17:25:41 Executing: C:\Users\scotth\AppData\Roaming\ESI-OpenCFD\OpenFOAM\v2012\\msys64\usr\bin\bash --login -O expand_aliases -c echo Sourcing OpenFOAM environment...; source $HOME/OpenFOAM/OpenFOAM-v/etc/bashrc; export PATH=$FOAM_LIBBIN/msmpi:$FOAM_LIBBIN:$WM_THIRD_PARTY_DIR/platforms/linux64MingwDPInt32/lib:$PATH; cd "/c/Users/scotth/AppData/Local/Temp/meshCase" && ./Allmesh
17:25:41 Raw command: ['D:/FreeCAD_0.19.24054-Win-Conda_vc14.x-x86_64/bin\\python.exe', '-u', 'C:\\Users\\scotth\\AppData\\Roaming\\FreeCAD\\Mod\\CfdOF-master\\WindowsRunWrapper.py', 'C:\\Users\\scotth\\AppData\\Roaming\\ESI-OpenCFD\\OpenFOAM\\v2012\\\\msys64\\usr\\bin\\bash', '--login', '-O', 'expand_aliases', '-c', 'echo Sourcing OpenFOAM environment...; source $HOME/OpenFOAM/OpenFOAM-v/etc/bashrc; export PATH=$FOAM_LIBBIN/msmpi:$FOAM_LIBBIN:$WM_THIRD_PARTY_DIR/platforms/linux64MingwDPInt32/lib:$PATH; cd "/c/Users/scotth/AppData/Local/Temp/meshCase" && ./Allmesh']
17:25:42 Sourcing OpenFOAM environment...
17:25:42 /usr/bin/bash: /home/ofuser/OpenFOAM/OpenFOAM-v/etc/bashrc: No such file or directory
/usr/bin/bash: /home/ofuser/OpenFOAM/OpenFOAM-v2012/etc/bashrc
Error parsing OpenFOAM version string directory
OS: Windows 10 (10.0)
Version: 0.19.24054 (Git)
Hash: ed873038025277f220dfaa058599a0dfbb435835
Python version: 3.8.6
Qt version: 5.12.5
Coin version: 4.0.0
OCC version: 7.4.0
