Updated to copy the files automatically if possible.oliveroxtoby wrote: ↑Sun Jul 04, 2021 3:13 pmI had a look and it seems that the LP build now has the same conflicing .dlls included as the Conda build. The workaround described above should fix the issue (it does for me). Let's wait to hear from @Syres if these .dlls are needed or not - if so I will try to automate the workaround or find a better way.thschrader wrote: ↑Sun Jul 04, 2021 7:31 am My status:
(thats a pitty, because FC0.20 has some great new FEM-wb features...)
installation bluecfdcore 2017 on windows 10
Moderator: oliveroxtoby
- oliveroxtoby
Re: installation bluecfdcore 2017 on windows 10
I've raised the question regarding the removal of the Dlls with the packagers: https://forum.freecadweb.org/viewtopic.php?f=42&t=59899
Bingo .oliveroxtoby wrote: ↑Mon Jul 05, 2021 9:18 pm ...
After new cfdof-wb update no missing dependencies any more with (LP-version)
OS: Windows 10 Version 1909
Version: 0.20.25065 (Git)
Hash: 4de2ad46b2b9c78ac2721a0dbea7c19306261095
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Can I ask if it worked as a non-Administrator or did you need your work IT Support to login?
Works as non-Administrator.
This includes compiling cfmesh/Hisa.
For installing new software (bluecfd 2020 for instance) I must call our IT.
Thats why I like extractable binaries...
I have noticed that Conda-Version dependency check delivers:
Checking dependencies...
No missing dependencies detected
OS: Windows 10 (10.0)
Version: 0.20.25176 (Git)
Hash: 909dfa7036f9fd36bbd3acee2a5dee161d2819fb
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Have not yet tried to run a simulation. But up to now it looks fine! Thank you everybody!
Qt version: 5.12.9
OCC version: 7.5.2
I try to install cfdOF on windows 10 pro via FreeCAD_0.20.25065_Win-LPv12.5.4_vc17.x-x86-64 version and blueCFD core 2017-2
I have some issues with admin rights. I have try to start FreeCAD as an admin without success.
I have try to install bluecfdcore in a folder with full right but I have once again admin issue.
Can I have your help please?
10:18:45 Traceback (most recent call last):
10:18:45 File "C:\Users\julie\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 271, in downloadInstallCfMesh
10:18:45 runtime = self.testGetRuntime(False)
10:18:45 File "C:\Users\julie\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdPreferencePage.py", line 171, in testGetRuntime
10:18:45 runtime = CfdTools.getFoamRuntime()
10:18:45 File "C:\Users\julie\AppData\Roaming\FreeCAD\Mod\CfdOF\CfdTools.py", line 434, in getFoamRuntime
10:18:45 raise IOError("The directory {} is not a recognised OpenFOAM installation".format(installation_path))
10:18:45 OSError: The directory C:\Program Files\blueCFD-Core-2017\OpenFOAM-5.x is not a recognised OpenFOAM installation
I have done what you asked. For each groups I have autorized everything.
I start FreeCAD as admin (right click on the icon and run as admin) but I still have the issue.
I have try also with Conda and it is the same.
I have uninstall reinstall BluecfdCore several times and locations but the problem is still here
- oliveroxtoby
This might not work with BlueCFD 2017 - please try downloading the latest version (2020).julieng wrote: ↑Sun Jul 11, 2021 5:58 am Hello,
