issues installing dependencies
Moderator: oliveroxtoby
istapp
Post by istapp »
I've had issues installing hisa and cfmesh-of on my Manjaro Linux machine in order to use the cfd-of workbench in FreeCAD as a frontend for OpenFOAM (org). I've also found a workaround.
tl;dr: In order to minimize headache, use openfoam from openfoam.com when trying to run the cfd-of workbench on an Arch-based linux distro.
Allwmake script seems to run into problems building cfmesh-of from source.
Freecad info:
OS: Manjaro Linux (KDE/plasma)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: Norwegian Bokmal/Norway (nb_NO)
inxi -Fazy output:
System:
  Kernel: 5.11.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=cbeb8c53-a621-42ac-a96b-0b748f010d08 ro i915.modeset=1
  init=/usr/bin/e4rat-lite-preload intel_pstate=enable quiet apparmor=1
  security=apparmor resume=UUID=6315efe9-3ada-4d9e-973b-87e77635e076
  udev.log_priority=3
  Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Distro: Manjaro Linux base: Arch Linux
Machine:
  Type: Laptop System: TOSHIBA product: SATELLITE L855 v: PSKA8E-006008N5
  serial: <filter>
  Mobo: TOSHIBA model: Portable PC v: MP serial: <filter>
  UEFI-[Legacy]: Insyde v: 1.60 date: 04/20/2012
Battery:
  ID-1: BAT0 charge: 39.8 Wh (100.0%) condition: 39.8/48.6 Wh (81.9%)
  volts: 10.8 min: 10.8 model: PA5024U-1BRS type: Li-ion serial: <filter>
  status: Full
CPU:
  Info: Quad Core model: Intel Core i7-3610QM bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  cache: L2: 6 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36732
  Speed: 2062 MHz min/max: 1200/2300 MHz Core speeds (MHz): 1: 2062 2: 2181
  3: 2203 4: 2255 5: 2028 6: 2295 7: 2295 8: 2136
  Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
  Type: l1tf
  mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: mds mitigation: Clear CPU buffers; SMT vulnerable
  Type: meltdown mitigation: PTI
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  mitigation: usercopy/swapgs barriers and __user pointer sanitization
  Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
  IBRS_FW, STIBP: conditional, RSB filling
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort status: Not affected
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Toshiba driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: Importek TOSHIBA Web Camera - HD type: USB driver: uvcvideo
  bus-ID: 1-1.3:5 chip-ID: 10f1:1a43 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5")
  diag: 398mm (15.7")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
  v: 4.2 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
  class-ID: 0403
  Sound Server-1: ALSA v: k5.11.19-1-MANJARO running: yes
  Sound Server-2: JACK v: 0.125.0 running: no
  Sound Server-3: PulseAudio v: 14.2 running: yes
  Sound Server-4: PipeWire v: 0.3.27 running: yes
Network:
  Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Toshiba
  driver: alx v: kernel port: 2000 bus-ID: 01:00.0 chip-ID: 1969:1091
  class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Askey
  driver: ath9k v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0032
  class-ID: 0280
  IF: wlp2s0 state: up mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
  Device-1: Toshiba Bluetooth USB Host Controller type: USB driver: btusb
  v: 0.8 bus-ID: 1-1.2:13 chip-ID: 0930:0219 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Drives:
  Local Storage: total: 465.76 GiB used: 129.12 GiB (27.7%)
  SMART Message: Unable to run smartctl. Root privileges required.
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK5075GSX
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 1M scheme: MBR
Partition:
  ID-1: / raw-size: 448.64 GiB size: 440.59 GiB (98.21%)
  used: 129.12 GiB (29.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Swap:
  Kernel: swappiness: 200 (default 60) cache-pressure: 10 (default 100)
  ID-1: swap-1 type: zram size: 6 GiB used: 1.01 GiB (16.9%) priority: -2
  dev: /dev/zram0
Sensors:
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 272 Uptime: 1d 3h 05m wakeups: 27 Memory: 15.56 GiB
  used: 2.79 GiB (17.9%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 clang: 11.1.0 Packages: 1767 pacman: 1752 lib: 456 flatpak: 15
  Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04 ```
terminal output of ./Allwmake executed from /opt/OpenFOAM/ThirdParty-8 (containing only files from cfmesh-of)
wmake error: could not change to directory 'meshLibrary'
wmake executables
wmake cartesian2DMesh
make[1]: Entering directory '/opt/OpenFOAM/ThirdParty-8/executables/cartesian2DMesh'
Making dependency list for source file cartesian2DMesh.C
could not open file cartesian2DMeshGenerator.H for source file cartesian2DMesh.C due to No such file or directory
could not open dependencies file Make/linux64GccDPInt32Opt/cartesian2DMesh.C.dep for source file cartesian2DMesh.C due to Permission denied
make[1]: *** No rule to make target 'Make/linux64GccDPInt32Opt/cartesian2DMesh.C.dep', needed by 'Make/linux64GccDPInt32Opt/cartesian2DMesh.o'.  Stop.
