeshGenerator::writeMesh() const »
cartesianMesh.C:(.text.startup+0x2e9) : référence indéfinie vers « Foam::cartesianMeshGenerator::~cartesianMeshGenerator() »
cartesianMesh.C:(.text.startup+0x407) : référence indéfinie vers « Foam::cartesianMeshGenerator::~cartesianMeshGenerator() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/cartesianMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'cartesianMesh' failed
wmake utilities
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/cartesianMesh] Error 1
make: *** [cartesianMesh] Error 2
wmake FMSToSurface
wmake extrudeEdgesInto2DSurface
wmake checkSurfaceMesh
wmake FLMAToSurface
wmake importSurfaceAsSubset
wmake generateBoundaryLayers
wmake copySurfaceParts
wmake FMSToVTK
Making dependency list for source file FLMAToSurface.C
Making dependency list for source file copySurfaceParts.C
Making dependency list for source file extrudeEdgesInto2DSurface.C
Making dependency list for source file generateBoundaryLayers.C
Making dependency list for source file FMSToVTK.C
wmkdepend: could not open 'HashSet.T.H' for source file 'FLMAToSurface.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'FLMAToSurface.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'FLMAToSurface.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'FLMAToSurface.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'copySurfaceParts.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'copySurfaceParts.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'copySurfaceParts.C': No such file or directory
wmkdepend: could not open 'foamTime.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'Time.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'copySurfaceParts.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'Istream.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'SubList.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'extrudeEdgesInto2DSurface.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'extrudeEdgesInto2DSurface.C': No such file or directory
wmkdepend: could not open 'FixedList.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'extrudeEdgesInto2DSurface.C': No such file or directory
wmkdepend: could not open 'face.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'Pair.T.H' for source file 'generateBoundaryLayers.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'FMSToVTK.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'extrudeEdgesInto2DSurface.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'FMSToVTK.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'FMSToVTK.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'FMSToVTK.C': No such file or directory
wmkdepend: could not open 'HashTable.T.H' for source file 'FMSToVTK.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'importSurfaceAsSubset.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'importSurfaceAsSubset.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'importSurfaceAsSubset.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'importSurfaceAsSubset.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'FMSToSurface.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'FMSToSurface.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'FMSToSurface.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'FMSToSurface.C': No such file or directory
wmkdepend: could not open 'HashSet.T.H' for source file 'checkSurfaceMesh.C': No such file or directory
wmkdepend: could not open 'token.T.H' for source file 'checkSurfaceMesh.C': No such file or directory
wmkdepend: could not open 'UList.T.H' for source file 'checkSurfaceMesh.C': No such file or directory
wmkdepend: could not open 'Map.T.H' for source file 'checkSurfaceMesh.C': No such file or directory
Making dependency list for source file checkSurfaceMesh.C
Making dependency list for source file importSurfaceAsSubset.C
Making dependency list for source file FMSToSurface.C
