Hello, Im having mostly a visual problem, when i mesh a cube (just a cube extruded with part design) and make the Open Foam analisys, i realized that when i open it in Paraview to see results these "walls" appear in the middle, like a cross. Does anybody know why this happens? i meshed the cube with gmsh and also refined it.
OS: Windows 10 Version 1903
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Spanish/Argentina (es_AR)
Visual Problem
Moderator: oliveroxtoby
Visual Problem
- error.png (76.2 KiB) Viewed 1081 times
- oliveroxtoby
Re: Visual Problem
Maybe try the 'clean to grid' filter in Paraview - see https://forum.freecadweb.org/viewtopic. ... 8&p=557739Budahn wrote: ↑Wed Jul 06, 2022 4:31 pm Hello, Im having mostly a visual problem, when i mesh a cube (just a cube extruded with part design) and make the Open Foam analisys, i realized that when i open it in Paraview to see results these "walls" appear in the middle, like a cross. Does anybody know why this happens? i meshed the cube with gmsh and also refined it.
Re: Visual Problem
Is there any tutorial that shows how to use it? i´m new to this and i dont really understand what to do exactly or how to apply the filter.
Thanks for the response.
- oliveroxtoby
Re: Visual Problem
It's added automatically now when you run paraview from CfdOF, so if you update your workbench and try again, the problem should be gone.
Re: Visual Problem
thank you a lot. Ramiro
