material preferences
A forum to discuss the implementation of a good Materials system in FreeCAD
bernd
Postby bernd » Fri Jun 01, 2018 6:59 pm
I would like to introduce some material preferences in FreeCAD. How is this done? Material module has no GUI workbench.
Mainly I would like to move the material directory preferences from FEM, see screen attached into materials and use it in the material editor here to have a smart choice between various material directories. https://github.com/FreeCAD/FreeCAD/blob ... py#L79-L89
bernd
see FreeCAD preferences, FEM, general ...
yorik
Site Admin
Re: material preferences
Postby yorik » Sat Jun 02, 2018 5:13 pm
This looks good...
I would leave it in FEM fow now, then we can think of something better. Maybe both FEM and Arch could fire that page up?
I quite like the fact that the material module has no WB, so it is directly integrated in all workbenches that use it...
Jee-Bee
Postby Jee-Bee » Sat Jun 02, 2018 5:59 pm
...FEM and Arch ...
Why is Part Design every time forgotten. Every part or body needs material properties too.
yorik
Site Admin
Postby yorik » Mon Jun 04, 2018 3:14 pm
It's not forgotten :) The Materials framework is very simple and made to work with the entire FreeCAD. It would just be a matter of implementing something in PartDesign. But I guess this requires some deeper discussion as how it should be implemented.
bernd
Postby bernd » Mon Jun 04, 2018 3:26 pm
a part can be alive without a material, but FEM without material is imposible! ATM we try to normalise material system between FEM and Arch which are there allready. Material in Part Design really needs some thinking first, since this is under FEM and Arch.
bernd
Postby bernd » Mon Jun 04, 2018 3:32 pm
This looks good...
My idea was to make a wb for the material module which has the material editor as tool and this page as pref. Mhh but we could go the other way around and use this page in arch and fem. No matter which way we gone itneeds a separate tab in prefs. I will move these prefs inside Fem in a separate tab and than we will see ...
sliptonic
Postby sliptonic » Tue Jun 05, 2018 7:06 pm
This looks good...
I like the idea of a material wb too. Path will need more material data in the future for setting feed/speed values on operations. A simpler material wb would be more intuitive than a set of features buried in FEM.
bernd
Postby bernd » Tue Jun 05, 2018 8:31 pm
git commit 05bee3aa1 and git commit 7c316ba0 ATM one needs to change the resource directories of the MaterialEditor in FEM pref.
bernd
Postby bernd » Tue Jun 05, 2018 8:33 pm
That means you will have totally different material properties than FEM needs (mainly Young's modulus and poisons ratio, ATM) ?
sliptonic
Postby sliptonic » Wed Jun 06, 2018 3:39 pm
Yes, things like Brinell hardness that will factor into calculating material removal rate. But since I'm no where near needing that stuff yet, I was really just reacting to the UI discussion.