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c FLMAToSurface.C -o Make/linux64GccDPInt64Opt/FLMAToSurface.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c copySurfaceParts.C -o Make/linux64GccDPInt64Opt/copySurfaceParts.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c extrudeEdgesInto2DSurface.C -o Make/linux64GccDPInt64Opt/extrudeEdgesInto2DSurface.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c FMSToVTK.C -o Make/linux64GccDPInt64Opt/FMSToVTK.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c FMSToSurface.C -o Make/linux64GccDPInt64Opt/FMSToSurface.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c generateBoundaryLayers.C -o Make/linux64GccDPInt64Opt/generateBoundaryLayers.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c importSurfaceAsSubset.C -o Make/linux64GccDPInt64Opt/importSurfaceAsSubset.o
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c checkSurfaceMesh.C -o Make/linux64GccDPInt64Opt/checkSurfaceMesh.o
In file included from ../../meshLibrary/lnInclude/DynList.H:254:0,
from ../../meshLibrary/lnInclude/VRWGraph.H:42,
from ../../meshLibrary/lnInclude/meshSubset.H:44,
from ../../meshLibrary/lnInclude/polyMeshGenPoints.H:49,
from ../../meshLibrary/lnInclude/polyMeshGenFaces.H:40,
from ../../meshLibrary/lnInclude/polyMeshGenCells.H:40,
from ../../meshLibrary/lnInclude/polyMeshGen.H:39,
from ../../meshLibrary/lnInclude/polyMeshGenModifier.H:40,
from generateBoundaryLayers.C:31:
../../meshLibrary/lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = long int; long int staticSize = 16]’:
../../meshLibrary/lnInclude/helperFunctionsTopologyManipulationI.H:491:34: required from here
../../meshLibrary/lnInclude/DynListI.H:195:15: error: request for member ‘size’ in ‘l’, which is of non-class type ‘const int’
setSize(l.size());
../../meshLibrary/lnInclude/DynListI.H:197:32: error: subscripted value is neither array nor pointer
../../meshLibrary/lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6]’:
../../meshLibrary/lnInclude/helperFunctionsGeometryQueriesI.H:1259:37: required from here
setSize(l.size());
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/extrudeEdgesInto2DSurface.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/extrudeEdgesInto2DSurface
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/copySurfaceParts.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/copySurfaceParts
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/importSurfaceAsSubset.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/importSurfaceAsSubset
Make/linux64GccDPInt64Opt/extrudeEdgesInto2DSurface.o : Dans la fonction « main » :
extrudeEdgesInto2DSurface.C:(.text.startup+0x20a) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
extrudeEdgesInto2DSurface.C:(.text.startup+0x21a) : référence indéfinie vers « Foam::triSurfaceExtrude2DEdges::triSurfaceExtrude2DEdges(Foam::triSurf const&) »
extrudeEdgesInto2DSurface.C:(.text.startup+0x222) : référence indéfinie vers « Foam::triSurfaceExtrude2DEdges::extrudeSurface() const »
extrudeEdgesInto2DSurface.C:(.text.startup+0x239) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
extrudeEdgesInto2DSurface.C:(.text.startup+0x246) : référence indéfinie vers « Foam::triSurf::~triSurf() »
extrudeEdgesInto2DSurface.C:(.text.startup+0x281) : référence indéfinie vers « Foam::triSurfaceExtrude2DEdges::~triSurfaceExtrude2DEdges() »
extrudeEdgesInto2DSurface.C:(.text.startup+0x289) : référence indéfinie vers « Foam::triSurf::~triSurf() »
extrudeEdgesInto2DSurface.C:(.text.startup+0x385) : référence indéfinie vers « Foam::triSurfaceExtrude2DEdges::~triSurfaceExtrude2DEdges() »
extrudeEdgesInto2DSurface.C:(.text.startup+0x38d) : référence indéfinie vers « Foam::triSurf::~triSurf() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/extrudeEdgesInto2DSurface' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'extrudeEdgesInto2DSurface' failed
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/extrudeEdgesInto2DSurface] Error 1
make: *** [extrudeEdgesInto2DSurface] Error 2
Make/linux64GccDPInt64Opt/copySurfaceParts.o : Dans la fonction « main » :
copySurfaceParts.C:(.text.startup+0x28f) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
