Thanks for the input. I have narrowed down the issues with openfoam docker to the corporate permissions on my laptop (it seems I may be able to make docker work as they have an exception for docker but not for docker toolkit - which is what openfoam was installing) and so have switched to the bluecfd approach.
For blue CFD I have it installed and can launch the terminal and can run in the terminal
Checking CFD workbench dependencies...
Checking FreeCAD version
Checking for OpenFOAM:
Running echo $WM_PROJECT_VERSION
Raw command: ['C:/Program Files/FreeCAD 0.18/bin\\python.exe', '-u', 'C:\\Users\\<username>\\AppData\\Roaming\\FreeCAD\\Mod\\CfdOF\\WindowsRunWrapper.py', 'C:\\Program Files\\blueCFD-Core-2017\\msys64\\usr\\bin\\bash', '--login', '-O', 'expand_aliases', '-c', 'echo Sourcing OpenFOAM environment...; source $HOME/OpenFOAM/OpenFOAM-vblueCFD-Core-2017/etc/bashrc; export PATH=$FOAM_LIBBIN/msmpi:$FOAM_LIBBIN:$WM_THIRD_PARTY_DIR/platforms/linux64MingwDPInt32/lib:$PATH; echo $WM_PROJECT_VERSION']
Setting environment for OpenFOAM 5.x mingw-w64 Double Precision (of5-64), using MSMPI71 - please wait...
Your "mingw_w64" operating system is not supported by the modifications
made to OpenFOAM. For further assistance, please report at:
https://github.com/blueCFD/Core/issues
which: no gcc.exe in (/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/bin:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/wmake:/usr/local/bin:/usr/bin:/bin:/opt/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/ofuser/AddOns/notepad2:/home/ofuser/AddOns/ParaView/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/lib:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/dummy:)
Usage: cygpath (-d|-m|-u|-w|-t TYPE) [-f FILE] [OPTION]... NAME...
cygpath [-c HANDLE]
cygpath [-ADHOPSW]
cygpath [-F ID]
Convert Unix and Windows format paths, or output system path information
Output type options:
-d, --dos print DOS (short) form of NAMEs (C:\PROGRA~1\)
-m, --mixed like --windows, but with regular slashes (C:/WINNT)
-M, --mode report on mode of file (binmode or textmode)
-u, --unix (default) print Unix form of NAMEs (/cygdrive/c/winnt)
-w, --windows print Windows form of NAMEs (C:\WINNT)
-t, --type TYPE print TYPE form: 'dos', 'mixed', 'unix', or 'windows'
Path conversion options:
-a, --absolute output absolute path
-l, --long-name print Windows long form of NAMEs (with -w, -m only)
-p, --path NAME is a PATH list (i.e., '/bin:/usr/bin')
-U, --proc-cygdrive Emit /proc/cygdrive path instead of cygdrive prefix
when converting Windows path to UNIX path.
-s, --short-name print DOS (short) form of NAMEs (with -w, -m only)
-C, --codepage CP print DOS, Windows, or mixed pathname in Windows
codepage CP. CP can be a numeric codepage identifier,
or one of the reserved words ANSI, OEM, or UTF8.
If this option is missing, cygpath defaults to the
character set defined by the current locale.
System information:
-A, --allusers use `All Users' instead of current user for -D, -O, -P
-D, --desktop output `Desktop' directory and exit
-H, --homeroot output `Profiles' directory (home root) and exit
-O, --mydocs output `My Documents' directory and exit
-P, --smprograms output Start Menu `Programs' directory and exit
-S, --sysdir output system directory and exit
-W, --windir output `Windows' directory and exit
-F, --folder ID output special folder with numeric ID and exit
Try `cygpath --help' for more information.
which: no g++.exe in (/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/bin:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/wmake:/usr/local/bin:/usr/bin:/bin:/opt/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/ofuser/AddOns/notepad2:/home/ofuser/AddOns/ParaView/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/lib:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/dummy:)
cygpath [-c HANDLE]
cygpath [-ADHOPSW]
cygpath [-F ID]
System information:
which: no ld.exe in (/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/bin:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/wmake:/usr/local/bin:/usr/bin:/bin:/opt/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/ofuser/AddOns/notepad2:/home/ofuser/AddOns/ParaView/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/lib:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/dummy:)
cygpath [-c HANDLE]
cygpath [-ADHOPSW]
cygpath [-F ID]
System information:
which: no objdump.exe in (/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/bin:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/bin:/home/ofuser/blueCFD/OpenFOAM-5.x/wmake:/usr/local/bin:/usr/bin:/bin:/opt/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/ofuser/AddOns/notepad2:/home/ofuser/AddOns/ParaView/bin:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/gperftools-svn/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib/MS-MPI-7.1:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64Gcc/MS-MPI-7.1/lib:/home/ofuser/blueCFD/ofuser-of5/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/site/5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib:/home/ofuser/blueCFD/ThirdParty-5.x/platforms/mingw_w64GccDPInt32/lib:/home/ofuser/blueCFD/OpenFOAM-5.x/platforms/mingw_w64GccDPInt32Opt/lib/dummy:)
cygpath [-c HANDLE]
cygpath [-ADHOPSW]
cygpath [-F ID]
System information:
