material editor
A forum to discuss the implementation of a good Materials system in FreeCAD
damian
Re: material editor
Postby damian » Mon Jul 23, 2018 5:21 pm
yorik wrote:
Mon Jul 23, 2018 5:05 pm
Or simply copy it over together with the .py files...
better
EDIT: I have the file together with the .py files,
/home/damian/freecad/src/Mod/Material/MatPropDict.xml
but this file is not built and installed
damian@damian-Aspire:~/freecad-build/Mod/Material$ dir
importFCMat.py MaterialEditor.py Material_rc.py
importFCMat.pyc MaterialEditor.pyc materials-editor.ui
InitGui.py Material.py
Init.py Material.pyc
yorik
Site Admin
Re: material editor
Postby yorik » Tue Jul 24, 2018 12:27 am
did you add it to the cmake file together with the py files? That should be all that is needed...
damian
Re: material editor
Postby damian » Tue Jul 24, 2018 8:32 am
I see it
This weekend I'll do a second commit. I'll fix other minor questions: I've lost doc and some grosses.
Guys! this is the week to demand, not the next week
bernd
Re: material editor
Postby bernd » Wed Jul 25, 2018 4:17 am
https://github.com/FreeCAD/FreeCAD/blob ... txt#L5-L13
damian
Re: material editor
Postby damian » Wed Jul 25, 2018 4:51 am
Done
damian
Re: material editor
Postby damian » Thu Jul 26, 2018 11:41 am
Good morning:
I've done a second commit with:
- installation of MatPropDict.xml
- fixes
- recovering doc
https://github.com/caceres/FreeCAD/comm ... 1f6de9e411
The result is more or less convenient, but I see one problem:
when a user is playing with the MaterialEditor and edit a property which is not a QLineEdit, later the property remains with the default value which can not be eliminated by the user. For instance the Gui::PrefColorButton (with a default grey) or Gui::PrefDoubleSpinBox (with a default cero)
I'm thinking about the third commit with a new button 'Delete value'
Besides, I'm thinking that the line edit to add and remove custom properties must disappear, facilitating a popup dialog where the user could edit its custom property with Name, Type, Unit, etc. But I understand that this modification requires to improve FreeCAD material format. To me, the ini-file format isn't enough to store a really user custom property. I propose to expand the card format to xml, maintaining the ability to read a write config file.
Thank everyone
EDIT: the button 'Delete property' could make the function of 'Delete value'. Less stuff
EDIT:
yorik wrote: ↑
Mon Jun 11, 2018 3:36 pm
That is easy for the "fixed" properties (we know their type), but when the user adds custom properties, I'm not sure. Ideally there should be a way to specify the property type. Maybe we need one more column that says the type?
For me with the above-mentioned popup dialog, and maintaining hidden the columns of Type, Unit, etc
yorik
Site Admin
Re: material editor
Postby yorik » Thu Jul 26, 2018 1:34 pm
Probably the very, very ideal way would be to sublass the QColorDialog (or any other...) and add a new "Remove value" button. But that's a lot of work just for something cosmetic, probably it's indeed best to simply add a "Delete value" button somewhere.
damian
Re: material editor
Postby damian » Fri Jul 27, 2018 9:59 pm
Good evening:
From the first day, I've been suffering sporadically segmentation faults.
Today I've been investigating the issue and I can reproduce it frequently, more frequent than I would like.
The fault comes randomly with the change of card in the combobox, and sometimes opening or closing the editor. The main problem is in the first steps, with the model implementation. The QStyledItemDelegate and the Widgets aren't the problems.
I've been testing different compositions, beginning with the original code with the minimum modifications, and always the same result in the first stages (loading model).
I need a width recess. The code is in github, and presumably complete but buggy.
Thank everyone
damian
Re: material editor
Postby damian » Sat Jul 28, 2018 4:18 pm
okay! Two different problems:
FIRST
Buttons cancel y okay: I can't reproduce the segmentation fault with pyside2. Then nothing to do.
SECOND
change of card in the combo material: a new composition of the method updateContents, avoiding the statement model.clear(), solves the problem
I'm finishing!!!
yorik
Site Admin
Re: material editor
Postby yorik » Tue Jul 31, 2018 7:05 pm
The crash is probably due to the expat bug on debian-based systems. Everything that uses xml in python crashes. But @kkremitzki is working on this I think... I propose to postpone to merge your PR until we know a bit more from him because otherwise it will make the mat editor unusable for a large portion of users...
