Starting with CfdOF
Moderator: oliveroxtoby
maxam
Re: Starting with CfdOF
Post by maxam »
thschrader wrote: Tue Jun 28, 2022 10:18 am You must create a new run-folder under ofuser-of8, then select a tutorial and
copy it into the new run folder. Did you do that?
Yes I did it! :)
thschrader
Post by thschrader »
maxam wrote: Tue Jun 28, 2022 12:32 pm Yes I did it! :)
Very strange...
I dont have admin-rights on my company-laptop, installation of bluecfd was done by
our IT-service. But this worked with VPN, I could see the installation on my home-office screen.
We choosed "Full Installation" option with all the default settings, as shown here at 1:50:
https://www.youtube.com/watch?v=nl7er2t-TnU&t=100s
Sometimes there is a problem with the installation when bluecfd must overwrite an existing
MS-MPI for using multi-cpu calculations.
Uninstall bluecfd and all existing MS-MPI, reboot system, install again.
If this doesnt help, you should call your IT-guys... ;)
Syres
Post by Syres »
I'd just go straight to your IT guys, it's the home user area that appears to be the root cause, it should definitely be ofuser as stipulated in C:\MyProgrs\blueCFD-Core-2020\blueCFD-Core_MSys2_mingw64.bat which then starts C:\MyProgrs\blueCFD-Core-2020\msys64\msys2_shell.cmd
rem Always create these folders, even if it's not necessary to use them
md %TEMP%\msys_tmp
md %TEMP%\msys_dev
rem hack in our own generic user-name
set USERNAME=ofuser
set USER=ofuser
set HOME=/home/ofuser
I've never seen this happen on an installation before so I can't be much more help.
maxam
Post by maxam »
@thschrader
I repeated the installation as you suggested. It doesn't work.
@Syres
You are right, I need a help from mu IT. Problem is that I already submitted the problem to my IT (before boring you :) ) but they have no time nor skill to solve it.
I think I must be realist and stop trying. However I would like to thank you all for your help.
