Save a STL file with multi-regions
Moderator: oliveroxtoby
wandererfan
Re: Save a STL file with multi-regions
Postby wandererfan » Sun Aug 21, 2016 12:12 pm
virengos
Postby virengos » Tue Oct 25, 2016 2:12 pm
I just came across this topic, and would like to contribute my own thoughts on the matter.
One other possibility is to export all the single regions to separate files and merge it outside of FreeCAD by using the 'cat' command in terminal (when using Linux) or the 'type' command (when using Windows).
cat obj1.stl ob2.stl obj3.stl > all_obj.stl
That's my approach, and it works for me when dealing with Open FOAM, meshing and CFD.
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
fynn
Postby fynn » Tue Jan 24, 2017 1:08 pm
I am facing the same issue as many cfd-people in this forum: For flow simulations in OpenFoam I need to be able to export the surfaces of my geometry individually as either .stl or .obj files, since the different surfaces will be assigned to different boundary conditions. As virengos suggests, the files can then be collected or imported to OpenFoam individually.
The big advantage of freeCad for cfd applications would be the treatment of geometry surfaces as part objects allowing their individual export.
This is the one reason why I tested freeCad. Until now, only the cad editor of Comsol Multiphysics allows me to do just that.
jbi
Postby jbi » Fri Mar 17, 2017 5:20 pm
I just stumbled across this thread. If I understand it right, only a Export of each single face of a shape is needed. This can be done with a macro.
# Purpose:     export each face of a selected shape to .stl file
#paste the import statements first:
import FreeCADGui
from FreeCAD import Base, Console
import FreeCAD
import Part
import DraftGeomUtils
import Draft
import time
import math
import os
#pre work: just create a folder tmp in FreeCAD 0.15 folder, single faces will be saved here
#first: select the shape for exporting and paste this 2 lines into the console and hit enter
sw = FreeCADGui.Selection.getSelectionEx()[0]
obj = sw.Object.Shape
#second: paste following lines into the console
for face in obj.Faces:
	unique=str(time.time())
	hash=str(face.hashCode())
	#edit your filename here
	filename='D:\\Anwenderprogramme\\FreeCAD 0.15\\tmp\\001_TIME_'+unique+'_Hash_'+hash+'.stl' #create unique filename
	face.exportStl(filename,0.3)
	parameters for stl export can be found here: search "exportSTL"
	at https://github.com/FreeCAD/FreeCAD/blob/4664e5bb483404b064e8de59ce0ca3161482e9a1/src/Mod/Part/App/TopoShapePyImp.cpp
#single file for each face is created in D:\\Anwenderprogramme\\FreeCAD 0.15\\tmp folder
#single faces can be selected too, just select the face of interest:
sf = FreeCADGui.Selection.getSelectionEx()[0]
face=sf.SubObjects[0]	#sf.Object.Shape
You can also create a macro and add a button to the gui. A lot of Information how this can be done can be found here and https://www.freecadweb.org/wiki/Online_Help_Toc here.
I hope this helps.
johan
Postby johan » Thu Jun 01, 2017 9:14 am
The new CFD WB might provide some help in this regard: https://forum.freecadweb.org/viewtopic. ... 6&start=40
It creates a multi-element stl instead of exporting separate stl files for the faces. This ensures a watertight geometry and allows for feature edge extraction.
bernd
Postby bernd » Thu Dec 14, 2017 7:34 am
this is may be interesting in the regard of this topic ... https://forum.freecadweb.org/viewtopic.php?f=3&t=16855
