request to add more functions to cfdof
Moderator: oliveroxtoby
M4mina
Post by M4mina »
I am a hydraulic engineer, I use cfdof in parallel to other commercial software, I want to thank you Oliver for the progress you are achieving and for your efforts
during my work I had to insert some functions to make it work, it should be the same way cfdof inserts the force function. I insert the wall shear stress, mass flowrate for multiphase flow, also I edit the wall roughness and surface tension in the dictionaries,
I would like to ask if there is a way to generate those functions form cfdof directly, kindly find the example below:
functions
   inlet1
        type            surfaceFieldValue;
        libs ("libfieldFunctionObjects.so");
        enabled         true;
        writeControl    timeStep;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name            inlet;
        operation       sum; //absWeightedSum; //sum; //weightedAreaAverage;
        //weightField     alpha.Water;
        fields
            rhoPhi
   PST1
        enabled         true;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name            open001;
        operation       sum;
        fields
            rhoPhi
   PST2
        enabled         true;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name            open002;
        operation       sum;
        fields
            rhoPhi
   PST3
        enabled         true;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name            open003;
        operation       sum;
        fields
            rhoPhi
   PST4
        enabled         true;
        writeInterval   1;
        log             true;
        writeFields     false;
        regionType      patch;
        name            open004;
        operation       sum;
        fields
            rhoPhi
//forces
    ReportingFunction
        type                forces;
        libs                ("libforces.so");
        log                 true;
        patches             ( bridgeinvert );
        p_rgh               p_rgh;
        U                   U;
        rho                 rho;
        pRef                0.0;
        porosity            false;
        writeFields         false;
        CofR                ( 0.0 0.0 0.0 );
        binData
            nBin            20;
            direction       ( 1.0 0.0 0.0 );
            cumulative      true;
//shearstress
    wallShearStress1
    // Mandatory entries (unmodifiable)
    type            wallShearStress;
    libs            (fieldFunctionObjects);
    //runtime modifiable
    patches         (defaultFaces); // (wall1 "(wall2|wall3)");
    // Optional (inherited) entries
    writePrecision  8;
    writeToFile     true;
    useUserTime     true;
    //region          region0;
    enabled         true;
    //log             true;
    //timeStart       0;
    //timeEnd         300;
    executeControl  adjustableRunTime;
    executeInterval 1;
    writeControl    adjustableRunTime;
    writeInterval   25;
If it is possible, I would be grateful. We can generate some tutorials incorporating them for water treatment plants and pump station work which I do usually.
Re: request to add more functions to cfdof
Please put the code in code tags (button </>) for improved readability.
