Word size of FreeCAD: 64-bit, Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.14
OCC version: 7.2.0
The material editor is currently completely broken:
- add a material, then "use FreeCAD material editor"
- in the "Material card" field select e.g. "ABS"
result: you see the values for ABS
- now press OK
result: the material values are not taken into account, all values are zero and starting a simulation tells you that too.
The checkbox "use this task panel" is not set so the material editor must take it from the loaded file.
OK to open a bug report?
