simpleFoam ended prematurely and may have crashed. exit code 3
Moderator: oliveroxtoby
Zehrondit
Post by Zehrondit »
Hello everyone,
I ran into such a problem, I'm trying to simulate the flow through a pipe, a very simple exercise, but after a few iterations, the calculation ends. I found a topic with such an error on the forum, but the solution to the problem was not announced. Someone can tell?
23:00:21  /*---------------------------------------------------------------------------*\
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
/*   Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt   *\
|  Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com   |
Build  : 8-53cd1468e263
Exec   : simpleFoam -parallel
Date   : Jan 25 2022
Time   : 23:00:21
Host   : "HOMEPC"
PID    : 8476
23:00:21  I/O    : uncollated
Case   : C:/Users/serge/AppData/Local/Temp/case
nProcs : 4
Slaves :
3
"HOMEPC.5672"
"HOMEPC.1760"
"HOMEPC.7524"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
23:00:21  // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //
Create time
Create mesh for time = 0
23:00:21
SIMPLE: Convergence criteria found
        p: tolerance 0.0001
        U: tolerance 0.0001
        "(k|epsilon|omega|f|v2|nuTilda)": tolerance 0.0001
Reading field p
23:00:21  Reading field U
Reading/calculating face flux field phi
23:00:21  Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
No MRF models present
No finite volume options present
Starting time loop
Time = 1
23:00:21  [1]
[3]
[2]
Generating stack trace...
23:00:21  [1]
Backtrace:
	ZN10StackTraceC1Ev [0x626c1855+0x25]
		 module: C:\PROGRA~1\BLUECF~1\ThirdParty-8\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
	ZN4Foam5error10printStackERNS_7OstreamE [0x6c30ae5a+0x23a]
		 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
	ZN4Foam6sigFpe13sigFpeHandlerEi [0x6c30b693+0x33]
	(No symbol) [0x408282]
		 module: C:\PROGRA~1\BLUECF~1\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\bin\simpleFoam.exe
	_C_specific_handler [0x7ffcdd1bad58+0x98]
		 module: C:\Windows\System32\msvcrt.dll
	0_chkstk [0x7ffcdebc82ff+0x12f]
		 module: C:\Windows\SYSTEM32\ntdll.dll
	RtlRestoreContext [0x7ffcdeb55a0a+0x8aa]
	KiUserExceptionDispatcher [0x7ffcdebc730e+0x2e]
	ZN4Foam22symGaussSeidelSmoother6smoothERKNS_4wordERNS_5FieldIdEERKNS_9lduMatrixERKS5_RKNS_10FieldFieldIS4_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEEhi [0x6c1c17ed+0x2fd]
	ZNK4Foam22symGaussSeidelSmoother6smoothERNS_5FieldIdEERKS2_hi [0x6c1c1b9a+0x3a]
	ZNK4Foam12smoothSolver5solveERNS_5FieldIdEERKS2_h [0x6c1bd022+0x372]
	(No symbol) [0x42b2c4]
	(No symbol) [0x42ca30]
	(No symbol) [0x42cdcb]
	(No symbol) [0x44ee06]
	(No symbol) [0x4013c1]
	(No symbol) [0x4014f6]
	BaseThreadInitThunk [0x7ffcdd2554e0+0x10]
		 module: C:\Windows\System32\KERNEL32.DLL
	RtlUserThreadStart [0x7ffcdeb2485b+0x2b]
[3]
Backtrace:
		 mod...
23:00:21
job aborted:
[ranks] message
[0] terminated
[1-3] process exited without calling finalize
---- error analysis -----
[1-3] on HOMEPC
23:00:21  No handles with labels found to put in legend.
1.FCStd
(236.66 KiB) Downloaded 59 times
oliveroxtoby
Re: simpleFoam ended prematurely and may have crashed. exit code 3
Post by oliveroxtoby »
Zehrondit wrote: Tue Jan 25, 2022 6:07 pm Hello everyone,
Try potential flow initialisation of velocity.
Zehrondit
Post by Zehrondit »
Tried it, still the same error
thschrader
Post by thschrader »
Zehrondit wrote: Tue Feb 01, 2022 5:05 pm Tried it, still the same error
Try this model as a starting point. Check your inlet definition...
Solver does not converge, try finer mesh and turbulence modell.
Regards Thomas
test1_ts.FCStd
(118.86 KiB) Downloaded 72 times
oliveroxtoby
thschrader wrote: Tue Feb 01, 2022 5:28 pm
Quite right - changing the sign of inlet Ux and using potential flow initialisation on velocity works for me.
Zehrondit
Post by Zehrondit »
Yes, already noticed the error, thanks to you and thschrader for the support