make[1]: Leaving directory '/opt/OpenFOAM/ThirdParty-8/executables/cartesian2DMesh'
make: *** [/opt/OpenFOAM/OpenFOAM-8/wmake/makefiles/apps:39: cartesian2DMesh] Error 2
wmake utilities .
wmake executables
wmake utilities .
wmake executables
wmake utilities .
./Allwmake executed as sudo, got this error:
    cd /opt/OpenFOAM/ThirdParty-8/ && sudo ./Allwmake
    wmake error: environment variable $WM_OPTIONS not set
so i checked
/opt/OpenFOAM/OpenFOAM-8/etc/config.sh/settings
and don't understand if something is wrong:
#----------------------------------*-sh-*--------------------------------------
# \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
#  \\    /   O peration     | Website:  https://openfoam.org
#   \\  /    A nd           | Copyright (C) 2011-2020 OpenFOAM Foundation
#    \\/     M anipulation  |
# License
#     This file is part of OpenFOAM.
#     OpenFOAM is free software: you can redistribute it and/or modify it
#     under the terms of the GNU General Public License as published by
#     the Free Software Foundation, either version 3 of the License, or
#     (at your option) any later version.
#     OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
#     ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
#     FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
#     for more details.
#     You should have received a copy of the GNU General Public License
#     along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
# File
#     etc/config.sh/settings
# Description
#     Startup file for OpenFOAM
#     Sourced from OpenFOAM-<VERSION>/etc/bashrc
# Set environment variables according to system type
export WM_ARCH=`uname -s`
case "$WM_ARCH" in
Linux)
    WM_ARCH=linux
    # Compiler specifics
    case `uname -m` in
        i686)
            export WM_ARCH_OPTION=32
            export WM_CC='gcc'
            export WM_CXX='g++'
            export WM_CFLAGS='-fPIC'
            export WM_CXXFLAGS='-fPIC -std=c++0x'
            export WM_LDFLAGS=
    x86_64)
        case "$WM_ARCH_OPTION" in
        32)
            export WM_COMPILER_ARCH=64
            export WM_CC='gcc'
            export WM_CXX='g++'
            export WM_CFLAGS='-m32 -fPIC'
            export WM_CXXFLAGS='-m32 -fPIC -std=c++0x'
            export WM_LDFLAGS='-m32'
        64)
            WM_ARCH=linux64
            export WM_COMPILER_LIB_ARCH=64
            export WM_CC='gcc'
            export WM_CXX='g++'
            export WM_CFLAGS='-m64 -fPIC'
            export WM_CXXFLAGS='-m64 -fPIC -std=c++0x'
            export WM_LDFLAGS='-m64'
            echo "Unknown WM_ARCH_OPTION '$WM_ARCH_OPTION', should be 32 or 64"\
                 1>&2
        esac
    aarch64)
        WM_ARCH=linuxArm64
        export WM_CC='gcc'
        export WM_CXX='g++'
        export WM_LDFLAGS=
    armv7l)
        WM_ARCH=linuxARM7
        export WM_COMPILER_LIB_ARCH=32
        export WM_CC='gcc'
        export WM_CXX='g++'
        export WM_LDFLAGS=
    ppc64)
        WM_ARCH=linuxPPC64
        export WM_CC='gcc'
        export WM_CXX='g++'
    ppc64le)
        WM_ARCH=linuxPPC64le
        export WM_CC='gcc'
        export WM_CXX='g++'
        echo Unknown processor type `uname -m` for Linux 1>&2
    esac
SunOS)
    WM_ARCH=SunOS64
    WM_MPLIB=FJMPI
    export WM_CC='gcc'
    export WM_CXX='g++'
    export WM_CFLAGS='-mabi=64 -fPIC'
    export WM_CXXFLAGS='-mabi=64 -fPIC -std=c++0x'
    export WM_LDFLAGS='-mabi=64 -G0'
*)    # An unsupported operating system
    /bin/cat <<USAGE 1>&2
