I'm having an issue with running the solver on a fresh install of FreeCAD / CfdOF. This is the case for all attempted geometries, including the Viscous Tube Bundle from the tutorials, which is the model I am currently trying to get to run. Study was setup using the Macro from the tutorials page.
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Dependencies check passes okay. Plot workbench is installed.
Writing mesh case and running mesher is fine. Writing the analysis case is fine. However, when I click Solver > Run, the following errors are returned in the Report View
File "C:\Users\dlaban\AppData\Roaming\FreeCAD\Mod\CfdOF\_TaskPanelCfdSolverControl.py", line 152, in runSolverProcess
cmd = self.solver_runner.get_solver_cmd(solverDirectory)
File "C:\Users\dlaban\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdRunnableFoam.py", line 93, in get_solver_cmd
self.residualPlot = ResidualPlot()
File "C:\Users\dlaban\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdResidualPlot.py", line 37, in __init__
self.fig = Plot.figure(FreeCAD.ActiveDocument.Name + "Residuals")
AttributeError: module 'Plot' has no attribute 'figure'
No messages are presented in the Analysis Control Status pane (no "exited with error" for instance), and it was only upon turning on the Report View that I even knew it was doing anything, I just thought the button was non-functional.
I have attached the .py files mentioned in the error messages.
Does this indicate any kind of installation issue? I am running on a limited user account so had to use the Elevate Permissions dialog during installation, I am wondering if that prevented install of a critical component maybe?
