chsh -s /bin/bash
Moderator: oliveroxtoby
chsh -s /bin/bash
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1264
dlOpen: using fallback library name "libturbulenceModels.dylib"
--> FOAM Warning :
From function void *Foam::dlOpen(const Foam::fileName &, const bool)
in file POSIX.C at line 1275
dlopen error : dlopen(libturbulenceModels.dylib, 9): image not found
--> FOAM Warning :
From function bool Foam::dlLibraryTable::open(const Foam::fileName &, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 106
could not load "libturbulenceModels.so"
Removing 0 existing processor directories
Decomposing mesh region0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod scotch
Finished decomposition in 0.86 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
Reading hexRef8 data : cellLevel
Reading hexRef8 data : pointLevel
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 0
Number of cells = 68341
Number of faces shared with processor 1 = 2381
Number of faces shared with processor 2 = 1630
Number of faces shared with processor 3 = 772
Number of processor patches = 3
Number of processor faces = 4783
Number of boundary faces = 8285
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 1
Number of cells = 68325
Number of faces shared with processor 0 = 2381
Number of faces shared with processor 3 = 396
Number of processor patches = 2
Number of processor faces = 2777
Number of boundary faces = 8641
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 2
Number of cells = 68621
Number of faces shared with processor 0 = 1630
Number of faces shared with processor 3 = 2712
Number of processor faces = 4342
Number of boundary faces = 7949
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 3
Number of cells = 68043
Number of faces shared with processor 0 = 772
Number of faces shared with processor 1 = 396
Number of faces shared with processor 2 = 2712
Number of processor faces = 3880
Number of boundary faces = 9969
Number of processor faces = 7891
Max number of cells = 68621 (0.42220027% above average 68332.5)
Max number of processor patches = 3 (20% above average 2.5)
Max number of faces between processors = 4783 (21.226714% above average 3945.5)
Time = 0
Processor 0: field transfer
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 1: field transfer
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 2: field transfer
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
Processor 3: field transfer
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
End
./Allrun: line 9: mpiexec: command not found
/OpenFOAM/OpenFOAM-9/etc/config.sh/mpi: line 46: mpicc: command not found
mpiexec (OpenRTE) 4.1.2
