[Solved] OpenFOAM version 2112 is not supported
Moderator: oliveroxtoby
poulmack
Post by poulmack »
I installed FreeCAD 0.20 and Windows MinGW OpenFOAM v2112 https://www.openfoam.com/download/release-history, and I get the following messages including that this version is not supported. Is it planned to be included in a future release of cfdOF?
OpenFOAM directory: C:\Program Files\ESI-OpenCFD\OpenFOAM\v2112
16:37:02  Running  echo $FOAM_API
16:37:02  Sourcing OpenFOAM environment...
16:37:02  openfoam: windows support (mingw64) is runtime only
16:37:05  2112
16:37:12  OpenFOAM version 2112 is not supported:
Only version 2012 supported for MinGW installation
16:37:12  Running  cartesianMesh -version
16:37:12  Sourcing OpenFOAM environment...
16:37:12  openfoam: windows support (mingw64) is runtime only
16:37:15  Using: OpenFOAM-v2112 (2112) - visit www.openfoam.com
Build: _14aeaf8dab-20211220
Invalid option: -version
I need to use this version or OpenFOAM v9 from OpenFOAM Foundation, but that's not available in the blueCFD-Core Project yet.
I have Windows 11 on my pc, but it says Windows 10 in the help section of FreeCAD.
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * CfdOF 1.17.0
Regards,
Paul
oliveroxtoby
Re: OpenFOAM version 2112 is not supported
Post by oliveroxtoby »
poulmack wrote: Wed Jun 22, 2022 10:51 pm Hello,
Yes, I'll try to add this soon. The problem is the compilation of HiSA and cfMesh, which I haven't got around to doing yet for this version. If you don't need them, it should work fine as is.
CFD-ROC
Post by CFD-ROC »
Hello, is there any Update on this subject?
Best regards
poulmack
Post by poulmack »
It looks like it's solved in the new release because cfMesh works fine with that version now.
oliveroxtoby
CFD-ROC wrote: Tue Jul 19, 2022 10:11 am Hello, is there any Update on this subject?
Best regards
Versions up to 2206 now supported.
CFD-ROC
Post by CFD-ROC »
Thanks!
Post by Kunda1 »
oliveroxtoby wrote: Tue Jul 19, 2022 8:37 pm Versions up to 2206 now supported.
Can we mark this thread as [Solved] ?