copySurfaceParts.C:(.text.startup+0x29f) : référence indéfinie vers « Foam::triSurfaceCopyParts::triSurfaceCopyParts(Foam::triSurf const&) »
copySurfaceParts.C:(.text.startup+0x2af) : référence indéfinie vers « Foam::triSurf::triSurf() »
copySurfaceParts.C:(.text.startup+0x2c6) : référence indéfinie vers « Foam::triSurfaceCopyParts::copySurface(Foam::List<Foam::word> const&, Foam::triSurf&) const »
copySurfaceParts.C:(.text.startup+0x2d1) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
copySurfaceParts.C:(.text.startup+0x304) : référence indéfinie vers « Foam::triSurf::~triSurf() »
copySurfaceParts.C:(.text.startup+0x30c) : référence indéfinie vers « Foam::triSurfaceCopyParts::~triSurfaceCopyParts() »
copySurfaceParts.C:(.text.startup+0x314) : référence indéfinie vers « Foam::triSurf::~triSurf() »
copySurfaceParts.C:(.text.startup+0x47d) : référence indéfinie vers « Foam::triSurf::~triSurf() »
copySurfaceParts.C:(.text.startup+0x48d) : référence indéfinie vers « Foam::triSurfaceCopyParts::~triSurfaceCopyParts() »
copySurfaceParts.C:(.text.startup+0x495) : référence indéfinie vers « Foam::triSurf::~triSurf() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/copySurfaceParts' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'copySurfaceParts' failed
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/copySurfaceParts] Error 1
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/FLMAToSurface.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FLMAToSurface
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/checkSurfaceMesh.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/checkSurfaceMesh
Make/linux64GccDPInt64Opt/importSurfaceAsSubset.o : Dans la fonction « main » :
importSurfaceAsSubset.C:(.text.startup+0x20c) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
importSurfaceAsSubset.C:(.text.startup+0x224) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
importSurfaceAsSubset.C:(.text.startup+0x239) : référence indéfinie vers « Foam::triSurfaceImportSurfaceAsSubset::triSurfaceImportSurfaceAsSubset(Foam::triSurf&) »
importSurfaceAsSubset.C:(.text.startup+0x2e8) : référence indéfinie vers « Foam::triSurfaceImportSurfaceAsSubset::addSurfaceAsSubset(Foam::triSurf const&, Foam::word const&, double) »
importSurfaceAsSubset.C:(.text.startup+0x35b) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
importSurfaceAsSubset.C:(.text.startup+0x388) : référence indéfinie vers « Foam::triSurfaceImportSurfaceAsSubset::~triSurfaceImportSurfaceAsSubset() »
importSurfaceAsSubset.C:(.text.startup+0x392) : référence indéfinie vers « Foam::triSurf::~triSurf() »
importSurfaceAsSubset.C:(.text.startup+0x39a) : référence indéfinie vers « Foam::triSurf::~triSurf() »
importSurfaceAsSubset.C:(.text.startup+0x485) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
importSurfaceAsSubset.C:(.text.startup+0x74d) : référence indéfinie vers « Foam::triSurfaceImportSurfaceAsSubset::~triSurfaceImportSurfaceAsSubset() »
importSurfaceAsSubset.C:(.text.startup+0x757) : référence indéfinie vers « Foam::triSurf::~triSurf() »
importSurfaceAsSubset.C:(.text.startup+0x75f) : référence indéfinie vers « Foam::triSurf::~triSurf() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/importSurfaceAsSubset' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'importSurfaceAsSubset' failed
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/importSurfaceAsSubset] Error 1
make: *** [importSurfaceAsSubset] Error 2
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/FMSToSurface.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FMSToSurface
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/checkSurfaceMesh' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'checkSurfaceMesh' failed
Make/linux64GccDPInt64Opt/checkSurfaceMesh.o : Dans la fonction « main » :
checkSurfaceMesh.C:(.text.startup+0x2c6) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
checkSurfaceMesh.C:(.text.startup+0x333) : référence indéfinie vers « Foam::triSurfaceChecks::calculateBoundingBox(Foam::triSurf const&, Foam::boundBox&) »