    Your "$WM_ARCH" operating system is not supported by this release
    of OpenFOAM. For further assistance, please contact https://openfoam.org
USAGE
esac
# Location of the jobControl directory
export FOAM_JOB_DIR=$WM_PROJECT_INST_DIR/jobControl
# wmake configuration
export WM_DIR=$WM_PROJECT_DIR/wmake
export WM_LINK_LANGUAGE=c++
export WM_LABEL_OPTION=Int$WM_LABEL_SIZE
export WM_OPTIONS=$WM_ARCH$WM_COMPILER$WM_PRECISION_OPTION$WM_LABEL_OPTION$WM_COMPILE_OPTION
# Base executables/libraries
export FOAM_APPBIN=$WM_PROJECT_DIR/platforms/$WM_OPTIONS/bin
export FOAM_LIBBIN=$WM_PROJECT_DIR/platforms/$WM_OPTIONS/lib
# External (ThirdParty) libraries
export FOAM_EXT_LIBBIN=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER$WM_PRECISION_OPTION$WM_LABEL_OPTION/lib
# Site-specific directory
siteDir="${WM_PROJECT_SITE:-$WM_PROJECT_INST_DIR/site}"
# Shared site executables/libraries
# Similar naming convention as ~OpenFOAM expansion
export FOAM_SITE_APPBIN=$siteDir/$WM_PROJECT_VERSION/platforms/$WM_OPTIONS/bin
export FOAM_SITE_LIBBIN=$siteDir/$WM_PROJECT_VERSION/platforms/$WM_OPTIONS/lib
# User executables/libraries
export FOAM_USER_APPBIN=$WM_PROJECT_USER_DIR/platforms/$WM_OPTIONS/bin
export FOAM_USER_LIBBIN=$WM_PROJECT_USER_DIR/platforms/$WM_OPTIONS/lib
# DynamicCode templates
# - default location is the "~OpenFOAM/codeTemplates/dynamicCode" expansion
# export FOAM_CODE_TEMPLATES=$WM_PROJECT_DIR/etc/codeTemplates/dynamicCode
# Convenience
export FOAM_ETC=$WM_PROJECT_DIR/etc
export FOAM_APP=$WM_PROJECT_DIR/applications
export FOAM_SRC=$WM_PROJECT_DIR/src
export FOAM_TUTORIALS=$WM_PROJECT_DIR/tutorials
export FOAM_UTILITIES=$FOAM_APP/utilities
export FOAM_SOLVERS=$FOAM_APP/solvers
export FOAM_RUN=$WM_PROJECT_USER_DIR/run
# Add wmake to the path - not required for runtime-only environment
[ -d "$WM_DIR" ] && PATH=$WM_DIR:$PATH
# Add OpenFOAM scripts to the path
export PATH=$WM_PROJECT_DIR/bin:$PATH
# Add site-specific scripts to path - only if they exist
if [ -d "$siteDir/bin" ]                        # Generic
then
    _foamAddPath "$siteDir/bin"
fi
if [ -d "$siteDir/$WM_PROJECT_VERSION/bin" ]    # Version-specific
then
    _foamAddPath "$siteDir/$WM_PROJECT_VERSION/bin"
fi
unset siteDir
_foamAddPath $FOAM_USER_APPBIN:$FOAM_SITE_APPBIN:$FOAM_APPBIN
# Make sure to pick up dummy versions of external libraries last
_foamAddLib  $FOAM_USER_LIBBIN:$FOAM_SITE_LIBBIN:$FOAM_LIBBIN:$FOAM_EXT_LIBBIN:$FOAM_LIBBIN/dummy
# Compiler settings
unset gcc_version gmp_version mpfr_version mpc_version
unset MPFR_ARCH_PATH GMP_ARCH_PATH
# Location of compiler installation
if [ -z "$WM_COMPILER_TYPE" ]
then
    WM_COMPILER_TYPE=system
    echo "Warning in $WM_PROJECT_DIR/etc/config.sh/settings:" 1>&2
    echo "    WM_COMPILER_TYPE not set, using '$WM_COMPILER_TYPE'" 1>&2
fi
# Load configured compiler versions, regardless of the compiler type
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config.sh/compiler`
case "$WM_COMPILER_TYPE" in
OpenFOAM | ThirdParty)
    if [ -n "$gcc_version" ]
    then
        gccDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$gcc_version
        gmpDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$gmp_version
        mpfrDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$mpfr_version
        mpcDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$mpc_version
        # Check that the compiler directory can be found
        [ -d "$gccDir" ] || {
            echo 1>&2
            echo "    Cannot find $gccDir installation." 1>&2