checkSurfaceMesh.C:(.text.startup+0x4c8) : référence indéfinie vers « Foam::triSurfaceChecks::checkSurfaceManifolds(Foam::triSurf&, Foam::word) »
checkSurfaceMesh.C:(.text.startup+0x5c2) : référence indéfinie vers « Foam::triSurfaceChecks::checkForHoles(Foam::triSurf&, Foam::word) »
checkSurfaceMesh.C:(.text.startup+0x684) : référence indéfinie vers « Foam::triSurfaceChecks::checkForNonManifoldEdges(Foam::triSurf&, Foam::word) »
checkSurfaceMesh.C:(.text.startup+0x728) : référence indéfinie vers « Foam::triSurfaceChecks::checkDisconnectedParts(Foam::triSurf&, Foam::word) »
checkSurfaceMesh.C:(.text.startup+0x7d5) : référence indéfinie vers « Foam::triSurfaceChecks::checkAngles(Foam::triSurf&, Foam::word, double) »
checkSurfaceMesh.C:(.text.startup+0x87f) : référence indéfinie vers « Foam::triSurfaceChecks::checkSelfIntersections(Foam::triSurf&, Foam::word, double) »
checkSurfaceMesh.C:(.text.startup+0x940) : référence indéfinie vers « Foam::triSurfaceChecks::checkOverlaps(Foam::triSurf&, Foam::word, double, double) »
checkSurfaceMesh.C:(.text.startup+0x9df) : référence indéfinie vers « Foam::triSurfaceChecks::checkCollocatedPoints(Foam::triSurf&, Foam::word, double) »
checkSurfaceMesh.C:(.text.startup+0xaee) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
checkSurfaceMesh.C:(.text.startup+0xb15) : référence indéfinie vers « Foam::triSurf::~triSurf() »
checkSurfaceMesh.C:(.text.startup+0x1022) : référence indéfinie vers « Foam::triSurf::~triSurf() »
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/checkSurfaceMesh] Error 1
make: *** [checkSurfaceMesh] Error 2
Make/linux64GccDPInt64Opt/FLMAToSurface.o : Dans la fonction « main » :
FLMAToSurface.C:(.text.startup+0x32b) : référence indéfinie vers « Foam::triSurf::triSurf() »
FLMAToSurface.C:(.text.startup+0x340) : référence indéfinie vers « Foam::triSurfModifier::triSurfModifier(Foam::triSurf&) »
FLMAToSurface.C:(.text.startup+0x700) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
FLMAToSurface.C:(.text.startup+0x75e) : référence indéfinie vers « Foam::triSurfModifier::~triSurfModifier() »
FLMAToSurface.C:(.text.startup+0x768) : référence indéfinie vers « Foam::triSurf::~triSurf() »
FLMAToSurface.C:(.text.startup+0x978) : référence indéfinie vers « Foam::triSurfFacets::addFacetSubset(Foam::word const&) »
FLMAToSurface.C:(.text.startup+0xb92) : référence indéfinie vers « Foam::triSurfModifier::~triSurfModifier() »
FLMAToSurface.C:(.text.startup+0xb9c) : référence indéfinie vers « Foam::triSurf::~triSurf() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FLMAToSurface' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'FLMAToSurface' failed
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FLMAToSurface] Error 1
make: *** [FLMAToSurface] Error 2
Make/linux64GccDPInt64Opt/FMSToSurface.o : Dans la fonction « main » :
FMSToSurface.C:(.text.startup+0x3ce) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
FMSToSurface.C:(.text.startup+0x3db) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
FMSToSurface.C:(.text.startup+0x47a) : référence indéfinie vers « Foam::triSurf::~triSurf() »
FMSToSurface.C:(.text.startup+0x5e5) : référence indéfinie vers « Foam::triSurfaceCopyParts::triSurfaceCopyParts(Foam::triSurf const&) »
FMSToSurface.C:(.text.startup+0x626) : référence indéfinie vers « Foam::triSurf::triSurf() »
FMSToSurface.C:(.text.startup+0x691) : référence indéfinie vers « Foam::triSurfFacets::facetSubsetName(long) const »
FMSToSurface.C:(.text.startup+0x739) : référence indéfinie vers « Foam::triSurfaceCopyParts::copySurface(Foam::List<Foam::word> const&, Foam::triSurf&) const »
FMSToSurface.C:(.text.startup+0x976) : référence indéfinie vers « Foam::triSurf::writeSurface(Foam::fileName const&) const »
FMSToSurface.C:(.text.startup+0x9df) : référence indéfinie vers « Foam::triSurf::~triSurf() »
FMSToSurface.C:(.text.startup+0xa02) : référence indéfinie vers « Foam::triSurfaceCopyParts::~triSurfaceCopyParts() »
FMSToSurface.C:(.text.startup+0x1218) : référence indéfinie vers « Foam::triSurf::~triSurf() »
FMSToSurface.C:(.text.startup+0x1222) : référence indéfinie vers « Foam::triSurfaceCopyParts::~triSurfaceCopyParts() »
FMSToSurface.C:(.text.startup+0x1234) : référence indéfinie vers « Foam::triSurf::~triSurf() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FMSToSurface' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'FMSToSurface' failed
make[1]: *** [/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FMSToSurface] Error 1
make: *** [FMSToSurface] Error 2
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt64Opt/generateBoundaryLayers.o' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'generateBoundaryLayers' failed
make[1]: *** [Make/linux64GccDPInt64Opt/generateBoundaryLayers.o] Error 1
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -DOpenCFDSpecific -DFOAM_VERSION_1906 -DNoSizeType -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/triSurface/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/surfMesh/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/home/nil/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/FMSToVTK.o -L/home/nil/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib \
-lm -o /home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FMSToVTK
Make/linux64GccDPInt64Opt/FMSToVTK.o : Dans la fonction « main » :
FMSToVTK.C:(.text.startup+0x227) : référence indéfinie vers « Foam::triSurf::triSurf(Foam::fileName const&) »
FMSToVTK.C:(.text.startup+0x1401) : référence indéfinie vers « Foam::triSurfPoints::pointSubsetName(long) const »
FMSToVTK.C:(.text.startup+0x1a08) : référence indéfinie vers « Foam::triSurfFeatureEdges::edgeSubsetName(long) const »
FMSToVTK.C:(.text.startup+0x2015) : référence indéfinie vers « Foam::triSurfFacets::facetSubsetName(long) const »
FMSToVTK.C:(.text.startup+0x2508) : référence indéfinie vers « Foam::triSurf::~triSurf() »
FMSToVTK.C:(.text.startup+0x3d96) : référence indéfinie vers « Foam::triSurf::~triSurf() »
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:140: recipe for target '/home/nil/OpenFOAM/nil-v1906/platforms/linux64GccDPInt64Opt/bin/FMSToVTK' failed
/home/nil/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: recipe for target 'FMSToVTK' failed
Nil
Is there a solution??
- oliveroxtoby
Really not sure what the problem could be. Can you confirm that your openfoam compilation completed without error. Re-run ./Allwmake from your OpenFOAM directory and ensure that no error messages appear. What output do you get if you run an openfoam command like
snappyHexMesh -help
Hi Oliver!
Thank you for your answer, I re-runned ./Allwmake and here is the output :
I also runned the snappyHex mesh command :
Thank you very much for your help!
2019-10-14 13:17:55 +0200
Finished compile of cfMesh with OpenFOAM-v1906
Gcc system compiler
linux64GccDPInt32Opt, with SYSTEMOPENMPI openmpi-system
wmake doc
skip wmake target for modules doxygen directory
OpenFOAM-v1906
Gcc system compiler
api = 1906
patch = 0
bin = 285 entries
lib = 129 entries
(base) nil@nil-laptop-Asus:~/OpenFOAM/OpenFOAM-v1906$ snappyHexMesh -help
Usage: snappyHexMesh [OPTIONS]
Options:
-case <dir> Specify case directory to use (instead of the cwd)
-checkGeometry Check all surface geometry for quality
-decomposeParDict <file>
Use specified file for decomposePar dictionary
-dict <file> Use alternative snappyHexMeshDict
-dry-run Check case set-up only using a single time step
-outFile <file> Name of the file to save the simplified surface to
-overwrite Overwrite existing mesh/results files
-parallel Run in parallel
-patches <(patch0 .. patchN)>
Only triangulate selected patches (wildcards supported)
-profiling Activate application-level profiling
-region <name> Specify alternative mesh region
-surfaceSimplify <boundBox>
Simplify the surface using snappyHexMesh starting from a
boundBox
-doc Display documentation in browser
-help Display short help and exit
-help-compat Display compatibility options and exit
-help-full Display full help and exit
Automatic split hex mesher. Refines and snaps to surface
Using: OpenFOAM-v1906 (1906) (see www.OpenFOAM.com)
Build: v1906
Arch: LSB;label=32;scalar=64