            echo "    Please install this compiler version or if you wish to" \
                 " use the system compiler," 1>&2
            echo "    change the 'WM_COMPILER_TYPE' setting to 'system'" 1>&2
            echo
        _foamAddMan     $gccDir/man
        _foamAddPath    $gccDir/bin
        # Add compiler libraries to run-time environment
        _foamAddLib     $gccDir/lib$WM_COMPILER_LIB_ARCH
        # Add gmp/mpfr libraries to run-time environment
        _foamAddLib     $gmpDir/lib$WM_COMPILER_LIB_ARCH
        _foamAddLib     $mpfrDir/lib$WM_COMPILER_LIB_ARCH
        # Add mpc libraries (not need for older gcc) to run-time environment
        if [ -n "$mpc_version" ]
        then
            _foamAddLib     $mpcDir/lib$WM_COMPILER_LIB_ARCH
        fi
        # Used by boost/CGAL:
        export MPFR_ARCH_PATH=$mpfrDir
        export GMP_ARCH_PATH=$gmpDir
    fi
    unset gcc_version gccDir
    unset gmp_version gmpDir  mpfr_version mpfrDir  mpc_version mpcDir
    if [ -n "$clang_version" ]
    then
        clangDir=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER_ARCH/$clang_version
        [ -d "$clangDir" ] || {
            echo 1>&2
            echo "    Cannot find $clangDir installation." 1>&2
            echo 1>&2
        _foamAddMan     $clangDir/share/man
        _foamAddPath    $clangDir/bin
    fi
    unset clang_version clangDir
system)
    # Use system compiler
    echo "Warn: WM_COMPILER_TYPE='$WM_COMPILER_TYPE' is unsupported" 1>&2
    echo "   treating as 'system' instead" 1>&2
esac
installed version of openfoam:
    pacman -Qs Openfoam
    local/openfoam 8-1
cfmesh-of downloaded from https://sourceforge .net/projects/cfmesh-cfdof/
I solved these issues by installing the openfoam-v2012 package instead, and redoing the dependency installations through cfd-of.
oliveroxtoby
Re: issues installing dependencies
Post by oliveroxtoby »
istapp wrote: Wed May 26, 2021 4:45 pm I've had issues installing hisa and cfmesh-of on my Manjaro Linux machine in order to use the cfd-of workbench in FreeCAD as a frontend for OpenFOAM (org). I've also found a workaround.
wmake executables
wmake utilities .
wmake executables
wmake utilities .
wmake executables
wmake utilities .
Was it your decision to install in the /opt/OpenFOAM/ThirdParty-8 directory, or is this where CfdOF chose to put them? CfdOF looks at the environment variable WM_PROJECT_USER_DIR which is supposed to be set to a user-accessible location, usually something like $HOME/OpenFOAM/<username>-8. I'm not sure if you are using a package from your distribution or the one downloaded from openfoam.org, but if it's the former it looks like they might have done something unconventional with the WM_PROJECT_USER_DIR setting.
Anyhow, it does not have to be built from the WM_PROJECT_USER_DIR location, so to work around you can copy the cmesh-cfdof and hisa directories to somewhere you have write permisisons and build them from there.
If building as root, you will probably need to do
. /opt/OpenFOAM/OpenFOAM-8/etc/bashrc
before the Allwmake to source the openfoam environment. But I would suggest rather building in your home directory.
Great - thanks for the feedback.
istapp
Post by istapp »
Thanks!
It was my decision to install cfmesh and hisa in /opt/openfoam/thirdparty-8/. I couldn't find an answer for where to put/build cfmesh and hisa on cfd-online.org or other forums, so i just went ahead and tried.
Manjaro / arch linux don't have cfmesh or hisa in their repos, but they do have both versions of openFOAM.
